    Installing on a Pi Zero
    175 Posts 33 Posters 303.4k Views 33 Watching
    • Mykle1M
      @sdetweil said in Installing on a Pi Zero:
      just use my script
      Amen to that.
      • ebolisaE
        ebolisa @sdetweil
        @sdetweil but which one exacly? I had MM running on P4 but the heat produced by the processor, the screen and its electronics, has pushed me to try out MM on a P0. With that, I should resolve the heat issue.
        So, after reading several outdated procedures and after investing hours (as you know, P0 is as slow as hell) I’m back to square one.
        Which steps should I take from scratch?
        Which SO should I start with?
        Which install batch should I install?
        @stanvv’s procedure worked till I had to reboot, then the X server stopped responding :angry_face:
          sdetweil @ebolisa
          @ebolisa what does it say?
          to install do this
          to update do this
          u want to install, so u do the 1st
          make sure to remove the MagicMirror folder, cause the script is starting from the beginning
          ebolisaE 1 Reply Last reply
          • ebolisaE
            ebolisa @sdetweil
            @sdetweil ok. Done the following with no avail.
            Removed MagicMirror folder
            Ran the install script. No errors. It did an autoreboot but no go.
            Reviewed the install_log… no errors.
            Did notice, however, the script created 3 folders:
            MagicMirror
            magic-mirror
            magic-mirror-app
            At reboot, the X server intent to start but incounters some errors and shuts down with the message: Server terminated successfully (0). Closing log file.
            Where do I go from here?
            TIA
            EDIT:
            Here’s the Xorg log:
            [    64.036]
            X.Org X Server 1.20.4
            X Protocol Version 11, Revision 0
            [    64.101] Build Operating System: Linux 5.4.0-54-generic armv8l Raspbian
            [    64.123] Current Operating System: Linux magicmirror 5.10.11+ #1399 Thu Jan        28 12:02:28 GMT 2021 armv6l
            [    64.123] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.e        nable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1280 bcm2708_fb        .fbheight=1024 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:7C:38:09 vc_mem.mem        _base=0x1ec00000 vc_mem.mem_size=0x20000000  console=ttyS0,115200 console=tty1 r        oot=PARTUUID=a27be534-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootw        ait
            [    64.220] Build Date: 15 January 2021  02:03:57PM
            [    64.243] xorg-server 2:1.20.4-1+rpt2+deb10u3 (https://www.debian.org/support        )
            [    64.265] Current version of pixman: 0.36.0
            [    64.311]    Before reporting problems, check http://wiki.x.org
                    to make sure that you have the latest version.
            [    64.314] Markers: (--) probed, (**) from config file, (==) default setting,
                    (++) from command line, (!!) notice, (II) informational,
                    (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
            [    64.415] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Feb 15 18:44:41 202        1
            [    64.455] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
            [    64.471] (==) No Layout section.  Using the first Screen section.
            [    64.471] (==) No screen section available. Using defaults.
            [    64.471] (**) |-->Screen "Default Screen Section" (0)
            [    64.471] (**) |   |-->Monitor "<default monitor>"
            [    64.494] (==) No monitor specified for screen "Default Screen Section".
                    Using a default monitor configuration.
            [    64.495] (==) Automatically adding devices
            [    64.496] (==) Automatically enabling devices
            [    64.496] (==) Automatically adding GPU devices
            [    64.503] (==) Max clients allowed: 256, resource mask: 0x1fffff
            [    64.517] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
            [    64.517]    Entry deleted from font path.
            [    64.517] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
            [    64.518] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
            [    64.518]    Entry deleted from font path.
            [    64.518] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
            [    64.518] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
            [    64.518] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
            [    64.519]    Entry deleted from font path.
            [    64.519] (==) FontPath set to:
                    /usr/share/fonts/X11/misc,
                    built-ins
            [    64.519] (==) ModulePath set to "/usr/lib/xorg/modules"
            [    64.519] (II) The server relies on udev to provide the list of input devices        .
                    If no devices become available, reconfigure udev or disable AutoAddDevic        es.
