    MMM-BoschSmartHome
    29 Posts 7 Posters 13.2k Views 7 Watching
      MajorC Project Sponsor
      Update with
      git pull
      was working fine.
      I am not sure about the new grafic-elements. This is how it looks on my system without custom.css.
      		module: "MMM-BoschSmartHome",
      			position: "bottom_left",
      				host: "192.168.2.XX", // Local IP Address
      				name: "MMM-BoschSmartHome", // Display name for App
      				identifier: "MMM-BoschSmartHome", // Unique Identifier for app
      				password: "XXX", // Password for Bosch Smart Home Bridge
      				refreshIntervalInSeconds: 60, // Default: 60
      				width: "340px",
      				displayRoomIcons: true, // Default: false
      				displayThermostats: true, // Default: false
      				airquality: {
      					purity: "none", // one of [tile, bar, donut, none]. Default: bar
      					humidity: "bar", // one of [tile, bar, donut, none]. Default: bar
      					temperature: "donut", // one of [tile, bar, donut, none]. Default: bar
      					preferredTemperatureProvider: "ClimateControl", // Twinguard or ClimateControl. Default: Twinguard, but falls back to CC
      					preferredHumidityProvider: "ClimateControl" // Twinguard or ClimateControl. Default: Twinguard, but falls back to CC
      • JalibuJ Offline
        Jalibu Module Developer
        The latest version fixes a few bugs and supports an option to hide individual components per room.
        Example:
          hideComponents: {
            "Livingroom": ["temperature", "purity", "humidity"],
            "Bed Room": ["battery", "climateControl", "temperatureLevel", "hue"],
            "Kitchen": ["shutters", "dishwasher", "thermostats"]
          Looking good for me so fare after a couple of minutes.
            MajorC Project Sponsor @Jalibu
            @jalibu is it possible, that the hide room option is not working at the moment? I can hide hue and other things, but not the entire room with:
            hideComponents: {
            					"Flur": ["room"],
            					"Küche": ["room"]// hides entire room
            JalibuJ M 2 Replies Last reply Reply Quote 0
            • JalibuJ Offline
              Jalibu Module Developer @MajorC
              @majorc
              I can not reproduce your problem. Could you send me a Debug Dump of your environment again?
                MajorC Project Sponsor @MajorC
                @majorc said in MMM-BoschSmartHome:
                hideComponents: {
                					"Flur": ["room"],
                My mistake. I had not installed the latest version of MMM-BoschSmartHome. I used git pull again, now everything works as expected.
                  @Jalibu
                  Hi, I just updated to MM 2.18 and the MM will not come up, if the MMM-BoschSmartHome module is active.
                  If I disable/comment out the module, everything is working fine.
                  Have you checked your module with MM 2.18?
                  Update: I did a
                  npm install rxjs
                  in the MMM-BoschSmartHome folder, that seams to do the fix.
                  JalibuJ S 2 Replies Last reply Reply Quote 0
                  • JalibuJ Offline
                    @majorc That’s strange. The only module dependency is bosch-smart-home-bridge which uses rxjs but also has it in its dependencies: https://github.com/holomekc/bosch-smart-home-bridge/blob/master/package.json
                    I am running the module on 2.18 without problems
                      sdetweil @MajorC
                      @majorc so, after you did the git pull did you do another npm install in the module folder?
                      sometimes update add new or changed dependencies.
                      general rule
                      if the module contains a package json
                      ALWAYS do npm install (or follow the module instructions, as for bugsounet’s stuff)
                      on install or update
                        MajorC Project Sponsor @sdetweil
                        @sdetweil I am sure i did that. But I am not able to check it again, because now it is working fine.
                          Is there an option to sort the shown rooms. I would like to change the order of the rooms.
                          JalibuJ 1 Reply Last reply Reply Quote 0
                          • JalibuJ Offline
                            @majorc nope, not yet. But feel free to create a Feature Request on GitHub for that.
