    TypeError: curr.start.toISOString is not a function
    34 Posts 7 Posters 36.9k Views 6 Watching
    • KirAsh4K
      KirAsh4 Moderator
      Ok, preliminary digging done. It appears the pattern matching isn’t working correctly for the times that Office386 puts on its calendar, I mean, really 1601 for a year? I don’t think so.
      Anyway, I’m going to tag @MichMich on this since he wrote the default calendar and I believe the node-ical stuff as well. I have the output of the ICS, so if you had shared it to get me the link, you can unshare it. I can work with the saved output.
      • BangeeB
        Bangee Module Developer
        ok, sounds not that good as expected. Whats next?
        • KirAsh4K
          KirAsh4 Moderator
          Basically one of us has to find the time to investigate. The way Office386 creates its dates is really odd. Leave it to Microsoft to break things … as always.
          • BangeeB
            ok, my girlfriends calnedar is working. also with office 365 :-) so stupid…
            • KirAsh4K
              KirAsh4 Moderator
              Does she have the same events as you? Setup the same way? Same time zones configured?
              • BangeeB
                she has different events in her calendar, but the all the other things are the same as mine.
                • MichMichM
                  MichMich
                  Do you have a calendar feed which I can test that gives the error?
                  • BangeeB
                    please give me your Mailadress, I’ll share my Calendar with you. :-)
                    • MichMichM
                      MichMich
                      Got it. Thanks. Will probably be able to look into this next week. Is that ok?
                      • BangeeB
                        yeah, no problem. today my calendar is running. I’ve made no changes…
                        strange, I’ve sent you the link to the working one.
                        Thanks! :hand_splayed_tone1:
                        • BangeeB
                          @MichMich did you find the problem?
                          MichMichM 1 Reply Last reply
                          • MichMichM
                            MichMich @Bangee
                            @Bangee Did not have any time to look into this … I’m sorry! Did I understand it correctly that you managed to solve it with the new calendar feed you sent me?
                            • BangeeB
                              i’ve sent you the working on. i don’t know why, but most of the time, the calendar is working find.
                              And sometimes there is this bug. I’ve sent you a diff file, with the differences between the files.
                              • BangeeB
                                @MichMich I still have these problems with office365 calender :-(
                                Did you found a solution for this issue?
                                • MichMichM
                                  MichMich
                                  Did you tryout the develop branch yet? It might include some changes that could help you.
                                  • E
                                    eugenelai
                                    Any update on this? I’m also using office365 calendar and my Calendar randomly stopped working. I’ve tried the node debug.js and just get the below. @MichMich @KirAsh4
                                    pi@rpi3:~/MagicMirror/modules/default/calendar $ sudo node debug.js
                                    Create fetcher ...
                                    Create fetcher done!
                                    [ { title: 'Max',
                                        startDate: '1493568000000',
                                        endDate: '1493654400000',
                                        fullDayEvent: true,
                                        firstYear: 1990 },
                                      { title: 'Someone',
                                        startDate: '1493740800000',
                                        endDate: '1493827200000',
                                        fullDayEvent: true,
                                        firstYear: 2010 },
                                      { title: 'Another',
                                        startDate: '1493913600000',
                                        endDate: '1494000000000',
                                        fullDayEvent: true,
                                        firstYear: 2000 },
                                      { title: 'Event',
                                        startDate: '1494086400000',
                                        endDate: '1494172800000',
                                        fullDayEvent: true,
                                        firstYear: 1980 } ]
                                    • BangeeB
                                      nope, still same here… :-(
                                        clumsy_ninja
                                        I’m just starting with my MagicMirror today and am also having this issue.
                                        I have two calendars,
                                        1. Office 365 - gives this issue
                                        2. google - loads, but doesn’t display all events in my calendar
                                        • BangeeB
                                          so now I found something new:
                                          in my Calendar the DTSTART is set to:
                                          DTSTART;TZID="(UTC+00:00) Monrovia, Reykjavik":20161028T200000
                                          when I remove (UTC+00:00) everything works fine.
                                          Then it looks like this:
                                          DTSTART;TZID="Monrovia, Reykjavik":20161028T200000
                                          I’ve used a PHP Script to do this.
                                          @MichMich can you implement this in the js script? or what will I need to replace for testing?
                                                  $ch = curl_init();
                                                  // set url
                                                  curl_setopt($ch, CURLOPT_URL, "https://ical.url/calendar.ics");
                                                  curl_setopt($ch, CURLOPT_USERAGENT, "Mozilla/4.0 (compatible; MSIE 5.01; Windows NT 5.0)");
                                                  curl_setopt($ch, CURLOPT_HEADER, false);
                                                  curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
                                                  curl_setopt($ch, CURLOPT_FOLLOWLOCATION, true);
                                                  curl_setopt($ch, CURLOPT_COOKIEJAR, "blabla");
                                                      // $output contains the output string
                                                  $output = curl_exec($ch);
                                                  // close curl resource to free up system resources
                                                  curl_close($ch);
                                                  $response = new Response();
                                                  $output = str_replace('(UTC+00:00) ', '', $output);
                                                  $response->setContent($output);
                                                  $response->setStatusCode(Response::HTTP_OK);
                                                  $response->headers->set('Content-type', 'text/calendar');
                                                  return $response;
                                          • MichMichM
                                            MichMich
                                            I suggest you fork the project, implement the fix that works for you and send me a PR. That way you can test it and others can benefit from your solution. :)
