    MMM-google assistant black screen.
    12 Posts 3 Posters 3.6k Views 4 Watching
      Mathieu
      Hello, I would like to use the google assistant on my Magic Mirror. I installed the module, logged in to googel and updated the config file.
      if I restart now the magic mirror comes simply only a black screen without error message. If the code is removed from the config then the magic mirror works normally again.
      If someone could help me with my problem I would be very happy.
      Greeting Volker.
        Mathieu
        My log … thank’s
        magicmirror@2.14.0 start /home/pi/MagicMirror
        DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js “dev”
        [22.01.2021 15:41.18.655] [LOG] Starting MagicMirror: v2.14.0
        [22.01.2021 15:41.18.666] [LOG] Loading config …
        [22.01.2021 15:41.18.686] [LOG] Loading module helpers …
        [22.01.2021 15:41.18.691] [LOG] No helper found for module: alert.
        [22.01.2021 15:41.18.996] [LOG] Initializing new module helper …
        [22.01.2021 15:41.18.998] [LOG] Module helper loaded: updatenotification
        [22.01.2021 15:41.19.001] [LOG] No helper found for module: clock.
        [22.01.2021 15:41.19.803] [LOG] Initializing new module helper …
        [22.01.2021 15:41.19.806] [LOG] Module helper loaded: calendar
        [22.01.2021 15:41.19.813] [LOG] Initializing new module helper …
        [22.01.2021 15:41.19.816] [LOG] Module helper loaded: MMM-DHT22
        [22.01.2021 15:41.19.819] [LOG] No helper found for module: compliments.
        [22.01.2021 15:41.19.824] [LOG] Initializing new module helper …
        [22.01.2021 15:41.19.825] [LOG] Module helper loaded: MMM-Lunartic
        [22.01.2021 15:41.19.827] [LOG] No helper found for module: MMM-WeatherOrNot.
        [22.01.2021 15:41.19.888] [LOG] Initializing new module helper …
        [22.01.2021 15:41.19.889] [LOG] Module helper loaded: newsfeed
        [22.01.2021 15:41.21.095] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v8.5-linux-arm/snowboy.node’
        Require stack:
        • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/index.js
        • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/index.js
        • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_helper.js
        [22.01.2021 15:41.21.098] [LOG] Loading module helpers …
        [22.01.2021 15:41.21.101] [LOG] No helper found for module: alert.
        [22.01.2021 15:41.21.104] [LOG] Initializing new module helper …
        [22.01.2021 15:41.21.106] [LOG] Module helper loaded: updatenotification
        [22.01.2021 15:41.21.109] [LOG] No helper found for module: clock.
        [22.01.2021 15:41.21.112] [LOG] Initializing new module helper …
        [22.01.2021 15:41.21.114] [LOG] Module helper loaded: calendar
        [22.01.2021 15:41.21.116] [LOG] Initializing new module helper …
        [22.01.2021 15:41.21.117] [LOG] Module helper loaded: MMM-DHT22
        [22.01.2021 15:41.21.120] [LOG] No helper found for module: compliments.
        [22.01.2021 15:41.21.122] [LOG] Initializing new module helper …
        [22.01.2021 15:41.21.123] [LOG] Module helper loaded: MMM-Lunartic
        [22.01.2021 15:41.21.124] [LOG] No helper found for module: MMM-WeatherOrNot.
        [22.01.2021 15:41.21.126] [LOG] Initializing new module helper …
        [22.01.2021 15:41.21.127] [LOG] Module helper loaded: newsfeed
        [22.01.2021 15:41.21.141] [ERROR] App threw an error during load
        [22.01.2021 15:41.21.155] [ERROR] Error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v8.5-linux-arm/snowboy.node’
        Require stack:
        • at Module._resolveFilename (internal/modules/cjs/loader.js:798:15)
          at Function…/lib/common/reset-search-paths.ts.Module._resolveFilename (electron/js2c/browser_init.js:7718:16)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Module._load (internal/modules/cjs/loader.js:691:27)
          at Function.Module._load (electron/js2c/asar.js:748:26)
          at Module.require (internal/modules/cjs/loader.js:853:19)
          at require (internal/modules/cjs/helpers.js:74:18)
          at Object. (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/index.js:8:29)
          at Module._compile (internal/modules/cjs/loader.js:968:30)
          at Object.Module._extensions…js (internal/modules/cjs/loader.js:986:10)
          [22.01.2021 15:41.21.158] [ERROR] Whoops! There was an uncaught exception…
          [22.01.2021 15:41.21.170] [ERROR] Error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v8.5-linux-arm/snowboy.node’
          Require stack:
          at Object.Module._extensions…js (internal/modules/cjs/loader.js:986:10) {
          code: ‘MODULE_NOT_FOUND’,
          requireStack: [
          ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/index.js’,
          ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/index.js’,
          ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_helper.js’,
          ‘/home/pi/MagicMirror/js/app.js’,
          ‘/home/pi/MagicMirror/js/electron.js’,
          ‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,
          undefined
          [22.01.2021 15:41.21.178] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [22.01.2021 15:41.21.180] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          [22.01.2021 15:41.21.636] [LOG] Launching application.