                              Baschti
                              I installed the module today, but i get this error:
                              [12.02.2023 16:06.09.906] [LOG] Starting MagicMirror: v2.22.0
                              [12.02.2023 16:06.09.918] [LOG] Loading config …
                              [12.02.2023 16:06.09.928] [LOG] Loading module helpers …
                              [12.02.2023 16:06.09.931] [LOG] No helper found for module: alert.
                              [12.02.2023 16:06.09.944] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘bosch-smart- home-bridge’
                              Require stack:
                              • /home/pi/MagicMirror/modules/MMM-BoschSmartHome/node_helper.js
                              • /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/mai n.js
                              [12.02.2023 16:06.09.946] [LOG] Loading module helpers …
                              [12.02.2023 16:06.09.948] [LOG] No helper found for module: alert.
                              [12.02.2023 16:06.09.953] [ERROR] App threw an error during load
                              [12.02.2023 16:06.09.956] [ERROR] Error: Cannot find module ‘bosch-smart-home-br idge’
                              Require stack:
                              at Module._resolveFilename (node:internal/modules/cjs/loader:963:15)
                              at n._resolveFilename (node:electron/js2c/browser_init:2:109416)
                              at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/i        ndex.js:49:29)
                              at Module._load (node:internal/modules/cjs/loader:811:27)
                              at f._load (node:electron/js2c/asar_bundle:2:13328)
                              at Module.require (node:internal/modules/cjs/loader:1035:19)
                              at require (node:internal/modules/cjs/helpers:102:18)
                              at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-BoschSmartHome/node_        helper.js:14:65)
                              at Module._compile (node:internal/modules/cjs/loader:1141:14)
                              at Module._extensions..js (node:internal/modules/cjs/loader:1196:10)
                              [12.02.2023 16:06.09.959] [ERROR] Whoops! There was an uncaught exception…
                              [12.02.2023 16:06.09.971] [ERROR] Error: Cannot find module ‘bosch-smart-home-br idge’
                              Require stack:
                              at Module._extensions..js (node:internal/modules/cjs/loader:1196:10) {
                              code: ‘MODULE_NOT_FOUND’,
                              requireStack: [
                              '/home/pi/MagicMirror/modules/MMM-BoschSmartHome/node_helper.js',
                              '/home/pi/MagicMirror/js/app.js',
                              '/home/pi/MagicMirror/js/electron.js',
                              '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/        main.js',
                              undefined
                              [12.02.2023 16:06.09.973] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                              [12.02.2023 16:06.09.974] [ERROR] If you think this really is an issue, please o pen an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                              [12.02.2023 16:06.10.508] [LOG] Launching application.
                              [1549:0212/160611.418965:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                              [1576:0212/160611.630258:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extens ion not supported.
                              magicmirror@2.22.0 start
                              Require stack:
                              Require stack:
                              Require stack:
                              i have absolutely no clue :-(
                                sdetweil @Baschti
                                @Baschti
                                looks like you didn’t do the npm install in the module folder
                                  Baschti @sdetweil
                                  @sdetweil The Module is located in MagicMirror/modules/MMM-BoschSmartHome/
                                    sdetweil @Baschti
                                    @Baschti yes? and
                                    the author missed
                                    a step in his instructions
                                    between step 1 and 2 do
                                    cd MMM-BoschSmartHome
                                      Baschti @sdetweil
                                      @sdetweil Awesome! Youre right! Can you give me a tip on how to integrate the window sensors
                                        sdetweil @Baschti
                                        @Baschti no. sorry, no idea on the actual details of implementation
                                          mcilliw
                                          Hey, I was wondering if it is possible to orientate the tiles of the rooms horizontally? Has anyone got an idea? :D
                                          • X Offline
                                            Xennon
                                            just wanted to leave you my css, which costs me a bit of time. I wanted to have a clean overview, just see the temperatures in my house. Because I have 9 thermostats, a list with all the colors was just to much for me.
