    Installing on a Pi Zero
    175 Posts 33 Posters 267.3k Views 33 Watching
      sdetweil @ebolisa
      @ebolisa what does it say?
      to install do this
      to update do this
      u want to install, so u do the 1st
      make sure to remove the MagicMirror folder, cause the script is starting from the beginning
      ebolisaE 1 Reply Last reply Reply Quote 0
      • ebolisaE Offline
        ebolisa @sdetweil
        @sdetweil ok. Done the following with no avail.
        Removed MagicMirror folder
        Ran the install script. No errors. It did an autoreboot but no go.
        Reviewed the install_log… no errors.
        Did notice, however, the script created 3 folders:
        MagicMirror
        magic-mirror
        magic-mirror-app
        At reboot, the X server intent to start but incounters some errors and shuts down with the message: Server terminated successfully (0). Closing log file.
        Where do I go from here?
        TIA
        EDIT:
        Here’s the Xorg log:
        [    64.036]
        X.Org X Server 1.20.4
        X Protocol Version 11, Revision 0
        [    64.101] Build Operating System: Linux 5.4.0-54-generic armv8l Raspbian
        [    64.123] Current Operating System: Linux magicmirror 5.10.11+ #1399 Thu Jan        28 12:02:28 GMT 2021 armv6l
        [    64.123] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.e        nable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1280 bcm2708_fb        .fbheight=1024 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:7C:38:09 vc_mem.mem        _base=0x1ec00000 vc_mem.mem_size=0x20000000  console=ttyS0,115200 console=tty1 r        oot=PARTUUID=a27be534-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootw        ait
        [    64.220] Build Date: 15 January 2021  02:03:57PM
        [    64.243] xorg-server 2:1.20.4-1+rpt2+deb10u3 (https://www.debian.org/support        )
        [    64.265] Current version of pixman: 0.36.0
        [    64.311]    Before reporting problems, check http://wiki.x.org
                to make sure that you have the latest version.
        [    64.314] Markers: (--) probed, (**) from config file, (==) default setting,
                (++) from command line, (!!) notice, (II) informational,
                (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
        [    64.415] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Feb 15 18:44:41 202        1
        [    64.455] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
        [    64.471] (==) No Layout section.  Using the first Screen section.
        [    64.471] (==) No screen section available. Using defaults.
        [    64.471] (**) |-->Screen "Default Screen Section" (0)
        [    64.471] (**) |   |-->Monitor "<default monitor>"
        [    64.494] (==) No monitor specified for screen "Default Screen Section".
                Using a default monitor configuration.
        [    64.495] (==) Automatically adding devices
        [    64.496] (==) Automatically enabling devices
        [    64.496] (==) Automatically adding GPU devices
        [    64.503] (==) Max clients allowed: 256, resource mask: 0x1fffff
        [    64.517] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
        [    64.517]    Entry deleted from font path.
        [    64.517] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
        [    64.518] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
        [    64.518]    Entry deleted from font path.
        [    64.518] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
        [    64.518] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
        [    64.518] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
        [    64.519]    Entry deleted from font path.
        [    64.519] (==) FontPath set to:
                /usr/share/fonts/X11/misc,
                built-ins
        [    64.519] (==) ModulePath set to "/usr/lib/xorg/modules"
        [    64.519] (II) The server relies on udev to provide the list of input devices        .
                If no devices become available, reconfigure udev or disable AutoAddDevic        es.
