    Working Weather Underground module?
    63 Posts 9 Posters 42.2k Views 9 Watching
      sdetweil @c1olli
      @c1olli sorry!
        c1olli
        no problem the way is a little bit longer, but I will go to finish it.
        For the next time I know the new way - hopefully I will not forget it :D
          chanster @Saabman
          @Saabman Thank you for doing this! When I tried out your version of the module, my MM loads with a blank screen. Actually I ran into this same problem when I tried to modify the modules myself a couple of days ago using the new API documentation that you found.
          When I manually try using the API via the URL, it seems to return data (I’ve *** some data for privacy) ie
          {"observations":[{"stationID":"***","obsTimeUtc":"2021-01-03T18:43:34Z","obsTimeLocal":"2021-01-03 10:43:34","neighborhood":"***","softwareType":null,"country":"US","solarRadiation":252.0,"lon":-121.763,"realtimeFrequency":null,"epoch":1609699414,"lat":37.32,"uv":0.7,"winddir":22,"humidity":85,"qcStatus":1,"metric":{"temp":12,"heatIndex":12,"dewpt":9,"windChill":12,"windSpeed":0,"windGust":3,"pressure":1024.38,"precipRate":0.00,"precipTotal":0.00,"elev":150}}]}
          I cannot see anything in the logs that is helpful :(
          [2021-01-03 10:39:25.741] [LOG]    Module helper loaded: MMM-WunderGround
          [2021-01-03 10:39:27.778] [LOG]    Connecting socket for: MMM-WunderGround
          [2021-01-03 10:39:27.779] [LOG]    MMM-WunderGround helper started ...
          [2021-01-03 10:39:27.829] [LOG]    Sockets connected & modules started ...
            sdetweil @chanster
            @chanster look in the developers window, ctrl-shift-i, select the console tab and scroll up. u can filter messages by module, by putting part of the module name in the filter field, weath here
            if the data changed format, then the old code won’t work
            C 2 Replies Last reply
              chanster @sdetweil
              @sdetweil Thanks !
              I realized what the issue is but I don’t know why it’s happening. I was trying to git clone @Saabman 's fork but it keeps cloning the original MMM-WunderGround for some reason. I’ll manually download @Saabman 's version and try again.
                chanster @sdetweil
                @sdetweil @Saabman
                I’m pretty I’m running @Saabman 's fork now but I’m still running into a blank screen when MM loads. Here’s what I can see in the console :
                Load script: modules/MMM-WunderGround//MMM-WunderGround.js
                module.js:513 Module registered: MMM-WunderGround
                loader.js:148 Bootstrapping module: MMM-WunderGround
                loader.js:236 File already loaded: moment.js
                loader.js:153 Scripts loaded for: MMM-WunderGround
                loader.js:236 File already loaded: weather-icons.css
                loader.js:195 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons-wind.css
                loader.js:195 Load stylesheet: modules/MMM-WunderGround/MMM-WunderGround.css
                loader.js:155 Styles loaded for: MMM-WunderGround
                translator.js:102 MMM-WunderGround - Load translation fallback: translations/en.json
                localhost/:2 Uncaught SyntaxError: Unexpected token / in JSON at position 4
                    at JSON.parse (<anonymous>)
                    at XMLHttpRequest.xhr.onreadystatechange (translator.js:22)
                  sdetweil @chanster
                  @chanster edit the module
                  and remove the comments
                  or
                  comments not allowed in json
                  C S 2 Replies Last reply
                    chanster @sdetweil
                    @sdetweil Thanks ! That did the trick!
                      Saabman Project Sponsor @sdetweil
                      @sdetweil Thanks for that I had seen the error but it didnt stop the application from running for me so didn’t look further into it.
                      @chanster I had forked the orignal version and then only modified the Develop branch.
                      If you just do a git clone you will get the Master branch not the develop branch - Im only learning my way around Github -so I might be doing something wrong as well. But from what I can work out if you use the following command it should get the the develop branch
                      git clone --single-branch --branch Develop https://github.com/saabman/MMM-WunderGround.git
                        sdetweil @Saabman
                        @Saabman see the topic at the top.of troubleshooting about test fixes and develop.
                        gives instructions
                          @sdetweil Thanks Ill look into it.
                          Just got the module pulling the forecast info into it - only displays it in the console at the moment but its getting there
                            sdetweil @Saabman
                            @Saabman funny, one has to READ the message to reply properly…
                            git clone should get all branches, unless u specifically ask for depth=??1
                            u can get another branch with git fetch remotename remotebranch_name: localbranch_name
                            then git checkout localbranch_name should work
                              c1olli
                              After the new installation of MM, I installed the module and I can see some weather data from my wether station - really good beginning.
                              @sdetweil Thanks for the fantastic installation script.
                                maxs
                                Nice that some people are working on it. I want also my pws in the mirror, and willing to help, but im not able to program. But can test if necessary. I tried the module so far , and yes there are some signs of live in the module. Thanks already.
                                  Ive been spending some time working out how to use github a bit better. Thanks for the tips sdetweil.
                                  So havent progressed any further on the module.
                                  What I have noticed is the original module MMM-Wunderground has quiet a lot in it - been able to choose different icons/color moon phase etc. which is not stuff that your PWS will provide. So thinking of doing a cut down version that just provides current weather data as provided by your PWS.
                                  C 1 Reply Last reply
                                    chanster @Saabman
                                    @Saabman Thanks again for all the work you have put into updating this module. Have you checked out MMM-Currentweather-MQTT ? I got it to work with my PWS. It takes an interesting approach of blending in data from PWS where available and supplements it with data from OpenWeather. It does require your PWS to publish its data via MQTT.
                                      Saabman Project Sponsor @chanster
                                      @chanster I Wasnt aware of that one, That would definantly be another way to go and not rely on an external API that will probably change :lol:
                                      My Weather station is about 20years old and I use a Raspberry pi runnig WEEWX to get the data of it and onto WunderGround and I just had a look and found a MQTT “plugin” for WEEWX so it would be simple enough to do. I already USE MQTT for energy Monitoring so Im half way there.
                                      Thanks for that
                                        chanster @Saabman
                                        @Saabman That’s great! Once I got my MQTT feed up, this module worked very well to display the data from my PWS.
                                          c1olli
                                          I tried out the MMM-ioBroker and this works properly.
                                          IoBroker gets the Data directly from my WH4000ws Weatherstation with the module WLAN-Wetterstation from SBorg2014.
                                          Next Step ist to install MagicMirror and ioBroker on one Raspberry Pi.
                                            Saabman Project Sponsor @c1olli
                                            @c1olli Thats good to know there are some options.
                                            Im thinking doing something along the lines of pulling Data from one of those “offline” systems and seeing if it is possible to integrate it into the new MagicMirror weather module.
                                            The last couple of days Ive been re writing and simplifying the Wunderground module to just display the current PWS data pulled from WunderGround. more as an exercise in trying to understand NodeJS and gitHub.
                                            my head is just about exploding :lol: but its getting there. I am not a programer by any stretch of the imagination. Im just sitting down looking at the code and try and work it out.
                                            to start with I pick something obvious like Temperature and just look through the code and find where it appears and then try and work out where it comes from and where it goes.
                                            • 2 / 4