            [    64.519] (II) Loader magic: 0x1fdf80
            [    64.519] (II) Module ABI versions:
            [    64.519]    X.Org ANSI C Emulation: 0.4
            [    64.519]    X.Org Video Driver: 24.0
            [    64.522]    X.Org XInput driver : 24.1
            [    64.522]    X.Org Server Extension : 10.0
            [    64.538] (--) using VT number 2
            [    64.538] (II) systemd-logind: logind integration requires -keeptty and -keep        tty was not provided, disabling logind integration
            [    64.542] (II) no primary bus or device found
            [    64.545] (II) LoadModule: "glx"
            [    64.556] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
            [    64.656] (II) Module glx: vendor="X.Org Foundation"
            [    64.657]    compiled for 1.20.4, module version = 1.0.0
            [    64.657]    ABI class: X.Org Server Extension, version 10.0
            [    64.657] (==) Matched modesetting as autoconfigured driver 0
            [    64.657] (==) Matched fbdev as autoconfigured driver 1
            [    64.657] (==) Assigned the driver to the xf86ConfigLayout
            [    64.657] (II) LoadModule: "modesetting"
            [    64.664] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
            [    64.674] (II) Module modesetting: vendor="X.Org Foundation"
            [    64.675]    compiled for 1.20.4, module version = 1.20.4
            [    64.675]    Module class: X.Org Video Driver
            [    64.675]    ABI class: X.Org Video Driver, version 24.0
            [    64.675] (II) LoadModule: "fbdev"
            [    64.682] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
            [    64.689] (II) Module fbdev: vendor="X.Org Foundation"
            [    64.690]    compiled for 1.20.3, module version = 0.5.0
            [    64.690]    Module class: X.Org Video Driver
            [    64.690]    ABI class: X.Org Video Driver, version 24.0
            [    64.693] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
            [    64.693] (II) FBDEV: driver for framebuffer: fbdev
            [    64.719] (WW) Falling back to old probe method for modesetting
            [    64.719] (EE) open /dev/dri/card0: No such file or directory
            [    64.720] (WW) Falling back to old probe method for fbdev
            [    64.720] (II) Loading sub module "fbdevhw"
            [    64.720] (II) LoadModule: "fbdevhw"
            [    64.721] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
            [    64.729] (II) Module fbdevhw: vendor="X.Org Foundation"
            [    64.729]    compiled for 1.20.4, module version = 0.0.2
            [    64.730]    ABI class: X.Org Video Driver, version 24.0
            [    64.734] (II) FBDEV(0): using default device
            [    64.734] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
            [    64.739] (II) FBDEV(0): Creating default Display subsection in Screen sectio        n
                    "Default Screen Section" for depth/fbbpp 24/32
            [    64.739] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
            [    64.739] (==) FBDEV(0): RGB weight 888
            [    64.743] (==) FBDEV(0): Default visual is TrueColor
            [    64.762] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
            [    64.763] (II) FBDEV(0): hardware: BCM2708 FB (video memory: 5120kB)
            [    64.763] (DB) xf86MergeOutputClassOptions unsupported bus type 0
            [    64.763] (II) FBDEV(0): checking modes against framebuffer device...
            [    64.763] (II) FBDEV(0): checking modes against monitor...
            [    64.764] (II) FBDEV(0): Virtual size is 1280x1024 (pitch 1280)
            [    64.764] (**) FBDEV(0):  Built-in mode "current"
            [    64.764] (==) FBDEV(0): DPI set to (96, 96)
            [    64.764] (II) Loading sub module "fb"
            [    64.764] (II) LoadModule: "fb"
            [    64.765] (II) Loading /usr/lib/xorg/modules/libfb.so
            [    64.787] (II) Module fb: vendor="X.Org Foundation"
            [    64.787]    compiled for 1.20.4, module version = 1.0.0
            [    64.787]    ABI class: X.Org ANSI C Emulation, version 0.4
            [    64.787] (**) FBDEV(0): using shadow framebuffer
            [    64.787] (II) Loading sub module "shadow"
            [    64.787] (II) LoadModule: "shadow"
            [    64.788] (II) Loading /usr/lib/xorg/modules/libshadow.so
            [    64.796] (II) Module shadow: vendor="X.Org Foundation"
            [    64.796]    compiled for 1.20.4, module version = 1.1.0
            [    64.801]    ABI class: X.Org ANSI C Emulation, version 0.4
            [    64.801] (II) UnloadModule: "modesetting"
            [    64.801] (II) Unloading modesetting
            [    64.838] (==) FBDEV(0): Backing store enabled
            [    64.845] (==) FBDEV(0): DPMS enabled
            [    64.847] (II) Initializing extension Generic Event Extension
            [    64.852] (II) Initializing extension SHAPE
            [    64.865] (II) Initializing extension MIT-SHM
            [    64.877] (II) Initializing extension XInputExtension
            [    64.888] (II) Initializing extension XTEST
            [    64.897] (II) Initializing extension BIG-REQUESTS
            [    64.905] (II) Initializing extension SYNC
            [    64.913] (II) Initializing extension XKEYBOARD
            [    64.921] (II) Initializing extension XC-MISC
            [    64.930] (II) Initializing extension SECURITY
            [    64.937] (II) Initializing extension XFIXES
            [    64.947] (II) Initializing extension RENDER
            [    64.955] (II) Initializing extension RANDR
            [    64.974] (II) Initializing extension COMPOSITE
            [    64.981] (II) Initializing extension DAMAGE
            [    64.992] (II) Initializing extension MIT-SCREEN-SAVER
            [    65.000] (II) Initializing extension DOUBLE-BUFFER
            [    65.007] (II) Initializing extension RECORD
            [    65.016] (II) Initializing extension DPMS
            [    65.025] (II) Initializing extension Present
            [    65.032] (II) Initializing extension DRI3
            [    65.035] (II) Initializing extension X-Resource
            [    65.042] (II) Initializing extension XVideo
            [    65.053] (II) Initializing extension XVideo-MotionCompensation
            [    65.054] (II) Initializing extension SELinux
            [    65.054] (II) SELinux: Disabled on system
            [    65.058] (II) Initializing extension GLX
            [    65.065] (II) AIGLX: Screen 0 is not DRI2 capable
            [    68.618] (II) IGLX: Loaded and initialized swrast
            [    68.620] (II) GLX: Initialized DRISWRAST GL provider for screen 0
            [    68.621] (II) Initializing extension XFree86-VidModeExtension
            [    68.628] (II) Initializing extension XFree86-DGA
            [    68.637] (II) Initializing extension XFree86-DRI
            [    68.641] (II) Initializing extension DRI2
            [   118.828] (II) Server terminated successfully (0). Closing log file.
