    What is your backup and restore method?
    18 Posts 10 Posters 7.9k Views 15 Watching
      BillyTheKid9588
      My mirror configuration has taken some time to get right and i’m curious to know people’s back up and restore methods in case of system failure.
      I’ve seen some backup the whole sd, some just the config file, i see advantages and disadvantages to both of these. If the sd is backed up, maybe the module code is out of date, if just the config file, there is the potential to lose Raspbian specific settings.
      Curious to know how people approach this.
      • SnilleS Offline
        Snille Module Developer
        Hi there! Manual “backup” of the config, CSS and compliments files when I change them (just copying it to my server). Then when reinstalling, I’m using a script (that I can wget down to the new install) containing all modules to reinstall and it copy back the config, CSS and compliments from the backup location… :)
        See script below…
        #!/bin/bash
        ## Snilles automatic module clone and install script for MM2.
        ## Don't forget to add your public SSH key to your GIT profile!
        ## If you don't, nothing will be cloned!
        ## If you don't have an SSH key. This is how you get one.
        ## Generate SSH key(s).
        # cd ~
        # ssh-keygen -t rsa
        ## Press: Enter, Enter, Enter...
        ## See the public Key...
        # cat /home/pi/.ssh/id_rsa.pub
        ## Copy the SSH public key and add it to your GIT SSH keys on GitHUB.
        ## Config below.
        # System to install (what config to use).
        ## Housesystems Server Install
        Toinstall='house'
        ## NUC install (On the actual Mirror, this is not used anymore)
        #Toinstall='NUC'
        # Real Name of the config file.
        ConfigName='config.js'
        ## The Install Folder.
        ## Local install.
        ## On NUC
        #User='/home/snille'
        ## On Raspberry Pi
        #User='/home/pi'
        ## Install om Homesystems Server.
        User='/var/www/html/magicmirror'
        ## The module install directory.
        Moddir=$User'/MagicMirror/modules'
        ## Configuration and other files backup location (from previous installation).
        DownloadFrom='https://yoursite.com/mmbackup/'
        ## Configuration file.
        Files[1]='config-'$Toinstall'.js'
        ## Where to put the Configuration file.
        Dirs[1]=$User'/MagicMirror/config/'
        ## Custom CSS file.
        Files[2]='custom.css'
        ## Where to put the CSS file.
        Dirs[2]=$User'/MagicMirror/css/'
        ## Custom screen on/off scripts.
        Files[3]='screen.sh'
        ## Where to put the screen script files.
        Dirs[3]=$User'/'
        ## Not used moved to "screen.sh"
        #Files[4]='turnoffscreen.sh'
        #Dirs[4]=$User'/'
        #Files[5]='turnonscreen.sh'
        #Dirs[5]=$User'/'
        ## Custom Magic Mirror update script.
        Files[6]='update.sh'
        ## Where to put the update script file.
        Dirs[6]=$User'/'
        ## Custom compliment files.
        Files[7]='compliments-Snille.json'
        ## Where to put the compliment file.
        Dirs[7]=$User'/MagicMirror/modules/default/compliments/'
        Files[8]='compliments-Camilla.json'
        Dirs[8]=$User'/MagicMirror/modules/default/compliments/'
        Files[9]='compliments-Louise.json'
        Dirs[9]=$User'/MagicMirror/modules/default/compliments/'
        #Files[10]='compliments-Martin.json'
        #Dirs[10]=$User'/MagicMirror/modules/default/compliments/'
        # Start file for the MagigMirror
        Files[11]='MacigMirror.sh'
        Dirs[11]=$User'/'
        ## Package file
        Packfile='package.json'
