    Hello-Lucy Install Part 5 Unable to resolve dependency tree
    6 Posts 3 Posters 1.2k Views 3 Watching
      Desert Rat
      Re: Hello-Lucy installation troubles
      I’m new to the Forum and a have a problem installing Hello Lucy. I receive error messages, shown below, when running part 5 of the install.
      I followed all install instructions and verified my microphone and sound were working.
      Would appreciate any assistance on how to proceed to complete this installation.
      Thanks Desert-Rat
      From /home/pi/.npm/eresolve-report.txt
      npm resolution error report
      2021-02-15T21:37:19.700Z
      While resolving: Hello-Lucy@1.0.1
      Found: eslint@6.8.0
      node_modules/eslint
      dev eslint@“^6.8.0” from the root project
      Could not resolve dependency:
      peer eslint@“^3.19.0 || ^4.5.0” from eslint-config-airbnb-base@11.3.2
      node_modules/eslint-config-airbnb-base
      dev eslint-config-airbnb-base@“^11.0.1” from the root project
      Fix the upstream dependency conflict, or retry
      this command with --force, or --legacy-peer-deps
      to accept an incorrect (and potentially broken) dependency resolution.
      Raw JSON explanation object:
      “code”: “ERESOLVE”,
      “current”: {
      “name”: “eslint”,
      “version”: “6.8.0”,
      “whileInstalling”: {
      “name”: “Hello-Lucy”,
      “version”: “1.0.1”,
      “path”: “/home/pi/MagicMirror/modules/Hello-Lucy”
      “location”: “node_modules/eslint”,
      “dependents”: [
      “type”: “dev”,
      “name”: “eslint”,
      “spec”: “^6.8.0”,
      “from”: {
      “location”: “/home/pi/MagicMirror/modules/Hello-Lucy”
      “edge”: {
      “type”: “peer”,
      “name”: “eslint”,
      “spec”: “^3.19.0 || ^4.5.0”,
      “error”: “INVALID”,
      “from”: {
      “name”: “eslint-config-airbnb-base”,
      “version”: “11.3.2”,
      “version”: “1.0.1”,
      “location”: “node_modules/eslint-config-airbnb-base”,
      “dependents”: [
      “type”: “dev”,
      “spec”: “^11.0.1”,
      “from”: {
      “peerConflict”: null,
      “strictPeerDeps”: false,
      “force”: false
      From /home/pi/.npm/_logs/2021-02-15T21_37_19_723Z-debug.log
      0 verbose cli [ ‘/usr/bin/node’,
      0 verbose cli ‘/usr/local/bin/npm’,
      0 verbose cli ‘install’,
      0 verbose cli ‘–productive’ ]
      1 info using npm@7.5.2
      2 info using node@v10.23.1
      3 timing config:load:defaults Completed in 6ms
      4 timing config:load:file:/usr/local/lib/node_modules/npm/npmrc Completed in 7ms
      5 timing config:load:builtin Completed in 7ms
      6 timing config:load:cli Completed in 11ms
      7 timing config:load:env Completed in 1ms
      8 timing config:load:file:/home/pi/MagicMirror/modules/Hello-Lucy/.npmrc Completed in 1ms
      9 timing config:load:project Completed in 3ms
      10 timing config:load:file:/home/pi/.npmrc Completed in 1ms
      11 timing config:load:user Completed in 1ms
      12 timing config:load:file:/etc/npmrc Completed in 0ms
      13 timing config:load:global Completed in 0ms
      14 timing config:load:cafile Completed in 1ms
      15 timing config:load:validate Completed in 0ms
      16 timing config:load:setUserAgent Completed in 1ms
      17 timing config:load:setEnvs Completed in 4ms
      18 timing config:load Completed in 40ms
      19 verbose npm-session 34512379a9096347
      20 timing npm:load Completed in 80ms
      21 timing arborist:ctor Completed in 6ms
      22 timing arborist:ctor Completed in 0ms
      23 timing idealTree:init Completed in 100ms
      24 timing idealTree:userRequests Completed in 0ms
      25 silly idealTree buildDeps
      26 silly fetch manifest lmtool@2.0.3
      27 http fetch GET 200 https://registry.npmjs.org/lmtool 586ms
      28 silly fetch manifest pocketsphinx-continuous@git://github.com/mykle1/pocketsphinx-continuous-node.git
      29 silly fetch manifest eslint@^6.8.0