              sdetweil @ebolisa
              @ebolisa i would rebuild the sd card and start again
              • ebolisaE
                ebolisa @sdetweil
                @sdetweil I agree but which OS should I use? The lite one?
                  sdetweil @ebolisa
                  @ebolisa full desktop
                  • ebolisaE
                    ebolisa @sdetweil
                    @sdetweil Thank you! Finally got it going. I had to change the SD card.
                    Now I can finally replace my P4 with the P0. The P4, along with the display, are causing heat related problems so, P0 to the rescue.
                    Just FYI, I cannot hide the cursor and sudo apt-get install unclutter didn’t help.
                    S 2 Replies Last reply
                      sdetweil @ebolisa
                      @ebolisa in css/main.css body should have cursor:none
                      you are running chromium-browser, not electron, but should have been the same
                        sdetweil @ebolisa
                        @ebolisa pi0 doesnt have a lot of power, so beware running too much…
                        check swap space usage
                        free -m
                        to see if it needs to be made bigger
                        • ebolisaE
                          ebolisa @sdetweil
                          @sdetweil Yes, I set swap to 1024. It’s slow but it works.
                          Thanks again!!
                            RushHour99
                            @sdetweil , I went through a fresh SD card install for a Pi Zero W. raspbian and then the raspberry.sh script via your github page. I believe everything completed without error.
                            However when Magic Mirror launches on reboot, I get a blank page indicating:
                            This site can’t be reached
                            localhost refused to connect
                            Any idea what to do to troubleshoot?
                              sdetweil @RushHour99
                              @rushhour99 is this with extra modules or just the base?
                              can u show the output of
                              pm2 logs --lines=100
                              R 1 Reply Last reply
                                RushHour99 @sdetweil
                                This just the Magic Mirror base. I haven’t added any extra modules.
                                Unfortunately I cannot paste the pm2 logs output. When I try it gets caught in some sort of spam filter and won’t let me post.
                                  @rushhour99 u can email to me… same userid on gmail
                                  also attach /home/pi/install.log
                                    @sdetweil Thanks, error log emailed. Ive done this process before without error ~9 months ago. Maybe the rasbian version or magic mirror version has changed recently that is now causing the problem.
                                      @rushhour99 there is a new MM version every 2 months…
                                      I test on my own pi 0 .
                                      haven’t seen a problem like this
                                      sent email back, can u send install.log
                                        @rushhour99 do this
                                        sudo npm i -g npm@6
                                        this will downgrade npm to v6
                                        then
                                        rm -rf node_modules
                                        rm package-lock.json
                                        npm install --only=prod
                                        and check if the config.js file exists
                                        ls ~/MagicMirror/config/config,js -laF
                                          sudo npm -i npm@6
                                          I got an error. Thanks for helping out, this is a new build so I don’t mind if it gets messed up and I need to start over.
                                          $ sudo npm -i npm@6
                                          npm ERR! code ENOENT
                                          npm ERR! syscall open
                                          npm ERR! errno -2
                                          npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                                          npm ERR! enoent This is related to npm not being able to find a file.
                                          npm ERR! enoent
                                          npm ERR! /root/.npm/_logs/2021-08-03T22_48_17_691Z-debug.log
                                            @rushhour99 typo, sorry
                                            sudo npm i -g npm@6
                                            • 8 / 9