                                            This css gave me a 3 column design, just with the room name and the current temperature:
                                             * MMM-BoschSmartHome
                                            .MMM-BoschSmartHome .bsh-wrapper {
                                              background-color: rgba(0,0,0,0.00);
                                              color: #fff;
                                              font-size: 10px;
                                                display: grid;
                                                grid-template-columns: repeat(3, 1fr);
                                                grid-gap: 10px;
                                              line-height: normal;
                                            .MMM-BoschSmartHome .bsh-wrapper br {
                                                display: none;
                                            .MMM-BoschSmartHome .bsh-wrapper,
                                            .MMM-BoschSmartHome .bsh-tile {
                                                margin: 0;
                                                padding: 0;
                                            .MMM-BoschSmartHome .bsh-room-icon {
                                              margin-right: 8px;
                                            .MMM-BoschSmartHome .bsh-tiles {
                                              font-size: 10px;
                                            .MMM-BoschSmartHome .bsh-badge.climate-control {
                                              visibility: hidden;
                                                min-width: 0; /* Prevent tiles from expanding beyond their column */
                                                width: 100%;
                                              color: white;
                                            .MMM-BoschSmartHome .bsh-room-title {
                                              font-size: 10px;
                                            .MMM-BoschSmartHome .bsh-tile.tile-row {
                                              visibility: hidden;
                                            .MMM-BoschSmartHome .bsh-tile i {
                                              visibility: hidden;
                                            .MMM-BoschSmartHome .bsh-tile.temperature-level span.setpoint-temperature {
                                              font-size: 10px;
                                            .MMM-BoschSmartHome .bsh-tile.temperature-level div:first-child {
                                                visibility: hidden;
                                                position: relative;
                                            .MMM-BoschSmartHome .bsh-tile.temperature-level span.room-temperature {
                                                visibility: visible;
                                                position: absolute;
                                                left: 0; /* Adjust this to position the temperature correctly */
                                                width: 100%;
                                              font-size: 1.8em;
                                              font-weight: bold;
                                              display: inline-block;
                                            I’m using this config:
                                            		    host: "", // Bosch Smart Home Bridge's local IP Address
                                            		    password: "", // Password for Bosch Smart Home Bridge
                                            		    width: "200px",
                                             		    hideComponents: {
                                                			 "Küche": ["dishwasher"]
                                            			}, // See example below. Default: {}
                                             		    hideEmptyRooms: false, // Hide rooms, if they have no information to display. Default: false
                                             		    colorizeRoomWithAirQuality: true, // Colorizes room tiles in red/orange/green depending on combined air quality. Only works with Twinguard
                                            		    roomOrder: ["Wohnzimmer", "Küche", "Bad EG", "Flur EG", "Schlafzimmer","Kinderzimmer", "Bad OG", "Flur OG / Büro", "HWR"], // Manually set the room order by a list of room names, e.g. ["Livingroom", "Bedroom", "Kitchen"]
                                             		    airquality: {
                                            		      humidity: "none", // one of [tile, bar, donut, none]
                                            		      temperature: "none", // one of [tile, bar, donut, none]
                                            		      preferredTemperatureProvider: "Twinguard", // Twinguard or ClimateControl
                                            		      preferredHumidityProvider: "Twinguard" // Twinguard or ClimateControl
                                            		    temperatureLevel: {
                                            		      displayCurrentTemperature: true, // Default: true
                                            		      displayTargetTemperature: false, // Default: true
                                            		      forceRowTile: false // Show tile as row, even if there is no target temperature. Default: true
                                            		    thermostats: {
                                            		      display: false, // Default: true
                                            		      displayName: false // Default: false
                                            		    dishwasher: {
                                            Thanks @ the author of this module.
                                            Before I forget something … If you have BSHC-2 and not BSHC you just have to press the button for pairing at the BSHC.2, not hold the button, like in BSHC. This simple info costs me a week.
