    TypeError: curr.start.toISOString is not a function
    34 Posts 7 Posters 36.9k Views 6 Watching
    • BangeeB
      Bangee Module Developer
      ok, sounds not that good as expected. Whats next?
      • KirAsh4K
        KirAsh4 Moderator
        Basically one of us has to find the time to investigate. The way Office386 creates its dates is really odd. Leave it to Microsoft to break things … as always.
        • BangeeB
          ok, my girlfriends calnedar is working. also with office 365 :-) so stupid…
          • KirAsh4K
            KirAsh4 Moderator
            Does she have the same events as you? Setup the same way? Same time zones configured?
            • BangeeB
              she has different events in her calendar, but the all the other things are the same as mine.
              • MichMichM
                MichMich
                Do you have a calendar feed which I can test that gives the error?
                • BangeeB
                  please give me your Mailadress, I’ll share my Calendar with you. :-)
                  • MichMichM
                    MichMich
                    Got it. Thanks. Will probably be able to look into this next week. Is that ok?
                    • BangeeB
                      yeah, no problem. today my calendar is running. I’ve made no changes…
                      strange, I’ve sent you the link to the working one.
                      Thanks! :hand_splayed_tone1:
                      • BangeeB
                        @MichMich did you find the problem?
                        MichMichM 1 Reply Last reply
                        • MichMichM
                          MichMich @Bangee
                          @Bangee Did not have any time to look into this … I’m sorry! Did I understand it correctly that you managed to solve it with the new calendar feed you sent me?
                          • BangeeB
                            i’ve sent you the working on. i don’t know why, but most of the time, the calendar is working find.
                            And sometimes there is this bug. I’ve sent you a diff file, with the differences between the files.
                            • BangeeB
                              @MichMich I still have these problems with office365 calender :-(
                              Did you found a solution for this issue?
                              • MichMichM
                                MichMich
                                Did you tryout the develop branch yet? It might include some changes that could help you.
                                • E
                                  eugenelai
                                  Any update on this? I’m also using office365 calendar and my Calendar randomly stopped working. I’ve tried the node debug.js and just get the below. @MichMich @KirAsh4
                                  pi@rpi3:~/MagicMirror/modules/default/calendar $ sudo node debug.js
                                  Create fetcher ...
                                  Create fetcher done!
                                  [ { title: 'Max',
                                      startDate: '1493568000000',
                                      endDate: '1493654400000',
                                      fullDayEvent: true,
                                      firstYear: 1990 },
                                    { title: 'Someone',
                                      startDate: '1493740800000',
                                      endDate: '1493827200000',
                                      fullDayEvent: true,
                                      firstYear: 2010 },
                                    { title: 'Another',
                                      startDate: '1493913600000',
                                      endDate: '1494000000000',
                                      fullDayEvent: true,
                                      firstYear: 2000 },
                                    { title: 'Event',
                                      startDate: '1494086400000',
                                      endDate: '1494172800000',
                                      fullDayEvent: true,
                                      firstYear: 1980 } ]
                                  • BangeeB
                                    nope, still same here… :-(
                                      clumsy_ninja
                                      I’m just starting with my MagicMirror today and am also having this issue.
                                      I have two calendars,
                                      1. Office 365 - gives this issue
                                      2. google - loads, but doesn’t display all events in my calendar
                                      • BangeeB
                                        so now I found something new:
                                        in my Calendar the DTSTART is set to:
                                        DTSTART;TZID="(UTC+00:00) Monrovia, Reykjavik":20161028T200000
                                        when I remove (UTC+00:00) everything works fine.
                                        Then it looks like this:
                                        DTSTART;TZID="Monrovia, Reykjavik":20161028T200000
                                        I’ve used a PHP Script to do this.
                                        @MichMich can you implement this in the js script? or what will I need to replace for testing?
                                                $ch = curl_init();
                                                // set url
                                                curl_setopt($ch, CURLOPT_URL, "https://ical.url/calendar.ics");
                                                curl_setopt($ch, CURLOPT_USERAGENT, "Mozilla/4.0 (compatible; MSIE 5.01; Windows NT 5.0)");
                                                curl_setopt($ch, CURLOPT_HEADER, false);
                                                curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
                                                curl_setopt($ch, CURLOPT_FOLLOWLOCATION, true);
                                                curl_setopt($ch, CURLOPT_COOKIEJAR, "blabla");
                                                    // $output contains the output string
                                                $output = curl_exec($ch);
                                                // close curl resource to free up system resources
                                                curl_close($ch);
                                                $response = new Response();
                                                $output = str_replace('(UTC+00:00) ', '', $output);
                                                $response->setContent($output);
                                                $response->setStatusCode(Response::HTTP_OK);
                                                $response->headers->set('Content-type', 'text/calendar');
                                                return $response;
                                        • MichMichM
                                          MichMich
                                          I suggest you fork the project, implement the fix that works for you and send me a PR. That way you can test it and others can benefit from your solution. :)
                                          • BangeeB
                                            Ok, :-) but actually I don’t no where to implement this in js :-)
                                            Can someone give me a hint where to place my str_replace (UTC+00:00) in DTSTART variable?
                                            Thanks ;-)