      30 http fetch GET 200 https://registry.npmjs.org/eslint 345ms
      31 silly fetch manifest eslint-config-airbnb-base@^11.0.1
      32 http fetch GET 200 https://registry.npmjs.org/eslint-config-airbnb-base 90ms
      33 silly fetch manifest eslint@^3.19.0 || ^4.5.0
      34 timing idealTree Completed in 3229ms
      35 timing command:install Completed in 3281ms
      36 verbose stack Error: unable to resolve dependency tree
      36 verbose stack at Arborist.[failPeerConflict] (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:1115:25)
      36 verbose stack at Arborist.[loadPeerSet] (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:1095:34)
      37 verbose cwd /home/pi/MagicMirror/modules/Hello-Lucy
      38 verbose Linux 5.10.11-v7l+
      39 verbose argv “/usr/bin/node” “/usr/local/bin/npm” “install” “–productive”
      40 verbose node v10.23.1
      41 verbose npm v7.5.2
      42 error code ERESOLVE
      43 error ERESOLVE unable to resolve dependency tree
      44 error
      45 error While resolving: Hello-Lucy@1.0.1
      45 error Found: eslint@6.8.0
      45 error node_modules/eslint
      45 error dev eslint@“^6.8.0” from the root project
      45 error
      45 error Could not resolve dependency:
      45 error peer eslint@“^3.19.0 || ^4.5.0” from eslint-config-airbnb-base@11.3.2
      45 error node_modules/eslint-config-airbnb-base
      45 error dev eslint-config-airbnb-base@“^11.0.1” from the root project
      45 error
      45 error Fix the upstream dependency conflict, or retry
      45 error this command with --force, or --legacy-peer-deps
      45 error to accept an incorrect (and potentially broken) dependency resolution.
      45 error
      45 error See /home/pi/.npm/eresolve-report.txt for a full report.
      46 verbose exit 1
      S Mykle1M 2 Replies Last reply Reply Quote 0
        sdetweil @Desert Rat
        @desert-rat what he said
                     v
          Mykle1 Project Sponsor Module Developer @Desert Rat
          @desert-rat
          Just verifying:
          Did you run npm install in the Hello Lucy folder? Normally, this would be correct, but not in this case.
          The proper way of installing dependencies for Hello Lucy are as follows:
          • cd into the Hello-Lucy/installers folder
          • run bash dependencies.sh
            Desert Rat
            Thanks for the quick Response. I followed the install process from
            github mykle1 /Hello-Lucy . The steps I followed areshown below.
            3 Step Installation
            Please complete all 3
            git clone https://github.com/mykle1/Hello-Lucy into the ~/MagicMirror/modules directory
            cd Hello-Lucy/installers
            Thanks Desert Rat
              Desert Rat
              Resolved
              As with most things in life it will take two things to get you in trouble. In this instance I experienced The Part 5 errors noted here. I spent a couple of day researching NPM before doing as indicated in the install error messages ( Change Production Value ). That change produced other warnings and I attempted to test but failed. In the end the install and Hello-Lucy worked as advertised. The second problem was a mini microphone.
              Thanks for the help!
                @desert-rat
                Actually, there was a dependency issue. It took me some time to figure out how to correct the issue. I took the simplest route. The issue was with the dev dependencies which are not necessary for Lucy to run but caused the installation of necessary dependencies to fail.
                I’ve removed the installation of the dev dependencies from the dependency installer. I trashed my installation of Lucy (and her dependencies) and did a fresh installation. Everything seems to be working correctly here now.
                Sorry for the long delay in investigating the problem.
