    MMM-CalendarExt2
    486 Posts 83 Posters 1.1m Views 83 Watching
    • BKeyportB Offline
      BKeyport Module Developer @rmcelwee
      @rmcelwee
      .CX2 .[view_mode] .eventTitle {
        text-align:center;
      eg:
       .CX2 .daily .eventTitle {
        text-align:center;
        rmcelwee @BKeyport
        @BKeyport said in MMM-CalendarExt2:
          text-align:center;
        This is not working for me for some reason???
        .CX2 .week .eventTitle {
        text-align:center;
        • BKeyportB Offline
          @rmcelwee Looks like that’s the only one that isn’t assigned a class for CSS, I can’t find anything in the defaults that’ll do what you want.
          Sorry.
            DJ6sTep
            I’m a noob to this MM/java stuff, so please be patience with me. I just need help with a few things:
            • How do I move the position of my calendar so it’s above my WIFI-PASSWORD module?
            • How do I remove the weekly count on the left side of the calendar (ie- 1st week, 2nd week, etc)?
            • Is there any way I could make the calendar size smaller? So it doesn’t take up the whole screen?
            • Why did the calendar move my garbage & recycling icons to the far right, covering the temperature?
            Really appreciate the help & this module is so sick!!
            BKeyportB R 2 Replies Last reply Reply Quote 0
            • BKeyportB Offline
              BKeyport Module Developer @DJ6sTep
              @DJ6sTep said in MMM-CalendarExt2:
              normally, the order of things coming up is determined by the order in config.js - however, in this case, the module is using a fake container, so it’ll load AFTER everything else. It’s best to use it’s own region for it.
              see: https://forum.magicmirror.builders/topic/286/regions?_=1610316572966
              Take a look at https://github.com/MMM-CalendarExt2/MMM-CalendarExt2/blob/master/docs/Configuration/Views/week%2C-month.md
              in particular weeksFormat
              Yep. Change your view and/or region.
              • Why did the calendar move my garbage & recycling icons to the far right?
              The calendar wedges itself into a region, and expands the region to fit. the icons must be right justified.
              Be aware that the author of the module has left the project, and nobody has picked it up, so we’re just helping from what we know.
              Good luck.
                DJ6sTep @BKeyport
                @BKeyport I was able to get my calendar in the position I want now. Thanks so much for all the great info man.
                Still having these issues:
                • What parameter do I use for weeksFormat? I tried using false & disabled & it still didn’t remove the weekly count on the left. I couldn’t find any of the parameter options in the link you posted.
                • I’m having issues finding info on how to resize my calendar & how to resize the font size of events inside a date.
                I really appreciate the support & your quick response to my questions man.
                • BKeyportB Offline
                  @DJ6sTep
                  Try
                  weeksFormat: "",
                  in the view section of your config. Effectively, that tells it to display nothing.
                  That sounds like css, and honestly, even though I’ve written a module, I’m lost when it comes to css, someone else should see this and help, hopefully.
                    rmcelwee @rmcelwee
                    @rmcelwee said in MMM-CalendarExt2:
                    My calendar flashes every 60 seconds but as far as I can tell, I have all my calendars updating every 180 seconds.
                    			  module: 'MMM-CalendarExt2',
                    				calendars : [
                    				    className: "vacation",
                    					scanInterval: "1000*180",
                    					url: "https://calendar.google.com/calendar/ical/...",
                    I forgot to post what fixed this for me. I added (without quotes):
                    " updateInterval: 1000*600, "
                    in between config: { and calendars : [ at the top. scanInterval does something completely different but I don’t know what. Now my calendar only updates every 10 minutes. Hopefully this will help someone. Thanks!
                      rmcelwee @DJ6sTep
                      I am still learning this but I put this in my custom.css to get rid of the week count:
                      .CX2 .weeksmark {
                      display:none;
                        rmcelwee @DJ6sTep
                        I had a ton of trouble with the sizing on my modules and basically fixed them via trial and error. Go to your config.js and add this to your views config (play with your px number and you will see):
                        slotMaxHeight: “105px”,
                        I think I also messed with this as well (in the same section):
                        slotCount: 8,
                        Good luck! Glad to see another newbie in here. Makes me feel a little better with the two month struggle I went through to get my mirror looking right!