        ## All the modules repos from Git.
        Repos[1]='git@github.com:Snille/MMM-HideAll.git'
        Repos[2]='git@github.com:matteodanelli/MMM-cryptocurrency.git'
        Repos[3]='git@github.com:basknol/MMM-Globe.git'
        Repos[4]='git@github.com:Snille/MMM-Modulebar.git'
        Repos[5]='git@github.com:Snille/MMM-ModuleScheduler.git'
        Repos[6]='git@github.com:CatoAntonsen/MMM-MotionEye.git'
        Repos[7]='git@github.com:Gyran/MMM-plex-recently-added.git'
        Repos[8]='git@github.com:Snille/MMM-Profilepicture.git'
        Repos[9]='git@github.com:tosti007/MMM-ProfileSwitcher.git'
        Repos[10]='git@github.com:Jopyth/MMM-Remote-Control.git'
        Repos[11]='git@github.com:Snille/MMM-Sonos.git'
        Repos[12]='git@github.com:brobergp/MMM-TextClock.git'
        Repos[13]='git@github.com:tosti007/MMM-TouchNavigation.git'
        Repos[14]='git@github.com:bugsounet/MMM-Tools.git'
        Repos[15]='git@github.com:timdows/MMM-JsonTable.git'
        Repos[16]='git@github.com:derekn/MMM-TautulliActivity.git'
        #Repos[17]='git@github.com:Snille/MMM-IFTTT.git' # For development of the IFTTT module, the one below is used.
        Repos[18]='git@github.com:jc21/MMM-IFTTT.git'
        Repos[19]='git@github.com:NolanKingdon/MMM-MoonPhase.git'
        Repos[20]='git@github.com:Snille/MMM-homeassistant-sensors.git'
        #Repos[21]='git@github.com:schnibel/MMM-Memo.git' # Replaced by module below, I changed some things.
        Repos[22]='git@github.com:Snille/MMM-Memo.git'
        Repos[23]='git@github.com:almerica/MMM-ImageFit.git'
        Repos[24]='git@github.com:Snille/MMM-Videoplayer.git'
        Repos[25]='git@github.com:MartinGris/MMM-GoogleMaps-Tracking.git'
        ## Start!
        cd "$Moddir"
        for t in "${Repos[@]}"
        	do
        		git clone $t
        		#echo "Cloning $t"
        done
        echo "Cloning Done."
        echo "Now npm installing..."
        for f in *;
        	do
        		if [[ -d $f ]]; then
        			installmodule=$(basename $f)
        			[[ $installmodule =~ ^(default|node_modules)$ ]] && continue
        			cd "$installmodule"
        			if [ -e "$Packfile" ]; then
        #				npm install --production
        				npm install
        			fi
        			cd ".."
        		fi
        	done
        echo "Download and install done."
        echo "Now restoring backup files from $DownloadFrom."
        ## Counts through the array of files (and uses the dirs to know where to put them).
        for ((i=1; i<=${#Files[@]}; i++)); do
        	if [[ $(wget $DownloadFrom${Files[i]} -O-) ]] 2>/dev/null
        	then
        		printf 'Moving %s to %s...\n\n' "${Files[i]}" "${Dirs[i]}"
        		mv ${Files[i]} ${Dirs[i]}
        	fi
        done
        ## Rename the config.
        mv ${Dirs[1]}${Files[1]} ${Dirs[1]}$ConfigName
        echo "Installation and restore done!"
        echo "You can now start your Magic Mirror."
        exit
        If you cant find it, make it and share it!
        Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
        • swvalentiS Offline
          swvalenti Project Sponsor
          @Snille Can you dumb this down a little bit for me please, trying to use this…I created key and added to github but not sure how to do the rest.
          SnilleS 1 Reply Last reply Reply Quote 0
          • karsten13K Online
            karsten13
            my approach …
            The following script must be executed in the magicmirror folder and creates another script restore.sh. This result script should be saved (on my server it is under git control) and can be executed (again in the magicmirror folder) to restore the old system (or bringing the old config to a new system).
