    TypeError: curr.start.toISOString is not a function
    34 Posts 7 Posters 36.9k Views 6 Watching
    • MichMichM
      MichMich
      Do you have a calendar feed which I can test that gives the error?
      • BangeeB
        Bangee Module Developer
        please give me your Mailadress, I’ll share my Calendar with you. :-)
        • MichMichM
          MichMich
          Got it. Thanks. Will probably be able to look into this next week. Is that ok?
          • BangeeB
            yeah, no problem. today my calendar is running. I’ve made no changes…
            strange, I’ve sent you the link to the working one.
            Thanks! :hand_splayed_tone1:
            • BangeeB
              @MichMich did you find the problem?
              MichMichM 1 Reply Last reply
              • MichMichM
                MichMich @Bangee
                @Bangee Did not have any time to look into this … I’m sorry! Did I understand it correctly that you managed to solve it with the new calendar feed you sent me?
                • BangeeB
                  i’ve sent you the working on. i don’t know why, but most of the time, the calendar is working find.
                  And sometimes there is this bug. I’ve sent you a diff file, with the differences between the files.
                  • BangeeB
                    @MichMich I still have these problems with office365 calender :-(
                    Did you found a solution for this issue?
                    • MichMichM
                      MichMich
                      Did you tryout the develop branch yet? It might include some changes that could help you.
                      • E
                        eugenelai
                        Any update on this? I’m also using office365 calendar and my Calendar randomly stopped working. I’ve tried the node debug.js and just get the below. @MichMich @KirAsh4
                        pi@rpi3:~/MagicMirror/modules/default/calendar $ sudo node debug.js
                        Create fetcher ...
                        Create fetcher done!
                        [ { title: 'Max',
                            startDate: '1493568000000',
                            endDate: '1493654400000',
                            fullDayEvent: true,
                            firstYear: 1990 },
                          { title: 'Someone',
                            startDate: '1493740800000',
                            endDate: '1493827200000',
                            fullDayEvent: true,
                            firstYear: 2010 },
                          { title: 'Another',
                            startDate: '1493913600000',
                            endDate: '1494000000000',
                            fullDayEvent: true,
                            firstYear: 2000 },
                          { title: 'Event',
                            startDate: '1494086400000',
                            endDate: '1494172800000',
                            fullDayEvent: true,
                            firstYear: 1980 } ]
                        • BangeeB
                          nope, still same here… :-(
                            clumsy_ninja
                            I’m just starting with my MagicMirror today and am also having this issue.
                            I have two calendars,
                            1. Office 365 - gives this issue
                            2. google - loads, but doesn’t display all events in my calendar
                            • BangeeB
                              so now I found something new:
                              in my Calendar the DTSTART is set to:
                              DTSTART;TZID="(UTC+00:00) Monrovia, Reykjavik":20161028T200000
                              when I remove (UTC+00:00) everything works fine.
                              Then it looks like this:
                              DTSTART;TZID="Monrovia, Reykjavik":20161028T200000
                              I’ve used a PHP Script to do this.
                              @MichMich can you implement this in the js script? or what will I need to replace for testing?
                                      $ch = curl_init();
                                      // set url
                                      curl_setopt($ch, CURLOPT_URL, "https://ical.url/calendar.ics");
                                      curl_setopt($ch, CURLOPT_USERAGENT, "Mozilla/4.0 (compatible; MSIE 5.01; Windows NT 5.0)");
                                      curl_setopt($ch, CURLOPT_HEADER, false);
                                      curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
                                      curl_setopt($ch, CURLOPT_FOLLOWLOCATION, true);
                                      curl_setopt($ch, CURLOPT_COOKIEJAR, "blabla");
                                          // $output contains the output string
                                      $output = curl_exec($ch);
                                      // close curl resource to free up system resources
                                      curl_close($ch);
                                      $response = new Response();
                                      $output = str_replace('(UTC+00:00) ', '', $output);
                                      $response->setContent($output);
                                      $response->setStatusCode(Response::HTTP_OK);
                                      $response->headers->set('Content-type', 'text/calendar');
                                      return $response;
                              • MichMichM
                                MichMich
                                I suggest you fork the project, implement the fix that works for you and send me a PR. That way you can test it and others can benefit from your solution. :)
                                • BangeeB
                                  Ok, :-) but actually I don’t no where to implement this in js :-)
                                  Can someone give me a hint where to place my str_replace (UTC+00:00) in DTSTART variable?
                                  Thanks ;-)
                                    chadderwick
                                    So I ran into this problem and have a fix. I have uploaded the files to drop box for know. If this fixes others, i’ll look into updating the project.
                                    There are 2 files that need updated:
                                    /home/pi/MagicMirror/modules/default/calendar/vendor/node-ical.js
                                    line 33
                                    https://dl.dropboxusercontent.com/u/1184191/node-ical.js
                                    /home/pi/MagicMirror/modules/default/calendar/vendor/ical.js
                                    line 97
                                    https://dl.dropboxusercontent.com/u/1184191/ical.js
                                    • BangeeB
                                      can you maybe post your solution? that would be great
                                      thanks bangee
                                        chadderwick
                                        Apologies…my dropbox links dropped out.
                                        Here are the updated files:
                                        https://www.dropbox.com/sh/xvlusz1po4tvq24/AABF9ZuCL5j-ok4xfnYA5JsHa?dl=0
                                        This has not been tested with the latest version. I bought 6 different types of mirrors (glass and acrylic) and couldn’t find what i was looking for so gave up the dream for now…
                                          moshinh
                                          Does this work? Confirmed? I tried someone elses .js and it didnt :-(
                                            moshinh
                                            it does not :-(
