    MMM - NewsFeed Ticker Hangs
    40 Posts 4 Posters 16.9k Views 4 Watching
      @cowboysdude said in MMM - NewsFeed Ticker Hangs:
      Not sure let me try to load it and see what it does.
      I just installed it. Running for 10 minutes, flawlessly, using the default config entry.
      Nice module, Jim! :-)
      EDIT:
      It is NOT working properly. The 5 or 6 news items keep repeating
      M S 3 Replies Last reply Reply Quote 1
        Matthewlawson3 @Mykle1
        @mykle1 interesting.
        Like I said changed in the .css file the background to none and I also made a change in the speed of the ticker to 2000 in the MMM-NewsFeedTicker.js file. Could that be causing issues? Or maybe my Ars Technica addition is causing issues for some reason.
          Mykle1 Project Sponsor Module Developer @Matthewlawson3
          @matthewlawson3
          I don’t think it’s you. See my edited post
            @mykle1 said in MMM - NewsFeed Ticker Hangs:
            EDIT:
            Okay. At least I know it is not something I did.
            General question: How does one uninstall a module? Or do you just comment it or // it out?
            cowboysdudeC Mykle1M 2 Replies Last reply Reply Quote 0
            • cowboysdudeC Offline
              cowboysdude Module Developer @Matthewlawson3
              @matthewlawson3 You can delete it from your config entry and go to the MagicMirror/modules directory find the module and delete it so for example :
              MagicMirror/modules/MMM-Whatever
              You go to MagicMirror/modules
              then delete the MMM-Whatever directory…
              Gone!
                @matthewlawson3
                You can comment out the config entry or delete the entry.
                Easiest way to delete the module itself. Click your way to the modules folder, enter the modules folder, trash the MMM-NewsFeedTicker.
                cowboysdudeC M 2 Replies Last reply Reply Quote 0
                  @mykle1 I JUST said that…get off my toes LMAO
                    @cowboysdude
                    Hey, have you seen Jim these days? I wonder where he disappeared to.
                      @mykle1 Great question…I wonder where Robert is… or @strawberry-3-141 … I feel like a latch key kid…
                        @cowboysdude
                        Last online:
                        Jim - 24 days
                        Robert - Oct 2020
                          @mykle1 thank you!
                            sdetweil @Mykle1
                            @Matthewlawson3 the doc doesn’t mention it, but by default in only shows the 1st 5 items regardless of how many sources u have
                            to get all of them do
                            maxNewsItems: 0,
                            in the module config above the list of sources
                            ----- edit: i was incorrect… the list gets rebuilt each time , never mind
                            BUT ----- this causes a problem, the list is never cleared, so it continues to grow and grow
                            haven’t seen the hang yet… one possible source in fetcher.js,
                            comment out the items=[]; line as shown below
                            		reloadTimer = null;
                            		//items = [];
                            its the same name as the global , so there could confusion over which list to add to.
                              @sdetweil said in MMM - NewsFeed Ticker Hangs:
                              Thanks bro. I don’t even use this module. I was just trying to help out the user above. Hopefully, he’s paying attention and has read your suggestion.
                                sdetweil @Mykle1
                                @mykle1 fixed
                                  @mykle1 fixed
                                  Now I really hope he’s paying attention.
                                  Well done, bro. :thumbsup:
                                    sdetweil @Mykle1
                                    @mykle1 also sent him a dm…
                                      Matthewlawson3 @sdetweil
                                      @sdetweil Okay so the reason it hangs and doesn’t go to other sources is because of what exactly? Sorry just saw this and trying to get up to speed.
                                      I added the max news items where you said I think if I understand correctly (see config file below). I also changed the number to 0 inside the MMM-NewsFeedTicker.js.
                                      Where is the fetcher.js? Can’t find that file.
                                      The module keeps repeating NYT and USA Today and doesn’t move on to BBC or Ars Technica.
                                      	disabled: false,
                                      	module: "MMM-NewsFeedTicker",
                                      	position: "bottom_bar",
                                      	//classes: "day_scheduler",
                                      		maxNewsItems: 0,
                                      	    feeds: [
                                      			title: "New York Times",
                                      			url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml",
                                      			customLogo: "NYT_logo_rss_250x40.png"
                                      			title: "USA Today",
                                      			url: "http://rssfeeds.usatoday.com/UsatodaycomNation-TopStories",
                                      			customLogo: "RSS_Syndication_Logo-USATN.png"
                                      			title: "BBC World News",
                                      			url: "http://feeds.bbci.co.uk/news/world/rss.xml#",
                                      			customLogo: "bbc_news_120x60.gif"
                                      			title: "Ars Technica",
                                      			url: "http://feeds.arstechnica.com/arstechnica/technology-lab",
                                      			customLogo: "arstechnica.jpg"
                                      Mykle1M S 2 Replies Last reply Reply Quote 0
                                        @matthewlawson3
                                        Try this:
                                        Under the maxNewsItems that you just added to your config entry, add this
                                        updateInterval: 10 * 60 * 1000,
                                        The default is 1 minute, which effectively resets the module back to the beginning of the feeds. This will give it 10 minutes to display the feeds without resetting. Assuming this will work, adjust the time accordingly.
                                          Matthewlawson3
                                          @mykle1 Just added it. It brought the ticker to a crawl across the screen. Super slow.
                                            sdetweil @Matthewlawson3
                                            @matthewlawson3 never edit the module source file.use config.js to adjust the parma
                                            I loaded the module u referenced, and fetcher.js is in that folder
                                            no idea if it hangs yet. hasn’t for me.
