    MMM-SoccerLiveScore
    187 Posts 37 Posters 339.4k Views 35 Watching
      dawookie1979 @Feedy88
      @Feedy88 hello, i have the files and npm installed them into the module directory, but the module isnt showing up? i have it in the config file too :)
      • Feedy88F
        Feedy88
        @dawookie1979 mh, just tried again and it works for me (takes some time to load though, maybe limit it to one league for now). Nonetheless, I removed it again and moved on with MMM-soccer as this module has the same features and more and is still being maintained by the original creator.
        Nonetheless, if you want tot get MMM-SoccerLiveScore running, can you post your config? I just copied the sample and it works fine.
        D 1 Reply Last reply
          dawookie1979
          hello, i will remove soccerlivescore, and try MMM-soccer. Thank you for your help
            dave_ @Feedy88
            @Feedy88 hey i was wondering if u could help me setup MMM-soccer I’m having a really hard time figuring it out plzzz
            Feedy88F 1 Reply Last reply
            • Feedy88F
              Feedy88 @dave_
              @dave_ Hey there,
              would be happy to help. What is your issue currently? Also would help to post a snippet of the config you are using.+
              • 0m4r0
                0m4r Module Developer
                I have forked the repository and fixed a few bugs as I noticed it is not maintained for 4 years. I have now reduced the numbers of API calls needed to fetch the team logos (that are now directly obtained by the HTML code) and reduced the number of API calls to fetch the table and the scores.
                The table APIs does not include a “refresh” time (as they maybe did return times ago) and this causes an infinite number of call to it.
                The forked repo is here: https://github.com/0m4r/MMM-SoccerLiveScore
                I have not made a PR as I d believe the original one is abandoned.
                E 1 Reply Last reply
                • E
                  Egnos @0m4r
                  @0m4r thank you for solving the problems of this module.
                  I have only one problem: I don’t see the Juventus football team logo (it’s my favorite team … what luck!😔)
                  As you can see in the following photo:
                  alt text
                  How can i solve?
                  Many thanks.
                  0m4r0 1 Reply Last reply
                  • 0m4r0
                    Juventus logo is black with a transparent background, so it is black on black and you will not be able to see it! :) I spent some time thinking it did not work… but then I realized the black on black problem :)
                    • E
                      Egnos @0m4r
                      @0m4r I’m not sure both a problem of color, otherwise I would still see a logo of the logo or in part. As you can see in the picture in detail the pixels do not show any change …
                      alt text
                      • 0m4r0
                        yes, I guess it is correct, black is rendered on screen by non turning on the pixel of the screen, why should they if they are supposed to be all black?
                        this is the link t the image for the logo of Juventus:
                        https://www.toralarm.com/api/proxy/images/ta/images/teams/30000991/64
                        this is how it would look on a non-black background.
                        • Feedy88F
                          Feedy88
                          @0m4r much appreciated.
                          I would like to make a feature request if I may.
                          • Give the option to put the focus on a team any only show results from this team
                          Cheers,
                          Feedy
                          • 0m4r0
                            0m4r Module Developer @Feedy88
                            @Feedy88 would you be so kind to add a feature request to the github repo: https://github.com/0m4r/MMM-SoccerLiveScore/issues? thanks!
                            • lavolp3L
                              lavolp3 Module Developer
                              @0m4r
                              Do you know if the api provides the goals in any game as well?
                              And is German 2nd League and/or DFB cup integrated? (EDIT ok seen it in your README)
                              Are real-time live results availabe?
                              I’ve put quite a lot of work into the MMM-soccer module but all of these are missing in the API.
                              MMM-soccer also contains the focus feature fyi.
                              How to troubleshoot modules
                              MMM-soccer v2, MMM-AVStock
                              • 0m4r0
                                0m4r Module Developer @lavolp3
                                @lavolp3 I am actually reverse-engineering the APIs as there is no formal documentation.
                                Anyhow,
                                Do you know if the API provides the goals in any game as well?
                                yes, the score is provided.
                                If the game is ended it provides the final result, if the game is on-going you get the current score, if the game is not started it provides a default “0 - 0” result.
                                the list of supported league are the same you can see on the toralarm.de website
                                yes, it is available. The APIs also return a suggested time to refresh to get up to date results.
                                lavolp3L 1 Reply Last reply
                                • lavolp3L
                                  lavolp3 Module Developer @0m4r
                                  @0m4r said in MMM-SoccerLiveScore:
                                  Thanks but i meant the information about the goals: minutes, scorers
                                  • 0m4r0
                                    @lavolp3 I think with some more work it can be done…
                                    I am also considering to add the scorers standings for each league
                                    It is quite a hard work to reverse engineer the APIs, but it is fun :D
                                    • lavolp3L
                                      @0m4r Well I don’t know anything about reverse engineering so appreciate if you find anything.
                                      • E
                                        Egnos @lavolp3
                                        Hi guys,
                                        for a couple of days I have not seen the results of Serie A (Italy) and Champions League.
                                        Is it just me who has this problem?
                                        Thank you.
                                        • 0m4r0
                                          0m4r Module Developer @Egnos
                                          @egnos I can still see them, but I have installed my own fork which I tweaked and fixed in some places: https://github.com/0m4r/MMM-SoccerLiveScore
                                          If you are familiar with github you can even try some of the new features I am working on by checking out the developer branch :)
                                          • E
                                            Egnos @0m4r
                                            @0m4r thanks for answering me.
                                            Now it works without my intervention!
                                            Where can I find the news you are working on?
                                            0m4r0 S 2 Replies Last reply
                                            • 10
                                            • 5 / 10
