    Working Weather Underground module?
    63 Posts 9 Posters 38.9k Views 9 Watching
      sdetweil @chanster
      @chanster look in the developers window, ctrl-shift-i, select the console tab and scroll up. u can filter messages by module, by putting part of the module name in the filter field, weath here
      if the data changed format, then the old code won’t work
      C 2 Replies Last reply Reply Quote 0
        chanster @sdetweil
        @sdetweil Thanks !
        I realized what the issue is but I don’t know why it’s happening. I was trying to git clone @Saabman 's fork but it keeps cloning the original MMM-WunderGround for some reason. I’ll manually download @Saabman 's version and try again.
          chanster @sdetweil
          @sdetweil @Saabman
          I’m pretty I’m running @Saabman 's fork now but I’m still running into a blank screen when MM loads. Here’s what I can see in the console :
          Load script: modules/MMM-WunderGround//MMM-WunderGround.js
          module.js:513 Module registered: MMM-WunderGround
          loader.js:148 Bootstrapping module: MMM-WunderGround
          loader.js:236 File already loaded: moment.js
          loader.js:153 Scripts loaded for: MMM-WunderGround
          loader.js:236 File already loaded: weather-icons.css
          loader.js:195 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons-wind.css
          loader.js:195 Load stylesheet: modules/MMM-WunderGround/MMM-WunderGround.css
          loader.js:155 Styles loaded for: MMM-WunderGround
          translator.js:102 MMM-WunderGround - Load translation fallback: translations/en.json
          localhost/:2 Uncaught SyntaxError: Unexpected token / in JSON at position 4
              at JSON.parse (<anonymous>)
              at XMLHttpRequest.xhr.onreadystatechange (translator.js:22)
            sdetweil @chanster
            @chanster edit the module
            and remove the comments
            or
            comments not allowed in json
            C S 2 Replies Last reply Reply Quote 0
              chanster @sdetweil
              @sdetweil Thanks ! That did the trick!
                Saabman Project Sponsor @sdetweil
                @sdetweil Thanks for that I had seen the error but it didnt stop the application from running for me so didn’t look further into it.
                @chanster I had forked the orignal version and then only modified the Develop branch.
                If you just do a git clone you will get the Master branch not the develop branch - Im only learning my way around Github -so I might be doing something wrong as well. But from what I can work out if you use the following command it should get the the develop branch
                git clone --single-branch --branch Develop https://github.com/saabman/MMM-WunderGround.git
                  sdetweil @Saabman
                  @Saabman see the topic at the top.of troubleshooting about test fixes and develop.
                  gives instructions
                    @sdetweil Thanks Ill look into it.
                    Just got the module pulling the forecast info into it - only displays it in the console at the moment but its getting there
                      sdetweil @Saabman
                      @Saabman funny, one has to READ the message to reply properly…
                      git clone should get all branches, unless u specifically ask for depth=??1
                      u can get another branch with git fetch remotename remotebranch_name: localbranch_name
                      then git checkout localbranch_name should work
                        c1olli
                        After the new installation of MM, I installed the module and I can see some weather data from my wether station - really good beginning.
                        @sdetweil Thanks for the fantastic installation script.
                          maxs
                          Nice that some people are working on it. I want also my pws in the mirror, and willing to help, but im not able to program. But can test if necessary. I tried the module so far , and yes there are some signs of live in the module. Thanks already.
                            Ive been spending some time working out how to use github a bit better. Thanks for the tips sdetweil.
                            So havent progressed any further on the module.
                            What I have noticed is the original module MMM-Wunderground has quiet a lot in it - been able to choose different icons/color moon phase etc. which is not stuff that your PWS will provide. So thinking of doing a cut down version that just provides current weather data as provided by your PWS.
                              chanster @Saabman
                              @Saabman Thanks again for all the work you have put into updating this module. Have you checked out MMM-Currentweather-MQTT ? I got it to work with my PWS. It takes an interesting approach of blending in data from PWS where available and supplements it with data from OpenWeather. It does require your PWS to publish its data via MQTT.
                                Saabman Project Sponsor @chanster
                                @chanster I Wasnt aware of that one, That would definantly be another way to go and not rely on an external API that will probably change :lol:
                                My Weather station is about 20years old and I use a Raspberry pi runnig WEEWX to get the data of it and onto WunderGround and I just had a look and found a MQTT “plugin” for WEEWX so it would be simple enough to do. I already USE MQTT for energy Monitoring so Im half way there.
                                Thanks for that
                                  chanster @Saabman
                                  @Saabman That’s great! Once I got my MQTT feed up, this module worked very well to display the data from my PWS.
                                    c1olli
                                    I tried out the MMM-ioBroker and this works properly.
                                    IoBroker gets the Data directly from my WH4000ws Weatherstation with the module WLAN-Wetterstation from SBorg2014.
                                    Next Step ist to install MagicMirror and ioBroker on one Raspberry Pi.
                                      Saabman Project Sponsor @c1olli
                                      @c1olli Thats good to know there are some options.
                                      Im thinking doing something along the lines of pulling Data from one of those “offline” systems and seeing if it is possible to integrate it into the new MagicMirror weather module.
                                      The last couple of days Ive been re writing and simplifying the Wunderground module to just display the current PWS data pulled from WunderGround. more as an exercise in trying to understand NodeJS and gitHub.
                                      my head is just about exploding :lol: but its getting there. I am not a programer by any stretch of the imagination. Im just sitting down looking at the code and try and work it out.
                                      to start with I pick something obvious like Temperature and just look through the code and find where it appears and then try and work out where it comes from and where it goes.
                                        c1olli
                                        It would be nice to have a better looking solution, combinated witch the “offline” data.
                                        I can understand, that your head ist exploding, for me is it the same - if you are a little bit older and you can’t program than it is not easy (for me) to learn such things.
                                        I’m happy when I can change little things and combinate such things that they are working for me.
                                        The ioBroker module for catching the data from the weatherstation is here (in german): WLAN-Wetterstation
                                          @c1olli said in Working Weather Underground module?:
                                          thanks for that, in German explains why I couldn’t find it.
                                          Ive been working on the module just to display the weather station data with no forecast getting the data to display is no problem - getting it to display nicely is another story all together.
                                          So im working through trying to understand how the HTML works and Style sheets etc.
                                          I would encourage anyone to take some time to sit down and have a go at modifying a module. Its not easy when you first look at it but parts of it do start to make sense after a while.
                                            Saabman Project Sponsor @Saabman
                                            OK I think I have got something worth having a look its basic but its there at least.
                                            Ive got some ideas on further customisation ie changeing sizes of the parameters etc. but ill add those as I go.
                                            https://github.com/saabman/MMM-WunderGround-PWS-Observations
                                            ![alt text](Screen Shot 2021-01-17 at 22.32.06.png image url)
                                            • 3 / 4
