    Newsfeed Wrap with CSS
    13 Posts 3 Posters 4.0k Views 3 Watching
      sdetweil @schlittrix
      @schlittrix the text align has to be inside the bracesof the newsfeed class
        schlittrix @sdetweil
        @sdetweil ouh. I’m a beginner :D
        so this way?
        newsfeed-desc { width: 700px; text-align: center; }
          @schlittrix yes
          u can specify lots of style elements in a single class like that
          for readability you should put the contents on separate lines inside the braces
          like this
          newsfeed-desc {
               width: 700px;
               text-align: center;
          S 2 Replies Last reply Reply Quote 2
            @sdetweil said in Newsfeed Wrap with CSS:
            @schlittrix yes
            like this
            newsfeed-desc {
                 width: 700px;
                 text-align: center;
            thank you so much :)
            I will try this today in the evening
              @schlittrix yes
              like this
              newsfeed-desc {
                   width: 700px;
                   text-align: center;
              so i tried this step without success…
              When I just have the “width”-line, the text is wrapped, but not centered.
              But when I put in these code with text-align, nothing happend and the text is no more wrapped…
              any ideas? :(
                @schlittrix
                try this
                newsfeed-desc {
                    width: 700px;
                    display: flex;
                    justify-content: center;
                from here https://stackoverflow.com/questions/6618648/can-overflow-text-be-centered
                  newsfeed-desc {
                  width: 700px;
                  display: flex;
                  Don’t know, maybe I’m stupid…
                  but it still doesn’t work…
                  this is my config-setup:
                                          module: "newsfeed",
                                          position: "bottom_bar",
                                                  feeds: [
        title: "Tagesschau",
        url: "https://www.tagesschau.de/xml/rss2/"
                                                  showSourceTitle: true,
                                                  showPublishDate: true,
                                                  broadcastNewsFeeds: true,
                                                  broadcastNewsUpdates: true,
                                                  showDescription: true,
                                                  wrapDescription: true
                  and this is the css-file:
                  newsfeed-desc {
                      width: 500px;
                      display: flex;
                    @schlittrix i don’t KNOW exactly how to make it work… I;m guessing as I haven’t played with this at all… SO… its quite possible it wouldn’t work…
                    i’ll try to get to this a little later today
                    so this works
                    .newsfeed-desc {
                        width: 500px;
                        position: absolute;
                        left: 37%;
                        text-align: center;
                    use this algorithm to calc the left edge
                    (((yy-xx)/2)/yy)*100
                    where xx is the width of your news area
                    and yy is the width of your screen
                    also, notice the leading dot (.) on the class name, this is required
                    one other thing… the align: center, aligns EVER line centered… so the 1st line won’t fill to the width …
                      @schlittrix thank you for posting this, I was testing on the next release, and there was a new bug in newsreader that I was able to submit fix for…
                        excellent!!! it works fine now :)
                        Thank you! Nice supporter :)
