    MMM-google assistant black screen.
    12 Posts 3 Posters 2.5k Views 4 Watching
      Mathieu
      Thank you I will post my config here this evening.
      And it’s the same for link internet… it’s doesn’t work. Thank you. and I try post a screen shot.
      Merci.
        Mathieu
        Capture d’écran 2021-01-25 à 19.09.30.png Capture d’écran 2021-01-25 à 19.08.41.png Capture d’écran 2021-01-25 à 19.07.39.png Capture d’écran 2021-01-25 à 19.05.42.png
          jste84
          I just posted about issues I’m having with this module after update
          I tried a fresh install but sadly I’m not having any luck with it
          Wish I hadn’t updated :(
          • E Offline
            Egnos @Mathieu
            @Mathieu meanwhile it would be better if you read the guideon github for MMM-GoogleAssistant and MMM-Assistant2Display
            Then I would try this config:
            		  module: "MMM-GoogleAssistant",
            		  position: "fullscreen_above",
            			assistantConfig: {
            				lang: "fr-FR",
            				latitude: 44.6503800,
            				longitude: -0.35508007.558791,
            			responseConfig: {
            			  useScreenOutput: true,
            			  screenOutputCSS: "screen_output.css",
            			  screenOutputTimer: 5000,
            			  screenRotate: false,
            			  activateDelay: 250,
            			  useAudioOutput: true,
            			  useChime: true,
            			  newChime: false,
            			  useNative: true,
            			  playProgram: "mpg321"
            			A2DServer: {
            			  useA2D: true,
            			  stopCommand: "stop",
            			  useYouTube: true,
            			  youtubeCommand: "youtube",
            			  displayResponse: true
            			micConfig: {
            			  recorder: "arecord",
            			  device: "plughw:2"
            			snowboy: {
            				Sensitivity: 0.7,
            				Model: "jarvis"
            		  module: "MMM-Assistant2Display",
            		  position: "bottom_right",
            			debug:false,
            			useYoutube: true,
            				cast: {
            					useCast: true,
            					castName: "MagicMirror",
            					port: 8569
            				volume: {
            					  useVolume: true,
            					  volumePreset: "ALSA_HDMI",
            					  myScript: null
            				links: 	{
            						useLinks: true,
            						scrollActivate: true
            after activating GA with “Jarvis” remember to say “YouTube …” and the name of the video …
              Mathieu
              @Egnos Thank You. Merci. Gracias
              I try this evening.
                Mathieu
                It’s Ok … work after clean install…
                But how you stop Youtube Vidéos where is the command…?
                Thank you
                • E Offline
                  Egnos @Mathieu
                  @Mathieu Stop ;-)