          [22.01.2021 15:41.21.703] [WARN] (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently “false”. It will change to be “true” in Electron 9. For more information please check https://github.com/electron/electron/issues/18397
        • E
          Egnos @Mathieu
          @Mathieu
          It seems you can’t find some “Error: Cannot find module” files, in particular some components of “snowboy”.
          I advise you to uninstall and clean install by carefully following this guide .
          Unfortunately the user @bugsounet is no longer part of the forum and without him it will be very difficult to get information on this module … :-(
            Mathieu @Egnos
            @Egnos it’s ok after clean install thank you … but … I am also having an issue with youtube it is not working. I used different commands but it is not showing youtube videos. I already changed all the false to true as per the video my GA is working but youTube still not working.
            • E
              Egnos @Mathieu
              @Mathieu good job!
              Post your config please (if I’m not mistaken some YouTube videos covered by copyright, due to Google policies, are no longer visible using GA…)
                Mathieu
                Thank you I will post my config here this evening.
                And it’s the same for link internet… it’s doesn’t work. Thank you. and I try post a screen shot.
                Merci.
                  Mathieu
                  Capture d’écran 2021-01-25 à 19.09.30.png Capture d’écran 2021-01-25 à 19.08.41.png Capture d’écran 2021-01-25 à 19.07.39.png Capture d’écran 2021-01-25 à 19.05.42.png
                    jste84
                    I just posted about issues I’m having with this module after update
                    I tried a fresh install but sadly I’m not having any luck with it
                    Wish I hadn’t updated :(
                    • E
                      Egnos @Mathieu
                      @Mathieu meanwhile it would be better if you read the guideon github for MMM-GoogleAssistant and MMM-Assistant2Display
                      Then I would try this config:
                      		  module: "MMM-GoogleAssistant",
                      		  position: "fullscreen_above",
                      			assistantConfig: {
                      				lang: "fr-FR",
                      				latitude: 44.6503800,
                      				longitude: -0.35508007.558791,
                      			responseConfig: {
                      			  useScreenOutput: true,
                      			  screenOutputCSS: "screen_output.css",
                      			  screenOutputTimer: 5000,
                      			  screenRotate: false,
                      			  activateDelay: 250,
                      			  useAudioOutput: true,
                      			  useChime: true,
                      			  newChime: false,
                      			  useNative: true,
                      			  playProgram: "mpg321"
                      			A2DServer: {
                      			  useA2D: true,
                      			  stopCommand: "stop",
                      			  useYouTube: true,
                      			  youtubeCommand: "youtube",
                      			  displayResponse: true
                      			micConfig: {
                      			  recorder: "arecord",
                      			  device: "plughw:2"
                      			snowboy: {
                      				Sensitivity: 0.7,
                      				Model: "jarvis"
                      		  module: "MMM-Assistant2Display",
                      		  position: "bottom_right",
                      			debug:false,
                      			useYoutube: true,
                      				cast: {
                      					useCast: true,
                      					castName: "MagicMirror",
                      					port: 8569
                      				volume: {
                      					  useVolume: true,
                      					  volumePreset: "ALSA_HDMI",
                      					  myScript: null
                      				links: 	{
                      						useLinks: true,
                      						scrollActivate: true
                      after activating GA with “Jarvis” remember to say “YouTube …” and the name of the video …
                        Mathieu
                        @Egnos Thank You. Merci. Gracias
                        I try this evening.
                          Mathieu
                          It’s Ok … work after clean install…
                          But how you stop Youtube Vidéos where is the command…?
                          Thank you
                          • E
                            Egnos @Mathieu
                            @Mathieu Stop ;-)