        [    64.519] (II) Loader magic: 0x1fdf80
        [    64.519] (II) Module ABI versions:
        [    64.519]    X.Org ANSI C Emulation: 0.4
        [    64.519]    X.Org Video Driver: 24.0
        [    64.522]    X.Org XInput driver : 24.1
        [    64.522]    X.Org Server Extension : 10.0
        [    64.538] (--) using VT number 2
        [    64.538] (II) systemd-logind: logind integration requires -keeptty and -keep        tty was not provided, disabling logind integration
        [    64.542] (II) no primary bus or device found
        [    64.545] (II) LoadModule: "glx"
        [    64.556] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
        [    64.656] (II) Module glx: vendor="X.Org Foundation"
        [    64.657]    compiled for 1.20.4, module version = 1.0.0
        [    64.657]    ABI class: X.Org Server Extension, version 10.0
        [    64.657] (==) Matched modesetting as autoconfigured driver 0
        [    64.657] (==) Matched fbdev as autoconfigured driver 1
        [    64.657] (==) Assigned the driver to the xf86ConfigLayout
        [    64.657] (II) LoadModule: "modesetting"
        [    64.664] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
        [    64.674] (II) Module modesetting: vendor="X.Org Foundation"
        [    64.675]    compiled for 1.20.4, module version = 1.20.4
        [    64.675]    Module class: X.Org Video Driver
        [    64.675]    ABI class: X.Org Video Driver, version 24.0
        [    64.675] (II) LoadModule: "fbdev"
        [    64.682] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
        [    64.689] (II) Module fbdev: vendor="X.Org Foundation"
        [    64.690]    compiled for 1.20.3, module version = 0.5.0
        [    64.690]    Module class: X.Org Video Driver
        [    64.690]    ABI class: X.Org Video Driver, version 24.0
        [    64.693] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
        [    64.693] (II) FBDEV: driver for framebuffer: fbdev
        [    64.719] (WW) Falling back to old probe method for modesetting
        [    64.719] (EE) open /dev/dri/card0: No such file or directory
        [    64.720] (WW) Falling back to old probe method for fbdev
        [    64.720] (II) Loading sub module "fbdevhw"
        [    64.720] (II) LoadModule: "fbdevhw"
        [    64.721] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
        [    64.729] (II) Module fbdevhw: vendor="X.Org Foundation"
        [    64.729]    compiled for 1.20.4, module version = 0.0.2
        [    64.730]    ABI class: X.Org Video Driver, version 24.0
        [    64.734] (II) FBDEV(0): using default device
        [    64.734] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
        [    64.739] (II) FBDEV(0): Creating default Display subsection in Screen sectio        n
                "Default Screen Section" for depth/fbbpp 24/32
        [    64.739] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
        [    64.739] (==) FBDEV(0): RGB weight 888
        [    64.743] (==) FBDEV(0): Default visual is TrueColor
        [    64.762] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
        [    64.763] (II) FBDEV(0): hardware: BCM2708 FB (video memory: 5120kB)
        [    64.763] (DB) xf86MergeOutputClassOptions unsupported bus type 0
        [    64.763] (II) FBDEV(0): checking modes against framebuffer device...
        [    64.763] (II) FBDEV(0): checking modes against monitor...
        [    64.764] (II) FBDEV(0): Virtual size is 1280x1024 (pitch 1280)
        [    64.764] (**) FBDEV(0):  Built-in mode "current"
        [    64.764] (==) FBDEV(0): DPI set to (96, 96)
        [    64.764] (II) Loading sub module "fb"
        [    64.764] (II) LoadModule: "fb"
        [    64.765] (II) Loading /usr/lib/xorg/modules/libfb.so
        [    64.787] (II) Module fb: vendor="X.Org Foundation"
        [    64.787]    compiled for 1.20.4, module version = 1.0.0
        [    64.787]    ABI class: X.Org ANSI C Emulation, version 0.4
        [    64.787] (**) FBDEV(0): using shadow framebuffer
        [    64.787] (II) Loading sub module "shadow"
        [    64.787] (II) LoadModule: "shadow"
        [    64.788] (II) Loading /usr/lib/xorg/modules/libshadow.so
        [    64.796] (II) Module shadow: vendor="X.Org Foundation"
        [    64.796]    compiled for 1.20.4, module version = 1.1.0
        [    64.801]    ABI class: X.Org ANSI C Emulation, version 0.4
        [    64.801] (II) UnloadModule: "modesetting"
        [    64.801] (II) Unloading modesetting
        [    64.838] (==) FBDEV(0): Backing store enabled
        [    64.845] (==) FBDEV(0): DPMS enabled
        [    64.847] (II) Initializing extension Generic Event Extension
        [    64.852] (II) Initializing extension SHAPE
        [    64.865] (II) Initializing extension MIT-SHM
        [    64.877] (II) Initializing extension XInputExtension
        [    64.888] (II) Initializing extension XTEST
        [    64.897] (II) Initializing extension BIG-REQUESTS
        [    64.905] (II) Initializing extension SYNC
        [    64.913] (II) Initializing extension XKEYBOARD
        [    64.921] (II) Initializing extension XC-MISC
        [    64.930] (II) Initializing extension SECURITY
        [    64.937] (II) Initializing extension XFIXES
        [    64.947] (II) Initializing extension RENDER
        [    64.955] (II) Initializing extension RANDR
        [    64.974] (II) Initializing extension COMPOSITE
        [    64.981] (II) Initializing extension DAMAGE
        [    64.992] (II) Initializing extension MIT-SCREEN-SAVER
        [    65.000] (II) Initializing extension DOUBLE-BUFFER
        [    65.007] (II) Initializing extension RECORD
        [    65.016] (II) Initializing extension DPMS
        [    65.025] (II) Initializing extension Present
        [    65.032] (II) Initializing extension DRI3
        [    65.035] (II) Initializing extension X-Resource
        [    65.042] (II) Initializing extension XVideo
        [    65.053] (II) Initializing extension XVideo-MotionCompensation
        [    65.054] (II) Initializing extension SELinux
        [    65.054] (II) SELinux: Disabled on system
        [    65.058] (II) Initializing extension GLX
        [    65.065] (II) AIGLX: Screen 0 is not DRI2 capable
        [    68.618] (II) IGLX: Loaded and initialized swrast
        [    68.620] (II) GLX: Initialized DRISWRAST GL provider for screen 0
        [    68.621] (II) Initializing extension XFree86-VidModeExtension
        [    68.628] (II) Initializing extension XFree86-DGA
        [    68.637] (II) Initializing extension XFree86-DRI
        [    68.641] (II) Initializing extension DRI2
        [   118.828] (II) Server terminated successfully (0). Closing log file.
