    Newsfeed Wrap with CSS
    13 Posts 3 Posters 4.8k Views 3 Watching
      schlittrix
      Hey,
      I’ve got a problem with the newsfeed-module.
      It works fine except the width, its too wide, so the text overwrites other modules. (newsfeed is centered).
      So .wrap doesn’t work.
      I tried it with CSS to fix the width, but than the “wrapped” text is still on the left side and not centered.
      Is there a possibility to center the “wrapped” text in the CSS-File or is there another option for me?
        Mykle1 Project Sponsor Module Developer @schlittrix
        @schlittrix
        From stackoverflow. I have not tested it.
        This should center the wrapped text as well. In custom.css file, add :
        text-align: center;
          schlittrix @Mykle1
          @mykle1
          Thank you. I tried this css-setup. The lengh is fine, but the center-function doesn’t work.
          newsfeed-desc { width: 700px; }
          text-align: center;
            sdetweil @schlittrix
            @schlittrix the text align has to be inside the bracesof the newsfeed class
              schlittrix @sdetweil
              @sdetweil ouh. I’m a beginner :D
              so this way?
              newsfeed-desc { width: 700px; text-align: center; }
                @schlittrix yes
                u can specify lots of style elements in a single class like that
                for readability you should put the contents on separate lines inside the braces
                like this
                newsfeed-desc {
                     width: 700px;
                     text-align: center;
                S 2 Replies Last reply Reply Quote 2
                  @sdetweil said in Newsfeed Wrap with CSS:
                  @schlittrix yes
                  like this
                  newsfeed-desc {
                       width: 700px;
                       text-align: center;
                  thank you so much :)
                  I will try this today in the evening
                    @schlittrix yes
                    like this
                    newsfeed-desc {
                         width: 700px;
                         text-align: center;
                    so i tried this step without success…
                    When I just have the “width”-line, the text is wrapped, but not centered.
                    But when I put in these code with text-align, nothing happend and the text is no more wrapped…
                    any ideas? :(
                      @schlittrix
                      try this
                      newsfeed-desc {
                          width: 700px;
                          display: flex;
                          justify-content: center;
                      from here https://stackoverflow.com/questions/6618648/can-overflow-text-be-centered
                        newsfeed-desc {
                        width: 700px;
                        display: flex;
                        Don’t know, maybe I’m stupid…
                        but it still doesn’t work…
                        this is my config-setup:
                                                module: "newsfeed",
                                                position: "bottom_bar",
                                                        feeds: [
        title: "Tagesschau",
        url: "https://www.tagesschau.de/xml/rss2/"
                                                        showSourceTitle: true,
                                                        showPublishDate: true,
                                                        broadcastNewsFeeds: true,
                                                        broadcastNewsUpdates: true,
                                                        showDescription: true,
                                                        wrapDescription: true
                        and this is the css-file:
                        newsfeed-desc {
                            width: 500px;
                            display: flex;
                          @schlittrix i don’t KNOW exactly how to make it work… I;m guessing as I haven’t played with this at all… SO… its quite possible it wouldn’t work…
                          i’ll try to get to this a little later today
                          so this works
                          .newsfeed-desc {
                              width: 500px;
                              position: absolute;
                              left: 37%;
                              text-align: center;
                          use this algorithm to calc the left edge
                          (((yy-xx)/2)/yy)*100
                          where xx is the width of your news area
                          and yy is the width of your screen
                          also, notice the leading dot (.) on the class name, this is required
                          one other thing… the align: center, aligns EVER line centered… so the 1st line won’t fill to the width …
                            @schlittrix thank you for posting this, I was testing on the next release, and there was a new bug in newsreader that I was able to submit fix for…
                              excellent!!! it works fine now :)
                              Thank you! Nice supporter :)
