    Current Weather and Weather Forecast looks grey out.
    24 Posts 6 Posters 8.3k Views 5 Watching
      raf
      /home/pi/MagicMirror/modules/default/weatherforecast/weatherforecast.js
      in this file change colored from false to true
        sdetweil @raf
        @raf please dont edit the code. use config.js
          A Former User
            sdetweil @Guest
            @hango no
            custom.css is in css always. hard coded to be loaded last
            never referenced in config.js
            ? S 2 Replies Last reply
              A Former User @sdetweil
                shagtimetim @sdetweil
                @sdetweil Following this: If not in config.js, where do we reference the custom.css?
                  sdetweil @shagtimetim
                  @shagtimetim you never reference custom.css.
                  it is hard coded in the mm runtime to load custom.css last, to allow it to override any styles set before
                  u have to do nothing
                    @sdetweil As always, thank you sir.
                      sdetweil @Guest
                      @hango altho u can, you shouldnt. there is only one. normal place should be fine
                      ? 1 Reply Last reply
                          sdetweil @Guest
                          @hango remember you can use the dev window elements tab, to edit the css, get what u want, and code that in custom.css
                          quit guessing
                              sdetweil @Guest
                              @hango good that u have skill most of us dont. just want to educate people on a different process than guess and try
                              Mykle1M 1 Reply Last reply
                              • Mykle1M
                                ![0_1612315124827_21.png](Uploading 100%)
                                Invalid files also
