    MMM-COVID19
    Scheduled Pinned Locked Moved Health
    63 Posts 25 Posters 41.5k Views 24 Watching
      paulie420
      Ok, I pulled the MMM-Covid19 git. I added the module in config.js, and entered my APIkey… However, it only displays the COVID-19 title and no data.
      Am I correct in stating that its not working because now rapidapi has made the coronavirus monitor API paid? Because I think I have it all setup correctly, I notice that the API in rapidapi states PAID, and nothing shows… I want Covid data; is there a way, or am I doing something wrong? OR do I just need to pay and then it’ll show up??
      • mumblebajM Offline
        mumblebaj Module Developer @KD
        @KD remove the comma after “medium” and you should be fine.
          mumblebaj Module Developer @paulie420
          @paulie420 The RapidAPI seems to be working fine. No need to pay. Can you post your config?
          J A 2 Replies Last reply Reply Quote 0
            Joeri @mumblebaj
            @mumblebaj Hello, I’ve got the same problem, this is my config.
            module: “MMM-COVID19”,
            position: “lower_third”,
            updateInterval: 300000,
            worldStats: true,
            delta: true,
            headerRowClass: ‘small’,
            orderCountriesByName: “false”,
            lastUpdateInfo: true,
            countries: [ “Argentina”, “USA” ],
            headerRowClass: “small”,
            infoRowClass: “medium”,
            rapidapiKey : “MY KEY”,
              andfha @mumblebaj
              @mumblebaj Same problem here. Looks like its paid now. curl shows “You are not subscribed to this API”
                menckow
                There are two versions of the api. A paid and a freemium version. The freemium one is the V2!
                If you want to use the freemium version you will have to edit the node_helper.js file in the module directory (MMM-COVID19) and change the rapidapihost entry and the GET URL as well
                rapidhost
                NEW: “x-rapidapi-host”: “coronavirus-monitor-v2.p.rapidapi.com”,
                OLD: “x-rapidapi-host”: “coronavirus-monitor.p.rapidapi.com”,
                GET URL
                NEW: ‘https://coronavirus-monitor-V2.p.rapidapi.com/coronavirus/cases_by_country.php’
                OLD: ‘https://coronavirus-monitor.p.rapidapi.com/coronavirus/worldstat.php’
                • I Offline
                  Indiz
                  Bonjour j’ai le même problème, je n’ai que le titre COVID-19 qui apparait et aucunes données.
                  Voici ma config:
                  	module: "MMM-COVID19",
                  	  worldStats: true,
                  	  delta: true,
                  	  countries: [ "USA", "France", "Spain" ],
                  	  headerRowClass: "small",
                  	  rapidapiKey : "KEY",
                    dubalda
                    Hi guys,
                    I’m not getting much luck getting this to work. I just get the header and no errors in the log.
                    position: “top_left”,
                    worldStats: true,
                    delta: true,
                    countries: [ “Argentina”, “China”, “Italy”, “Spain” ],
                    rapidapiKey : “xxx”
                    I’ve also amended the node_helper.js for the module to include the new rapidhost URLs
                    var byCountryUrl = ‘https://coronavirus-monitor-V2.p.rapidapi.com/coronavirus/cases_by_country.php’
                    getGlobalStats: function(key) {
                    var self = this
                    var options = {
                    method: ‘GET’,
                    url: worldStatsUrl,
                    headers: {
                    //‘x-rapidapi-host’: ‘coronavirus-monitor.p.rapidapi.com’,
                    ‘x-rapidapi-host’: ‘coronavirus-monitor-v2.p.rapidapi.com’,
                    ‘x-rapidapi-key’: key
                    getStatsByCoutry: function(key) {
                    var self = this
                    var options = {
                    method: ‘GET’,
                    url: byCountryUrl,
                    headers: {
                    Any help would be great!
                      sdetweil @dubalda
                      @dubalda when u use the url in a browser does it return the right data?
                        dubalda
                        Hi Sam,
                        I just get "{“message”:“Invalid API key. Go to https://docs.rapidapi.com/docs/keys for more info.”}
                        Sorry, perhaps I missing something here…are you refering this URL
                        Thx
                          sdetweil @dubalda
                          @dubalda whatever api you use. i always test in a browser first.
                          u need to add the apikey to the url
                          i am making it up (not exact text) cause i am on my phone in hospital
                          url.php&api_key=whatever is the key
                            dubalda
                            Sorry to hear you’re in hospital! Hopefully it’s nothing to serious.
                            I tried…
                            https://coronavirus-monitor.p.rapidapi.com/coronavirus/united_states_cases.php&api_key=xxx
                            and received.
                            RapidAPI does see it’s free service. I’ve amened the entries in node_helper.js back to the their defaults but still no joy there. Very strange.
                              sdetweil @dubalda
                              @dubalda free and requiring a key are different.
                              if u require a key you know who consumes your service
                              i said dont take my words exactly.
                              what does the service say is the apikey parameter name, exact spelling
                              this aint magic, its grunt work getting the parms right
                              i do my.own covid charts MyCovid19, see
                              https://github.com/sdetweil/MyCovid19
                              they have changed the data on me 3 times in a year. hard to keep up
                                dubalda
                                I’ve tried…
                                curl -H “x-rapidapi-host: coronavirus-monitor-v2.p.rapidapi.com” -H “x-rapidapi-key: xxx” ‘https://coronavirus-monitor-v2.p.rapidapi.com/coronavirus/cases_by_country.php’
                                And have copied the key (copy/paste) exactly from the website but get the message…
                                “message”:“You are not subscribed to this API.”
                                I think I’ll just get the Covid numbers from the news! Thanks for your help @sdetweil !
                                  sdetweil @dubalda
                                  @dubalda see
                                  https://docs.rapidapi.com/docs/basics-creating-a-project
                                    dubalda
                                    Thanks…I’ll have a look.
                                      dubalda
                                      @sdetweil I think the issue was due to the api having to be paid for. In the end I changed to MMM-COVID19-SPARKLINE which working fine. Thanks for your help!
                                      • 3 / 4
