    MMM-BoschSmartHome
    29 Posts 7 Posters 13.6k Views 7 Watching
    • mumblebajM
      mumblebaj Module Developer @Jalibu
      @Jalibu Looking good. Well done.
        MajorC Project Sponsor
        I have two rooms equipped with Bosch since one week and happy to test your module.
        • JalibuJ
          Jalibu Module Developer
          The latest version also supports the Twinguard AirQualityLevel (updated Screenshot on first post)
            I followed the instructions. Within generate certificate I was ask a couple of questions I was not sure about. (Country ID, Company, E-Mail, …).
            I included the config with my Bosch-IP address and the password. Pressed the button and reboot my raspberry.
            But nothing is shown on the screen.
            JalibuJ 1 Reply Last reply Reply Quote 0
            • JalibuJ
              Jalibu Module Developer @MajorC
              @MajorC There was a wrong/old value in my sample config (replace MMM-BSH with MMM-BoschSmartHome)
                I see, now it is working just fine! Great work @Jalibu !
                Next step to work on, some CSS functionalities.
                  I played a little bit with custom.css
                   * MMM-BoschSmartHome
                  .MMM-BoschSmartHome .bsh-wrapper {
                    background-color: rgba(0,0,0,0.00);
                    color: #fff;
                    font-size: 20px;
                  .MMM-BoschSmartHome .bsh-room-icon {
                    margin-right: 8 px;
                  .MMM-BoschSmartHome .bsh-tiles {
                    font-size: 18px;
                  • JalibuJ
                    I released a new version and updated my first Topic post with the latest Features and Screenshots.
                    Features
                    • Support for multiple rooms
                    • Shutter Contacts
                    • Room Climate Controls
                    • Thermostats
                    • Twinguards
                    • Visualization of Temperature, Humidity and Purity
                    • Bosch Home Connect Dishwashers (experimental!)
                    • Philips Hue Bridge
                    • Languages: English, German
                    Thanks to all testers!
                      Update with
                      git pull
                      was working fine.
                      I am not sure about the new grafic-elements. This is how it looks on my system without custom.css.
                      		module: "MMM-BoschSmartHome",
                      			position: "bottom_left",
                      				host: "192.168.2.XX", // Local IP Address
                      				name: "MMM-BoschSmartHome", // Display name for App
                      				identifier: "MMM-BoschSmartHome", // Unique Identifier for app
                      				password: "XXX", // Password for Bosch Smart Home Bridge
                      				refreshIntervalInSeconds: 60, // Default: 60
                      				width: "340px",
                      				displayRoomIcons: true, // Default: false
                      				displayThermostats: true, // Default: false
                      				airquality: {
                      					purity: "none", // one of [tile, bar, donut, none]. Default: bar
                      					humidity: "bar", // one of [tile, bar, donut, none]. Default: bar
                      					temperature: "donut", // one of [tile, bar, donut, none]. Default: bar
                      					preferredTemperatureProvider: "ClimateControl", // Twinguard or ClimateControl. Default: Twinguard, but falls back to CC
                      					preferredHumidityProvider: "ClimateControl" // Twinguard or ClimateControl. Default: Twinguard, but falls back to CC
                      • JalibuJ
                        The latest version fixes a few bugs and supports an option to hide individual components per room.
                        Example:
                          hideComponents: {
                            "Livingroom": ["temperature", "purity", "humidity"],
                            "Bed Room": ["battery", "climateControl", "temperatureLevel", "hue"],
                            "Kitchen": ["shutters", "dishwasher", "thermostats"]
                          Looking good for me so fare after a couple of minutes.
                            MajorC Project Sponsor @Jalibu
                            @jalibu is it possible, that the hide room option is not working at the moment? I can hide hue and other things, but not the entire room with:
                            hideComponents: {
                            					"Flur": ["room"],
                            					"Küche": ["room"]// hides entire room
                            JalibuJ M 2 Replies Last reply Reply Quote 0
                            • JalibuJ
                              @majorc
                              I can not reproduce your problem. Could you send me a Debug Dump of your environment again?
                                MajorC Project Sponsor @MajorC
                                @majorc said in MMM-BoschSmartHome:
                                hideComponents: {
                                					"Flur": ["room"],
                                My mistake. I had not installed the latest version of MMM-BoschSmartHome. I used git pull again, now everything works as expected.
                                  @Jalibu
                                  Hi, I just updated to MM 2.18 and the MM will not come up, if the MMM-BoschSmartHome module is active.
                                  If I disable/comment out the module, everything is working fine.
                                  Have you checked your module with MM 2.18?
                                  Update: I did a
                                  npm install rxjs
                                  in the MMM-BoschSmartHome folder, that seams to do the fix.
                                  JalibuJ S 2 Replies Last reply Reply Quote 0
                                  • JalibuJ
                                    @majorc That’s strange. The only module dependency is bosch-smart-home-bridge which uses rxjs but also has it in its dependencies: https://github.com/holomekc/bosch-smart-home-bridge/blob/master/package.json
                                    I am running the module on 2.18 without problems
                                      sdetweil @MajorC
                                      @majorc so, after you did the git pull did you do another npm install in the module folder?
                                      sometimes update add new or changed dependencies.
                                      general rule
                                      if the module contains a package json
                                      ALWAYS do npm install (or follow the module instructions, as for bugsounet’s stuff)
                                      on install or update
                                        MajorC Project Sponsor @sdetweil
                                        @sdetweil I am sure i did that. But I am not able to check it again, because now it is working fine.
                                          Is there an option to sort the shown rooms. I would like to change the order of the rooms.
                                          • JalibuJ
                                            @majorc nope, not yet. But feel free to create a Feature Request on GitHub for that.
