    Working Weather Underground module?
    63 Posts 9 Posters 42.2k Views 9 Watching
      c1olli
      My plan was to install all modules and then copy the config.js back.
        sdetweil @c1olli
        @c1olli u can install too w my install script
        but I think my upgrade script should fix it…
          c1olli
          It’s too late - I’m working for it for a few hours now and I formatted the SD card, new rasbian…
          But thanks for help.
            sdetweil @c1olli
            @c1olli yeh, I don’t install raspian
              c1olli
              eeeeh - that was before you told me about the new way. :(
                sdetweil @c1olli
                @c1olli sorry!
                  c1olli
                  no problem the way is a little bit longer, but I will go to finish it.
                  For the next time I know the new way - hopefully I will not forget it :D
                    chanster @Saabman
                    @Saabman Thank you for doing this! When I tried out your version of the module, my MM loads with a blank screen. Actually I ran into this same problem when I tried to modify the modules myself a couple of days ago using the new API documentation that you found.
                    When I manually try using the API via the URL, it seems to return data (I’ve *** some data for privacy) ie
                    {"observations":[{"stationID":"***","obsTimeUtc":"2021-01-03T18:43:34Z","obsTimeLocal":"2021-01-03 10:43:34","neighborhood":"***","softwareType":null,"country":"US","solarRadiation":252.0,"lon":-121.763,"realtimeFrequency":null,"epoch":1609699414,"lat":37.32,"uv":0.7,"winddir":22,"humidity":85,"qcStatus":1,"metric":{"temp":12,"heatIndex":12,"dewpt":9,"windChill":12,"windSpeed":0,"windGust":3,"pressure":1024.38,"precipRate":0.00,"precipTotal":0.00,"elev":150}}]}
                    I cannot see anything in the logs that is helpful :(
                    [2021-01-03 10:39:25.741] [LOG]    Module helper loaded: MMM-WunderGround
                    [2021-01-03 10:39:27.778] [LOG]    Connecting socket for: MMM-WunderGround
                    [2021-01-03 10:39:27.779] [LOG]    MMM-WunderGround helper started ...
                    [2021-01-03 10:39:27.829] [LOG]    Sockets connected & modules started ...
                      sdetweil @chanster
                      @chanster look in the developers window, ctrl-shift-i, select the console tab and scroll up. u can filter messages by module, by putting part of the module name in the filter field, weath here
                      if the data changed format, then the old code won’t work
                      C 2 Replies Last reply
                        chanster @sdetweil
                        @sdetweil Thanks !
                        I realized what the issue is but I don’t know why it’s happening. I was trying to git clone @Saabman 's fork but it keeps cloning the original MMM-WunderGround for some reason. I’ll manually download @Saabman 's version and try again.
                          chanster @sdetweil
                          @sdetweil @Saabman
                          I’m pretty I’m running @Saabman 's fork now but I’m still running into a blank screen when MM loads. Here’s what I can see in the console :
                          Load script: modules/MMM-WunderGround//MMM-WunderGround.js
                          module.js:513 Module registered: MMM-WunderGround
                          loader.js:148 Bootstrapping module: MMM-WunderGround
                          loader.js:236 File already loaded: moment.js
                          loader.js:153 Scripts loaded for: MMM-WunderGround
                          loader.js:236 File already loaded: weather-icons.css
                          loader.js:195 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons-wind.css
                          loader.js:195 Load stylesheet: modules/MMM-WunderGround/MMM-WunderGround.css
                          loader.js:155 Styles loaded for: MMM-WunderGround
                          translator.js:102 MMM-WunderGround - Load translation fallback: translations/en.json
                          localhost/:2 Uncaught SyntaxError: Unexpected token / in JSON at position 4
                              at JSON.parse (<anonymous>)
                              at XMLHttpRequest.xhr.onreadystatechange (translator.js:22)
                            sdetweil @chanster
                            @chanster edit the module
                            and remove the comments
                            or
                            comments not allowed in json
                            C S 2 Replies Last reply
                              chanster @sdetweil
                              @sdetweil Thanks ! That did the trick!
                                Saabman Project Sponsor @sdetweil
                                @sdetweil Thanks for that I had seen the error but it didnt stop the application from running for me so didn’t look further into it.
                                @chanster I had forked the orignal version and then only modified the Develop branch.
                                If you just do a git clone you will get the Master branch not the develop branch - Im only learning my way around Github -so I might be doing something wrong as well. But from what I can work out if you use the following command it should get the the develop branch
                                git clone --single-branch --branch Develop https://github.com/saabman/MMM-WunderGround.git
                                  sdetweil @Saabman
                                  @Saabman see the topic at the top.of troubleshooting about test fixes and develop.
                                  gives instructions
                                    @sdetweil Thanks Ill look into it.
                                    Just got the module pulling the forecast info into it - only displays it in the console at the moment but its getting there
                                      sdetweil @Saabman
                                      @Saabman funny, one has to READ the message to reply properly…
                                      git clone should get all branches, unless u specifically ask for depth=??1
                                      u can get another branch with git fetch remotename remotebranch_name: localbranch_name
                                      then git checkout localbranch_name should work
                                        c1olli
                                        After the new installation of MM, I installed the module and I can see some weather data from my wether station - really good beginning.
                                        @sdetweil Thanks for the fantastic installation script.
                                          maxs
                                          Nice that some people are working on it. I want also my pws in the mirror, and willing to help, but im not able to program. But can test if necessary. I tried the module so far , and yes there are some signs of live in the module. Thanks already.
                                            Ive been spending some time working out how to use github a bit better. Thanks for the tips sdetweil.
                                            So havent progressed any further on the module.
                                            What I have noticed is the original module MMM-Wunderground has quiet a lot in it - been able to choose different icons/color moon phase etc. which is not stuff that your PWS will provide. So thinking of doing a cut down version that just provides current weather data as provided by your PWS.
                                            C 1 Reply Last reply
                                            • 2 / 4
