[Remote-Control] Shutdown, Configure and Update your MagicMirror
@goldyfruit Why not just post the text? :D
[2.1.0] - 2020-11-01
Hello! Ezequiel here. Just wanted to say thanks for trust in me, in the past days I made a lot of changes into the code, adding some functions that’ll surely be in a future release, and also putting everything together in my fork. I answered almost every issue raised, and tried to help every person that use this module. Today, I’m glad to be able to share everything I learned to all of you. I apologize for some fast and uncommented commits, I just thinked that some things needed to be fixed ASAP.
See you in future commits, issues and PRs :DFixed
- A typo in
es
translation - A few typos in README.md (#134 and #149) and API/README.md (#179)
- Delayed commands should now work (#190)
- Typo on remote_action (#184)
- IP now showing (#194)
- MM restart button don’t just stop anymore (#126)
- Saving config should work as expected now (#153)
- installer.sh now detects where’s the node instalation (#222)
Added
- Danish translation (#157)
- Italian translation (#162)
- Port now showing according to config.js (#98)
- Custom commands for shutdown and reboot
Changed
- Overwrite of local changes when updating from a repository
- Now requires MagicMirror version 2.12
[2.0.1] - 2020-10-28
Huge thanks to @ezeholz who has offered to maintain the module fron now on!
Credit for this (and future) versions and releases goes to @ezeholz (unless noted otherwise).Now requires MagicMirror version 2.7.
Fixed
- Path to font awesome icons
- A few typos in
ca
andes
translations - Updates to
remote.html
to support newbasePath
feature in MMconfig.js
, follow up to this MM issue, related to #185
- A typo in
@Jopyth because I was lazy :p
[2.2.0] - 2020-11-16
FIXED
- Default values now removed from backup (#12)
- Custom Menus now works as expected
- API working, not well implemented in the past
- API
userPresence
now working as expected
ADDED
- Updates now show if there’s an update available every day (#52)
- Templates for issues and PRs, and also stale for automanagement of issues.
- Close Dev Tools (#119)
- Undo Config Implementation [Beta]
- Classes to show, hide or toggle multiple modules at once (#34)
- Classes and saves API
- Changelog of every module updated
- Showdown implemented in order to show changelog markdown.
- secureEndpoint config to bypass the non-apikey limitation. This could be dangerous, use it with caution.
- Added
POST
support for Monitor API (#200) - Added endpoint to edit config file (#206)
- Endpoint
/api/docs
now shows you the documentation available for the API. You can test your mirror right there!
CHANGED
lodash
required. Donpm install
on the Remote Control module.- Alert button don’t show up when Alert module isn’t active
- The way monitor turn on and off (#225)
- Now hide, show or toggle modules also accept arrays
/api/test
can be reach without anyapiKey
/api/modules/installed
and /available are now/api/module/installed
and/available
apiKey
required in order to change substantial things on the Mirror- Some Endpoints are gonna be deprecated in the future. You can see those inside
/api/docs
, in theLegacy
menu.
REMOVED
/api/modules
it’s no longer available, you can use/api/module
instead.- Postman collection deprecated ~ (Sorry n.n)
Hey,
I’m very new to coding and the magicmirror thing, here I’m stuck at restarting the mirror, the command pm2 restart doesn’t work, I managed to instal pm2 (I think) but it still doesn’t work “Process or namespace magicmirror not found”
It also said ealier in the module I needed an API key in my config section, where should I write it ?
Could someone help ? Thanks !
@Morganga for pm2 u can use my fixuppm2 script
@sdetweil Hey,
Thank you, managed to do it.
Now the RC website says the device isn’t allowed to acces the mirror…
Any clues ?Ok just withelisted all IP adresses and it’s all good !
Im trying to get a custom menu ready to send customized notifications via input fields.
Sadly im not into JS.
Can someone tell me how to get the value of an input field i added?my custom_menu.json:
{ "id": "custom", "type": "menu", "icon": "id-card-o", "text": "%%TRANSLATE:CUSTOM_MENU%%", "items": [{ "id": "custom-item-1", "type": "item", "icon": "dot-circle-o", "text": "Next page", "action": "NOTIFICATION", "content": { "notification": "INCREMENT_PAGE", "payload": null } }, { "id": "custom-item-2", "type": "item", "icon": "dot-circle-o", "text": "Last page", "action": "NOTIFICATION", "content": { "notification": "DECREMENT_PAGE", "payload": null } }, { "id": "level2", "type": "menu", "menu": "custom", "icon": "bars", "text": "Send notifications", "items": [ { "id": "custom-item-3", "type": "input", "icon": "dot-circle-o", "text": "Notification", "action": null, "content": null }, { "id": "custom-item-4", "type": "input", "icon": "dot-circle-o", "text": "Payload", "action": null, "content": null }, { "id": "custom-item-5", "type": "button", "icon": "dot-circle-o", "text": "Send", "action": "NOTIFICATION", "content": { "notification": null, "payload": null } } ] } ] }
The button (last entry) should now send an notification with the values from the input fields above.
something like this:{ "id": "custom-item-5", "type": "button", "icon": "dot-circle-o", "text": "Send", "action": "NOTIFICATION", "content": { "notification": "custom-item-3".value, "payload": "custom-item-4".value } }
So how can i get the value from my input items?
Thanks :)And another question. Is there a security problem when im neither using an ApiKey nor the secureEndpoints? Im using it in my private secured wifi with only me inside.
