    TypeError: curr.start.toISOString is not a function
    34 Posts 7 Posters 36.5k Views 6 Watching
    • K
      KirAsh4 Moderator
      Basically one of us has to find the time to investigate. The way Office386 creates its dates is really odd. Leave it to Microsoft to break things … as always.
        Bangee Module Developer
        ok, my girlfriends calnedar is working. also with office 365 :-) so stupid…
        • K
          KirAsh4 Moderator
          Does she have the same events as you? Setup the same way? Same time zones configured?
            she has different events in her calendar, but the all the other things are the same as mine.
            • MichMichM
              MichMich
              Do you have a calendar feed which I can test that gives the error?
                please give me your Mailadress, I’ll share my Calendar with you. :-)
                • MichMichM
                  MichMich
                  Got it. Thanks. Will probably be able to look into this next week. Is that ok?
                    yeah, no problem. today my calendar is running. I’ve made no changes…
                    strange, I’ve sent you the link to the working one.
                    Thanks! :hand_splayed_tone1:
                      @MichMich did you find the problem?
                      MichMichM 1 Reply Last reply Reply Quote 0
                      • MichMichM
                        MichMich @Bangee
                        @Bangee Did not have any time to look into this … I’m sorry! Did I understand it correctly that you managed to solve it with the new calendar feed you sent me?
                          i’ve sent you the working on. i don’t know why, but most of the time, the calendar is working find.
                          And sometimes there is this bug. I’ve sent you a diff file, with the differences between the files.
                            @MichMich I still have these problems with office365 calender :-(
                            Did you found a solution for this issue?
                            • MichMichM
                              MichMich
                              Did you tryout the develop branch yet? It might include some changes that could help you.
                              • E
                                eugenelai
                                Any update on this? I’m also using office365 calendar and my Calendar randomly stopped working. I’ve tried the node debug.js and just get the below. @MichMich @KirAsh4
                                pi@rpi3:~/MagicMirror/modules/default/calendar $ sudo node debug.js
                                Create fetcher ...
                                Create fetcher done!
                                [ { title: 'Max',
                                    startDate: '1493568000000',
                                    endDate: '1493654400000',
                                    fullDayEvent: true,
                                    firstYear: 1990 },
                                  { title: 'Someone',
                                    startDate: '1493740800000',
                                    endDate: '1493827200000',
                                    fullDayEvent: true,
                                    firstYear: 2010 },
                                  { title: 'Another',
                                    startDate: '1493913600000',
                                    endDate: '1494000000000',
                                    fullDayEvent: true,
                                    firstYear: 2000 },
                                  { title: 'Event',
                                    startDate: '1494086400000',
                                    endDate: '1494172800000',
                                    fullDayEvent: true,
                                    firstYear: 1980 } ]
                                  nope, still same here… :-(
                                    clumsy_ninja
                                    I’m just starting with my MagicMirror today and am also having this issue.
                                    I have two calendars,
                                    1. Office 365 - gives this issue
                                    2. google - loads, but doesn’t display all events in my calendar
                                      so now I found something new:
                                      in my Calendar the DTSTART is set to:
                                      DTSTART;TZID="(UTC+00:00) Monrovia, Reykjavik":20161028T200000
                                      when I remove (UTC+00:00) everything works fine.
                                      Then it looks like this:
                                      DTSTART;TZID="Monrovia, Reykjavik":20161028T200000
                                      I’ve used a PHP Script to do this.
                                      @MichMich can you implement this in the js script? or what will I need to replace for testing?
                                              $ch = curl_init();
                                              // set url
                                              curl_setopt($ch, CURLOPT_URL, "https://ical.url/calendar.ics");
                                              curl_setopt($ch, CURLOPT_USERAGENT, "Mozilla/4.0 (compatible; MSIE 5.01; Windows NT 5.0)");
                                              curl_setopt($ch, CURLOPT_HEADER, false);
                                              curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
                                              curl_setopt($ch, CURLOPT_FOLLOWLOCATION, true);
                                              curl_setopt($ch, CURLOPT_COOKIEJAR, "blabla");
                                                  // $output contains the output string
                                              $output = curl_exec($ch);
                                              // close curl resource to free up system resources
                                              curl_close($ch);
                                              $response = new Response();
                                              $output = str_replace('(UTC+00:00) ', '', $output);
                                              $response->setContent($output);
                                              $response->setStatusCode(Response::HTTP_OK);
                                              $response->headers->set('Content-type', 'text/calendar');
                                              return $response;
                                      • MichMichM
                                        MichMich
                                        I suggest you fork the project, implement the fix that works for you and send me a PR. That way you can test it and others can benefit from your solution. :)
                                          Ok, :-) but actually I don’t no where to implement this in js :-)
                                          Can someone give me a hint where to place my str_replace (UTC+00:00) in DTSTART variable?
                                          Thanks ;-)
                                            chadderwick
                                            So I ran into this problem and have a fix. I have uploaded the files to drop box for know. If this fixes others, i’ll look into updating the project.
                                            There are 2 files that need updated:
                                            /home/pi/MagicMirror/modules/default/calendar/vendor/node-ical.js
                                            line 33
                                            https://dl.dropboxusercontent.com/u/1184191/node-ical.js
                                            /home/pi/MagicMirror/modules/default/calendar/vendor/ical.js
                                            line 97
                                            https://dl.dropboxusercontent.com/u/1184191/ical.js