          sdetweil @ebolisa
          @ebolisa i would rebuild the sd card and start again
          • ebolisaE Offline
            ebolisa @sdetweil
            @sdetweil I agree but which OS should I use? The lite one?
              sdetweil @ebolisa
              @ebolisa full desktop
              • ebolisaE Offline
                ebolisa @sdetweil
                @sdetweil Thank you! Finally got it going. I had to change the SD card.
                Now I can finally replace my P4 with the P0. The P4, along with the display, are causing heat related problems so, P0 to the rescue.
                Just FYI, I cannot hide the cursor and sudo apt-get install unclutter didn’t help.
                  sdetweil @ebolisa
                  @ebolisa in css/main.css body should have cursor:none
                  you are running chromium-browser, not electron, but should have been the same
                    sdetweil @ebolisa
                    @ebolisa pi0 doesnt have a lot of power, so beware running too much…
                    check swap space usage
                    free -m
                    to see if it needs to be made bigger
                    • ebolisaE Offline
                      ebolisa @sdetweil
                      @sdetweil Yes, I set swap to 1024. It’s slow but it works.
                      Thanks again!!
                        RushHour99
                        @sdetweil , I went through a fresh SD card install for a Pi Zero W. raspbian and then the raspberry.sh script via your github page. I believe everything completed without error.
                        However when Magic Mirror launches on reboot, I get a blank page indicating:
                        This site can’t be reached
                        localhost refused to connect
                        Any idea what to do to troubleshoot?
                          sdetweil @RushHour99
                          @rushhour99 is this with extra modules or just the base?
                          can u show the output of
                          pm2 logs --lines=100
                            RushHour99 @sdetweil
                            @sdetweil said in Installing on a Pi Zero:
                            This just the Magic Mirror base. I haven’t added any extra modules.
                            Unfortunately I cannot paste the pm2 logs output. When I try it gets caught in some sort of spam filter and won’t let me post.
                              @rushhour99 u can email to me… same userid on gmail
                              also attach /home/pi/install.log
                                @sdetweil Thanks, error log emailed. Ive done this process before without error ~9 months ago. Maybe the rasbian version or magic mirror version has changed recently that is now causing the problem.
                                  @rushhour99 there is a new MM version every 2 months…
                                  I test on my own pi 0 .
                                  haven’t seen a problem like this
                                  sent email back, can u send install.log
                                    @rushhour99 do this
                                    sudo npm i -g npm@6
                                    this will downgrade npm to v6
                                    then
                                    rm -rf node_modules
                                    rm package-lock.json
                                    npm install --only=prod
                                    and check if the config.js file exists
                                    ls ~/MagicMirror/config/config,js -laF
                                      sudo npm -i npm@6
                                      I got an error. Thanks for helping out, this is a new build so I don’t mind if it gets messed up and I need to start over.
                                      $ sudo npm -i npm@6
                                      npm ERR! code ENOENT
                                      npm ERR! syscall open
                                      npm ERR! errno -2
                                      npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                                      npm ERR! enoent This is related to npm not being able to find a file.
                                      npm ERR! enoent
                                      npm ERR! /root/.npm/_logs/2021-08-03T22_48_17_691Z-debug.log
                                        @rushhour99 typo, sorry
                                        sudo npm i -g npm@6
                                          @sdetweil Thanks!
                                          I copied the config.js.sample to config.js before running the downgrade commands.
                                          After downgrading and rebooting, the Magic Mirror showed up on my Pi 0 with the default configuration.
                                            @rushhour99 great, thanks for the update
                                            I pushed a change to the installer to prevent npm going to v7.
                                            • 8 / 9