            #!/bin/sh
            base="$(cd "$(dirname "$0")" && pwd)"
            restore="$base/restore.sh"
            config="${1:-config/config.js}"
            css="css/custom.css"
            modules="modules"
            # Tests
            [ -f "$base/$config" ] || (echo "config.js does not exists" && exit 1)
            [ -f "$base/$css" ] || (echo "custom.css does not exists" && exit 1)
            [ -d "$base/$modules" ] || (echo "modules directory does not exists" && exit 1)
            echo "#!/bin/sh" > $restore
            echo "" >> $restore
            echo "base=\"\$(cd \"\$(dirname \"\$0\")\" && pwd)\"" >> $restore
            echo "" >> $restore
            echo "mkdir -p \$base/config" >> $restore
            echo "mkdir -p \$base/css" >> $restore
            echo "mkdir -p \$base/modules" >> $restore
            echo "" >> $restore
            echo "cat > \$base/$config <<\"EOF\"" >> $restore
            cat <$base/$config >> $restore
            echo "EOF" >> $restore
            echo "" >> $restore
            echo "cat > \$base/$css <<\"EOF\"" >> $restore
            cat <$base/$css >> $restore
            echo "" >> $restore
            for dir in $(find "$modules" -maxdepth 1 -mindepth 1 -type d)
            do
              [ -f "$dir/.git/config" ] && mods="$mods $(cat $dir/.git/config | grep 'url = ' | sed 's|.*url = ||g')"
            done
            for repo in $mods
            do
              echo "cd \$base/$modules && git clone $repo" >> $restore
            done
            echo "" >> $restore
            for repo in $mods
            do
              moddir="$modules/$(echo $repo | sed -r 's|.*\/(.*)|\1|g;s|.git||g')"
              [ -f "$base/$moddir/package.json" ] && echo "cd \$base/$moddir && npm install" >> $restore
            done
            echo "Created restore script $restore"
            chmod +x $restore
              @karsten13 Looks good but same thing I am not grasping how to implement this…sorry
              • SnilleS Offline
                Snille Module Developer @swvalenti
                @swvalenti Ok… :)
                You need a “server” (a location where you can “wget” files from for this to work.
                I have a specific backup directory on my own webserver, but you can use any server as long as you can wget from it.
                Then the “Toinstall” part is just me having more the one config files in the backup dir.
                Basically I have 2 different install possibility’s “house” and “NUC”.
                So my backup config files are named “config-house.js” and config-NUC.js".
                I enable the one I want to restore.
                “ConfigName” is the actual name of the config file when it’s copied to it’s destination. This is probably always going to be “config.js” for the MM2. :)
                “User” is in what directory the “MagicMirror” is located (when you cloned it).
                “Moddir” is where your modules will be installed (this is probably always going to the same for MM2 as well).
                “DownloadFrom” is where to download your backed up files from.
                Then it’s just two "array"s with the files and folders with the backup files and where to copy them when restoring.
                Files[1] = “file1-to-copy”
                Dirs[1] = “Where/to/copy/file-1”
                And so on…
                Files[3] Is the script I use to set the screen to sleep and wake it up (Using MMM-Remote-Control).
                Files[4] Is the script I use to automatically update the mirror and the modules (manually).
                Files[7-9] It’s the “compliment-files” (used in the compliments module).
                And Files[11] Is the MagicMirror start script I use (for starting the mirror with pm2).
                “Packfile” Is the name of the file to look for when installing moduls. If it’s there, the npm install will be executed when installing the module.
                Last but not least it’s all the git-repos for the modules I use in my mirror.
                These will be cloned in the “Moddir” and installed (with npm if “Packfile” exists").
                That’s about it. :)
                Let me know if you have any more questions. :)
                • LusbuebL Offline
                  Lusbueb
                  i use this tool:
                  https://www.linux-tips-and-tricks.de/en/backup/
                  every night I make a full backup of all 4 Raspi as a TAR file to a NAS on my network. then i shrink and convert the TAR files into an IMG file (read Framps Linux-Tips-and-Tricks).
                  so I can always make a new SD card with my Win10 and Win32 Disk Imager.
                  B 1 Reply Last reply Reply Quote 2
                    @Lusbueb I have a Buffalo NAS LS I am trying to backup too but can’t figure out the right path to add to sudo nano /etc/fstab
                    LusbuebL 1 Reply Last reply Reply Quote 0
                      BillyTheKid9588 @Lusbueb
                      @Lusbueb this looks interesting.
                      Do you stop mm before the back up?
                      • bheplerB Offline
                        bhepler Module Developer
                        The only information that is unique to my mirror is the module configuration. I just back up the config.js file whenever I make a change to the mirror configuration. If the mirror needs to be rebuilt, I can quickly build a slick Buster installation, SSH into the Pi, run the installation script, drop the backup config.js to the config folder and then do a half-dozen git clone commands.
                        Once the mirror is up & running, I can do the boring maintenance stuff (apt get update && apt get upgrade) and just let it run in the background.
