    TypeError: curr.start.toISOString is not a function
    34 Posts 7 Posters 36.5k Views 6 Watching
    • K
      KirAsh4 Moderator
      Just a guess, since I don’t know what calendar you’re using nor what the specific entry might be that’s blowing up, but the lines above that are relevant here:
              if (curr.start.length === 8) {
                  var comps = /^(\d{4})(\d{2})(\d{2})$/.exec(curr.start);
                  if (comps) {
                      curr.start = new Date (comps[1], comps[2] - 1, comps[3]);
      For some reason, the comps variable is failing to get set properly, which then causes the Date() object to fail and things just cascade from there. So you’d have to figure out why it’s failing, or what’s being set in it. What you could do is, in node-ical.js, after line 33, insert the following:
      console.dir(comps);
      Then run your debug.js file again and see what you get.
        Bangee Module Developer
        so i think you are right:
        pi@raspberrypi:~/MagicMirror/modules/default/calendar $ node debug.js
        Create fetcher ...
        Create fetcher done!
        undefined
        undefined
        undefined
        /home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:39
              rule += ';DTSTART=' + curr.start.toISOString().replace(/[-:]/g, '');
            at Object.ical.objectHandlers.END (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:39:40)
            at Object.handleObject (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/ical.js:257:41)
            at Object.parseICS (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/ical.js:298:20)
            at Request._callback (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:11:24)
            at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:200:22)
            at emitTwo (events.js:100:13)
            at Request.emit (events.js:185:7)
            at Request.<anonymous> (/home/pi/MagicMirror/node_modules/request/request.js:1067:10)
            at emitOne (events.js:95:20)
            at Request.emit (events.js:182:7)
        I’m using office365 calendar, but most of the time, my calendar is running …
        So whats next? :-)
        • K
          KirAsh4 Moderator
          Right, that was simply checking what’s in 'comps', however it appears the variable itself isn’t being set from the line above it. That is assuming you put the 'console.dir()' line in the right spot. :)
          So you can literally start sprinkling console calls to try and figure out where and why it’s failing:
          console.log("curr contains:");
          console.dir(curr);
          console.log("curr.start is set to:");
          console.log(curr.start);
              console.log("comps array contains:");
              console.dir(comps);
              if (comps) {
            ok, so here it is:
            Create fetcher ...
            curr contains:
            { type: 'STANDARD',
              params: [],
              start: { Mon, 01 Jan 1601 02:00:00 GMT tz: undefined },
              tzoffsetfrom: '+0200',
              tzoffsetto: '+0100',
              rrule: 'RRULE:FREQ=YEARLY;INTERVAL=1;BYDAY=-1SU;BYMONTH=10' }
            curr contains:
            { type: 'DAYLIGHT',
              params: [],
              start: { Mon, 01 Jan 1601 01:00:00 GMT tz: undefined },
              tzoffsetfrom: '+0100',
              tzoffsetto: '+0200',
              rrule: 'RRULE:FREQ=YEARLY;INTERVAL=1;BYDAY=-1SU;BYMONTH=3' }
            curr contains:
            { type: 'VEVENT',
              params: [],
              rrule: 'RRULE:FREQ=WEEKLY;UNTIL=20161004T183000Z;INTERVAL=1;BYDAY=TU;WKST=SU',
              uid: '040000008200E00074C5B7101A82E008000000009B3BEC42F394D10100000000000000001000000074F8AEF399AAD4438C6FBCBC8E500415',
              summary: 'Sommertraining',
              start: '00) Amsterdam, Berlin, Bern, Rome, Stockholm, Vienna":20160524T203000',
              end: '00) Amsterdam, Berlin, Bern, Rome, Stockholm, Vienna":20160524T220000',
              class: 'PUBLIC',
              priority: '5',
              dtstamp: '20160621T203603Z',
              transparency: 'OPAQUE',
              status: 'CONFIRMED',
              sequence: '0',
              'MICROSOFT-CDO-APPT-SEQUENCE': '0',
              'MICROSOFT-CDO-BUSYSTATUS': 'BUSY',
              'MICROSOFT-CDO-INTENDEDSTATUS': 'BUSY',
              'MICROSOFT-CDO-ALLDAYEVENT': 'FALSE',
              'MICROSOFT-CDO-IMPORTANCE': '1',
              'MICROSOFT-CDO-INSTTYPE': '1',
              'MICROSOFT-DISALLOW-COUNTER': 'FALSE' }
            /home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:45
            • K
              KirAsh4 Moderator
              There’s that failure … Notice the contents of curr.start in each iteration:
              That’s where it fails. It processes the previous two just fine, then encounters an invalid time stamp. This is something within the Offce386 calendar. What is that event?
                its a weekly event.
                I’ll Try to delete this event and reload, but thats no the solution… :-(
                • K
                  KirAsh4 Moderator
                  It doesn’t appear that the event information is valid to begin with, at least not the way that Office386 is serving the information. It doesn’t make sense to me. It should be an array, not a string. So the next question is, is the data you are receiving valid? And if so, where is that getting mangled that 'curr' ends up with an invalid array.
                  Unfortunately I don’t have/use Office386’s calendar, so I’m not going to be able to debug this unless you want to share your calendar link with me. or, recreate a blank one with similar events and share that.
                  • K
                    KirAsh4 Moderator
                    Ok, preliminary digging done. It appears the pattern matching isn’t working correctly for the times that Office386 puts on its calendar, I mean, really 1601 for a year? I don’t think so.
                    Anyway, I’m going to tag @MichMich on this since he wrote the default calendar and I believe the node-ical stuff as well. I have the output of the ICS, so if you had shared it to get me the link, you can unshare it. I can work with the saved output.
                      ok, sounds not that good as expected. Whats next?
                      • K
                        KirAsh4 Moderator
                        Basically one of us has to find the time to investigate. The way Office386 creates its dates is really odd. Leave it to Microsoft to break things … as always.
                          ok, my girlfriends calnedar is working. also with office 365 :-) so stupid…
                          • K
                            KirAsh4 Moderator
                            Does she have the same events as you? Setup the same way? Same time zones configured?
                              she has different events in her calendar, but the all the other things are the same as mine.
                              • MichMichM
                                MichMich
                                Do you have a calendar feed which I can test that gives the error?
                                  please give me your Mailadress, I’ll share my Calendar with you. :-)
                                  • MichMichM
                                    MichMich
                                    Got it. Thanks. Will probably be able to look into this next week. Is that ok?
                                      yeah, no problem. today my calendar is running. I’ve made no changes…
                                      strange, I’ve sent you the link to the working one.
                                      Thanks! :hand_splayed_tone1:
                                        @MichMich did you find the problem?
                                        MichMichM 1 Reply Last reply Reply Quote 0
                                        • MichMichM
                                          MichMich @Bangee
                                          @Bangee Did not have any time to look into this … I’m sorry! Did I understand it correctly that you managed to solve it with the new calendar feed you sent me?
                                            i’ve sent you the working on. i don’t know why, but most of the time, the calendar is working find.
                                            And sometimes there is this bug. I’ve sent you a diff file, with the differences between the files.
