Hello-Lucy Install Part 5 Unable to resolve dependency tree
Re: Hello-Lucy installation troubles
I’m new to the Forum and a have a problem installing Hello Lucy. I receive error messages, shown below, when running part 5 of the install.I followed all install instructions and verified my microphone and sound were working.
Would appreciate any assistance on how to proceed to complete this installation.
Thanks Desert-Rat
From /home/pi/.npm/eresolve-report.txt
npm resolution error report
2021-02-15T21:37:19.700Z
While resolving: Hello-Lucy@1.0.1
Found: eslint@6.8.0
node_modules/eslint
dev eslint@“^6.8.0” from the root projectCould not resolve dependency:
peer eslint@“^3.19.0 || ^4.5.0” from eslint-config-airbnb-base@11.3.2
node_modules/eslint-config-airbnb-base
dev eslint-config-airbnb-base@“^11.0.1” from the root projectFix the upstream dependency conflict, or retry
this command with --force, or --legacy-peer-deps
to accept an incorrect (and potentially broken) dependency resolution.Raw JSON explanation object:
“code”: “ERESOLVE”,
“current”: {
“name”: “eslint”,
“version”: “6.8.0”,
“whileInstalling”: {
“name”: “Hello-Lucy”,
“version”: “1.0.1”,
“path”: “/home/pi/MagicMirror/modules/Hello-Lucy”
“location”: “node_modules/eslint”,
“dependents”: [
“type”: “dev”,
“name”: “eslint”,
“spec”: “^6.8.0”,
“from”: {
“location”: “/home/pi/MagicMirror/modules/Hello-Lucy”
“edge”: {
“type”: “peer”,
“name”: “eslint”,
“spec”: “^3.19.0 || ^4.5.0”,
“error”: “INVALID”,
“from”: {
“name”: “eslint-config-airbnb-base”,
“version”: “11.3.2”,
“version”: “1.0.1”,
“location”: “node_modules/eslint-config-airbnb-base”,
“dependents”: [
“type”: “dev”,
“spec”: “^11.0.1”,
“from”: {
“peerConflict”: null,
“strictPeerDeps”: false,
“force”: false
}From /home/pi/.npm/_logs/2021-02-15T21_37_19_723Z-debug.log
0 verbose cli [ ‘/usr/bin/node’,
0 verbose cli ‘/usr/local/bin/npm’,
0 verbose cli ‘install’,
0 verbose cli ‘–productive’ ]
1 info using npm@7.5.2
2 info using node@v10.23.1
3 timing config:load:defaults Completed in 6ms
4 timing config:load:file:/usr/local/lib/node_modules/npm/npmrc Completed in 7ms
5 timing config:load:builtin Completed in 7ms
6 timing config:load:cli Completed in 11ms
7 timing config:load:env Completed in 1ms
8 timing config:load:file:/home/pi/MagicMirror/modules/Hello-Lucy/.npmrc Completed in 1ms
9 timing config:load:project Completed in 3ms
10 timing config:load:file:/home/pi/.npmrc Completed in 1ms
11 timing config:load:user Completed in 1ms
12 timing config:load:file:/etc/npmrc Completed in 0ms
13 timing config:load:global Completed in 0ms
14 timing config:load:cafile Completed in 1ms
15 timing config:load:validate Completed in 0ms
16 timing config:load:setUserAgent Completed in 1ms
17 timing config:load:setEnvs Completed in 4ms
18 timing config:load Completed in 40ms
19 verbose npm-session 34512379a9096347
20 timing npm:load Completed in 80ms
21 timing arborist:ctor Completed in 6ms
22 timing arborist:ctor Completed in 0ms
23 timing idealTree:init Completed in 100ms
24 timing idealTree:userRequests Completed in 0ms
25 silly idealTree buildDeps
26 silly fetch manifest lmtool@2.0.3
27 http fetch GET 200 https://registry.npmjs.org/lmtool 586ms
28 silly fetch manifest pocketsphinx-continuous@git://github.com/mykle1/pocketsphinx-continuous-node.git
29 silly fetch manifest eslint@^6.8.0
30 http fetch GET 200 https://registry.npmjs.org/eslint 345ms
31 silly fetch manifest eslint-config-airbnb-base@^11.0.1
32 http fetch GET 200 https://registry.npmjs.org/eslint-config-airbnb-base 90ms
33 silly fetch manifest eslint@^3.19.0 || ^4.5.0
34 timing idealTree Completed in 3229ms
35 timing command:install Completed in 3281ms
36 verbose stack Error: unable to resolve dependency tree
36 verbose stack at Arborist.[failPeerConflict] (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:1115:25)
36 verbose stack at Arborist.[loadPeerSet] (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:1095:34)
37 verbose cwd /home/pi/MagicMirror/modules/Hello-Lucy
38 verbose Linux 5.10.11-v7l+
39 verbose argv “/usr/bin/node” “/usr/local/bin/npm” “install” “–productive”
40 verbose node v10.23.1
41 verbose npm v7.5.2
42 error code ERESOLVE
43 error ERESOLVE unable to resolve dependency tree
44 error
45 error While resolving: [1mHello-Lucy[22m@[1m1.0.1[22m
45 error Found: [1meslint[22m@[1m6.8.0[22m[2m[22m
45 error [2mnode_modules/eslint[22m
45 error [33mdev[39m [1meslint[22m@“[1m^6.8.0[22m” from the root project
45 error
45 error Could not resolve dependency:
45 error [35mpeer[39m [1meslint[22m@“[1m^3.19.0 || ^4.5.0[22m” from [1meslint-config-airbnb-base[22m@[1m11.3.2[22m[2m[22m
45 error [2mnode_modules/eslint-config-airbnb-base[22m
45 error [33mdev[39m [1meslint-config-airbnb-base[22m@“[1m^11.0.1[22m” from the root project
45 error
45 error Fix the upstream dependency conflict, or retry
45 error this command with --force, or --legacy-peer-deps
45 error to accept an incorrect (and potentially broken) dependency resolution.
45 error
45 error See /home/pi/.npm/eresolve-report.txt for a full report.
46 verbose exit 1 -
@desert-rat what he said
| v -
Just verifying:
Did you run
npm installin the Hello Lucy folder? Normally, this would be correct, but not in this case.The proper way of installing dependencies for Hello Lucy are as follows:
cdinto the Hello-Lucy/installers folder -
run
bash dependencies.sh
Thanks for the quick Response. I followed the install process from
github mykle1 /Hello-Lucy . The steps I followed areshown below.3 Step Installation
Please complete all 3git clone https://github.com/mykle1/Hello-Lucy into the ~/MagicMirror/modules directory cd Hello-Lucy/installers bash dependencies.shThanks Desert Rat
Resolved
As with most things in life it will take two things to get you in trouble. In this instance I experienced The Part 5 errors noted here. I spent a couple of day researching NPM before doing as indicated in the install error messages ( Change Production Value ). That change produced other warnings and I attempted to test but failed. In the end the install and Hello-Lucy worked as advertised. The second problem was a mini microphone.
Thanks for the help!
Actually, there was a dependency issue. It took me some time to figure out how to correct the issue. I took the simplest route. The issue was with the dev dependencies which are not necessary for Lucy to run but caused the installation of necessary dependencies to fail.
I’ve removed the installation of the dev dependencies from the dependency installer. I trashed my installation of Lucy (and her dependencies) and did a fresh installation. Everything seems to be working correctly here now.
Sorry for the long delay in investigating the problem.