                          DJ6sTep @rmcelwee
                          slotCount: 8,
                          Appreciate the tips man, adding that weekformat line in the custom.css file did the trick.
                          Sorry man, I have a few more questions if you know :)
                          • How do I change the font size & the size of that background color that’s behind all my events? I find the default font size is too big. And I could probably fit more event slots in each day, if it was smaller font.
                          • How to update the calendar so it just shows the days of that month? Instead of it showing the previous days of the month before, because it’s on the last week as the new month. Same with it showing the days of the next month in the last week of the current month. Hopefully that makes sense. lol
                          Thanks for all the encouragement man & us newbies gotta help each other out. I’m on week 4 of this & I’m starting to see the finish line :)
                            DJ6sTep
                            I almost have my calendar how I want it to be, how would I move my calendar just a few inches down from it’s current position? Closer to my WIFI password module.
                            I’ve attached a pic of what I’m talking about & highlighted in RED the empty space I want to lower my calendar to.
                            Do I have to exit the custom.css with something like this? I could be way off on this one. lol.
                            .cx2 {
                            width: 800px;
                              rmcelwee @DJ6sTep
                              I did this in the custom.css to move my photos around (note the negative numbers):
                              .MMM-GooglePhotos {
                              margin-top: -300px;
                              margin-left: -123;
                              #GPHOTO_INFO {
                              display:none;
                                DJ6sTep @rmcelwee
                                @rmcelwee That worked & it moved my calendar down, where I wanted it to be. Thanks so much for the pro tip man!
                                  rmcelwee @DJ6sTep
                                  @DJ6sTep It took me DAYS of trial and error to get everything where I wanted it. I still have a weird problem where my weather forecast window changes size from time to time. Not sure why. I don’t have a picture of it but my upper left window will shrink and leave a thick black line between the picture and the weather.
                                    DJ6sTep @rmcelwee
                                    @rmcelwee I had that problem when I used MMM-JAST module (stock ticker) & it made my current weather module disappear. I ended up contacting the developer of that module & he made updates to it to resolve my issue. It could be the wallpaper module you’re using. Which wallpaper module are you using? I’m using MMM-Wallpaper & I’m having issues of it displaying my pictures in the correct orientation. I’ve contacted the developer on that one as well. So I might try the same wallpaper module you’re using.
                                    BTW- Your MM looks dope man!
                                    D R 2 Replies Last reply Reply Quote 0
                                      DJ6sTep @DJ6sTep
                                      @rmcelwee I can’t change the background of my events. Say I want to have all my “bday events” a certain color. I tried to add that to my custom.css, I’ve tried the following:
                                      .CX2 .bday, .bday.event.fullday {
                                      background-color: #00FFFF;
                                      .CX2 .bday {
                                      Nothing works :( What am I missing?
                                        rmcelwee @DJ6sTep
                                        No wallpaper, only google photos. Thanks!
                                          rmcelwee @DJ6sTep
                                          .CX2 .vacation.fullday {
                                          background-color:#00FF00;
                                          color:#000;
                                          .CX2 .nights.fullday {
                                          background-color:#009DFF;
                                          color:#000;
                                          .CX2 .days.fullday {
                                          background-color:#FFFF00;
                                          color:#000;
                                          BTW, here is what the weather forecast does (note that it is smaller on the bottom than in my other picture). I have changed nothing…20210120_180824.jpg
                                            DJ6sTep @rmcelwee
                                            @rmcelwee So would I just change,
                                            .CX2 .vacation.fullday -> .CX2 .bday.fullday in my case?
                                            What was the module you added after your weather forecast size changed? I had a similar issue just after I added my stock ticker module & contacted the developer. So that might be an option too.
                                            Do you have a module that prevents burn ins on your screen? I run MMM-MagicMover on mine, to prevent screen burn in. With MMM-MagicMover it does move my modules around ever so slightly, where my modules won’t be spaced out perfectly. But it’s not very noticeable.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 24
                                            • 25
                                            • 19 / 25
