    Working Weather Underground module?
    63 Posts 9 Posters 41.3k Views 9 Watching
      c1olli
      That’s a good beginning :D
      At the moment I have to install MM new, because the update failed and the system was stuck.
      I will test it when MM ist working again.
        sdetweil @c1olli
        @c1olli how did u do the update? manually or my upgrade script?
        what error did u get?
          c1olli
          I did it like it is written in the MM manual.
          git clone && npm install
          But I saved the MM folder with all my settings.
            sdetweil @c1olli
            @c1olli try my upgrade script, from here
            I think u will need to use force as a parameter, (instead of apply) unless u copy back the saved mm.
            u said it was broken… what was the prior results? black screen? won’t start?
              c1olli
              My plan was to install all modules and then copy the config.js back.
                sdetweil @c1olli
                @c1olli u can install too w my install script
                but I think my upgrade script should fix it…
                  c1olli
                  It’s too late - I’m working for it for a few hours now and I formatted the SD card, new rasbian…
                  But thanks for help.
                    sdetweil @c1olli
                    @c1olli yeh, I don’t install raspian
                      c1olli
                      eeeeh - that was before you told me about the new way. :(
                        sdetweil @c1olli
                        @c1olli sorry!
                          c1olli
                          no problem the way is a little bit longer, but I will go to finish it.
                          For the next time I know the new way - hopefully I will not forget it :D
                            chanster @Saabman
                            @Saabman Thank you for doing this! When I tried out your version of the module, my MM loads with a blank screen. Actually I ran into this same problem when I tried to modify the modules myself a couple of days ago using the new API documentation that you found.
                            When I manually try using the API via the URL, it seems to return data (I’ve *** some data for privacy) ie
                            {"observations":[{"stationID":"***","obsTimeUtc":"2021-01-03T18:43:34Z","obsTimeLocal":"2021-01-03 10:43:34","neighborhood":"***","softwareType":null,"country":"US","solarRadiation":252.0,"lon":-121.763,"realtimeFrequency":null,"epoch":1609699414,"lat":37.32,"uv":0.7,"winddir":22,"humidity":85,"qcStatus":1,"metric":{"temp":12,"heatIndex":12,"dewpt":9,"windChill":12,"windSpeed":0,"windGust":3,"pressure":1024.38,"precipRate":0.00,"precipTotal":0.00,"elev":150}}]}
                            I cannot see anything in the logs that is helpful :(
                            [2021-01-03 10:39:25.741] [LOG]    Module helper loaded: MMM-WunderGround
                            [2021-01-03 10:39:27.778] [LOG]    Connecting socket for: MMM-WunderGround
                            [2021-01-03 10:39:27.779] [LOG]    MMM-WunderGround helper started ...
                            [2021-01-03 10:39:27.829] [LOG]    Sockets connected & modules started ...
                              sdetweil @chanster
                              @chanster look in the developers window, ctrl-shift-i, select the console tab and scroll up. u can filter messages by module, by putting part of the module name in the filter field, weath here
                              if the data changed format, then the old code won’t work
                              C 2 Replies Last reply Reply Quote 0
                                chanster @sdetweil
                                @sdetweil Thanks !
                                I realized what the issue is but I don’t know why it’s happening. I was trying to git clone @Saabman 's fork but it keeps cloning the original MMM-WunderGround for some reason. I’ll manually download @Saabman 's version and try again.
                                  chanster @sdetweil
                                  @sdetweil @Saabman
                                  I’m pretty I’m running @Saabman 's fork now but I’m still running into a blank screen when MM loads. Here’s what I can see in the console :
                                  Load script: modules/MMM-WunderGround//MMM-WunderGround.js
                                  module.js:513 Module registered: MMM-WunderGround
                                  loader.js:148 Bootstrapping module: MMM-WunderGround
                                  loader.js:236 File already loaded: moment.js
                                  loader.js:153 Scripts loaded for: MMM-WunderGround
                                  loader.js:236 File already loaded: weather-icons.css
                                  loader.js:195 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons-wind.css
                                  loader.js:195 Load stylesheet: modules/MMM-WunderGround/MMM-WunderGround.css
                                  loader.js:155 Styles loaded for: MMM-WunderGround
                                  translator.js:102 MMM-WunderGround - Load translation fallback: translations/en.json
                                  localhost/:2 Uncaught SyntaxError: Unexpected token / in JSON at position 4
                                      at JSON.parse (<anonymous>)
                                      at XMLHttpRequest.xhr.onreadystatechange (translator.js:22)
                                    sdetweil @chanster
                                    @chanster edit the module
                                    and remove the comments
                                    or
                                    comments not allowed in json
                                    C S 2 Replies Last reply Reply Quote 0
                                      chanster @sdetweil
                                      @sdetweil Thanks ! That did the trick!
                                        Saabman Project Sponsor @sdetweil
                                        @sdetweil Thanks for that I had seen the error but it didnt stop the application from running for me so didn’t look further into it.
                                        @chanster I had forked the orignal version and then only modified the Develop branch.
                                        If you just do a git clone you will get the Master branch not the develop branch - Im only learning my way around Github -so I might be doing something wrong as well. But from what I can work out if you use the following command it should get the the develop branch
                                        git clone --single-branch --branch Develop https://github.com/saabman/MMM-WunderGround.git
                                          sdetweil @Saabman
                                          @Saabman see the topic at the top.of troubleshooting about test fixes and develop.
                                          gives instructions
                                            @sdetweil Thanks Ill look into it.
                                            Just got the module pulling the forecast info into it - only displays it in the console at the moment but its getting there
                                            • 2 / 4
