    Current Weather and Weather Forecast looks grey out.
    24 Posts 6 Posters 8.3k Views 5 Watching
      A Former User
        sdetweil @Guest
        @hango no
        custom.css is in css always. hard coded to be loaded last
        never referenced in config.js
        ? S 2 Replies Last reply
          A Former User @sdetweil
            shagtimetim @sdetweil
            @sdetweil Following this: If not in config.js, where do we reference the custom.css?
              sdetweil @shagtimetim
              @shagtimetim you never reference custom.css.
              it is hard coded in the mm runtime to load custom.css last, to allow it to override any styles set before
              u have to do nothing
                @sdetweil As always, thank you sir.
                  sdetweil @Guest
                  @hango altho u can, you shouldnt. there is only one. normal place should be fine
                  ? 1 Reply Last reply
                      sdetweil @Guest
                      @hango remember you can use the dev window elements tab, to edit the css, get what u want, and code that in custom.css
                      quit guessing
                          sdetweil @Guest
                          @hango good that u have skill most of us dont. just want to educate people on a different process than guess and try
                          Mykle1M 1 Reply Last reply
                          • Mykle1M
                            ![0_1612315124827_21.png](Uploading 100%)
                            Invalid files also
