    MMM-Spotify
    249 Posts 51 Posters 340.5k Views 54 Watching
      @sdetweil the mm aps show the music that is playing SOMEWHERE.
      some modules will let u stop/start/move play somewhere. not all 100% functional all the time
        Abstr @sdetweil
        @sdetweil ‘‘spotify doesnt care about not its platform’’, thats oke but my problem is switching between multiple spotify accounts.
        https://github.com/skuethe/MMM-Spotify
          sdetweil @Abstr
          @Abstr ok doc said u had to authorize each account in the order u set them up in the config json file
          did u get a request to allow for each account?
          never seen one work like this
            Abstr @sdetweil
            @sdetweil Yes, I got both both accounts allowed in the correct order. Username, ID’s and token work fine. I’ve setup two users in spotify.config.json like the sample below. The user which I put first in the spotify.config.json get to display the music in MagicMirror. The second user doesnt. No matter if I swap them.
            “USERNAME”: “AN NAME TO IDENTIFY THIS ACCOUNT”,
            “CLIENT_ID” : “PUT_YOUR_SPOTIFY_APP_CLIENT_ID”,
            “CLIENT_SECRET” : “PUT_YOUR_SPOTIFY_APP_CLIENT_SECRET”,
            “TOKEN” : “./username_token.json”
            “USERNAME”: “ANOTHER NAME TO IDENTIFY THIS ACCOUNT”,
            “TOKEN” : “./another_token.json”
            • L Offline
              lotman9000 @Abstr
              @Abstr you might be able to hardcode it within the MMM-Spotify.js file by adding
                    case "SPOTIFY_ACCOUNT_JONDOE":
                      this.sendSocketNotification("ACCOUNT","JONDOE")
                      break
              (e.g. after line 128) in order to create a notification that lets you address a specific account. Doesn’t allow toggling but might help you choosing a specific account. This should be the USERNAME from the spotify.config.json file.
                Abstr @lotman9000
                @lotman9000 Ill try. thank you!
                  razserv2010 @Guest
                  @sean
                  hey, try to
                  node first_auth.js
                  but i always get INVALID_CLIENT: Invalid redirect URI massage
                  and i get to my email that thare is new log in
                  what is the issue?
                    sdetweil @razserv2010
                    @razserv2010 sean has left mm for family reasons, now a year ago.
                    the was taken over by another user.
                    who is not here on these forums currently, see
                    http://forum.bugsounet.fr
                      crisvdn
                      Hi there,
                      I am currently using this module in combination with the GroveGesture module. I can use simple gesture commands (up, down, left, right etc).
                      I want to implement a solution to quickly switch between artists, playlists, tracks etc.
                      However, do you guys know if there’s a module that works well for this? I haven’t found anything like this just yet…
                      I am completely fine with adding the playlists hardcoded in the config file.
                      If this does not exist, I might consider making this as an addition to the MMM-Spotify module.
                      • L Offline
                        luizcarlosnery
                        Hello, thanks for this excellent module, I’ve been using it for some time but only now I came across a problem that I don’t know how to solve …
                        I need to hide another module when MMM-SPOTIFY is in play mode, and hide when MMM-SPOTIFY is in PAUSE.
                        Has as ?
                        • lavolp3L Offline
                          lavolp3 Module Developer @luizcarlosnery
                          @luizcarlosnery i haven’t looked in the code yet but a possibility might be too look if the spotify module sends notifications. If it does you might fetch these to hide your module using the notificationReceived function
                          How to troubleshoot modules
                          MMM-soccer v2, MMM-AVStock
                            skuethe
                            Hi everybody. I am the new owner of this module (as of last year October). I haven’t monitored these forums / this post for problems so far. If you do have technical problems with this module please be so kind to directly open an issue in the git repo:
                            https://github.com/skuethe/MMM-Spotify/issues
                            It makes working on issues a lot easier. Thanks!
                            As to some of the open topics / questions here of the last weeks:
                            • @Abstr @razserv2010 I’ve recently re-worked the multi user authentication and fixed some problems with it:
                              https://github.com/skuethe/MMM-Spotify/releases/tag/v2.0.1
                            • @crisvdn I am using it with MMM-Touch (which, of course, requires a touch screen) - it is a very powerful module
                            • @luizcarlosnery there is no direct option to do this. But you can definitely get something to work. There is a build-in config option to send custom notifications on suspend / resume:
                              notificationsOnSuspend and notificationsOnResume - see README for more details
                              You could, for example, use it in addition with MMM-pages which has some nice options to handle suspending / resuming special modules based on different pages
                            I hope that helps for now. I have some more fixes and improvements in the pipe that will be merged in the next comming weeks.
                            • L Offline
                              luizcarlosnery @lavolp3
                              @lavolp3 Thanks, but I managed to solve it by editing “Spotify.js” in play (param, cb) {
                              this.doRequest (“/ v1 / me / player / play”, “PUT”, null, param, cb)
                              pause (cb) {
                              this.doRequest (“/ v1 / me / player / pause”, “PUT”, null, null, cb)
                              I included the url commands for the remote control and solved the problem.
                              • lavolp3L Offline
                                @luizcarlosnery Hi @skuethe, first of all: great module.
                                I have set style: "mini" in my config which works well. However I have made some adjustments to picture size and text size in custom.css.
                                But I’m missing the scrolling title in this mode.
                                Also, what happens to minibar mode.
                                I understand you plan to remove that?
                                I have also corrected one issue resulting in an error if you’re not showing the account name, will send a PR on github for that.
                                  skuethe @lavolp3
                                  @lavolp3 Hey there. Thanks for the feedback.
                                  About the style: "mini" settings:
                                  • what adjustments did you do to the picture and text sizes? This is currently still an open topic on my side - so if it is some general improvement for the module feel free to also create a PR for that
                                  • I unfortunately don’t know what you exactly mean by “the scrolling title”. Could you elaborate?
                                  About the minibar mode:
                                  In my opinion this design breaks completely with the other two styles as it feels and looks completely different. In addition the implementation in the code is almost completely separated, which makes maintaining it an unnecessary effort.
                                  To be honest - I don’t even know if it is still working or if some of the changes in the past broke usage of it.
                                  I try to get feedback from people using it - if they want to keep it etc.
                                  About the account name issue:
                                  Great thanks - looking forward for your PR
                                  lavolp3L 2 Replies Last reply Reply Quote 0
                                  • lavolp3L Offline
                                    lavolp3 Module Developer @skuethe
                                    @skuethe
                                    Module looks like this for me know
                                    width a width of 500.
                                    You see it here. I’d need to see the rest of the title. It could scroll. That is already implemented in the minibar I think.
                                    Also, Volume is always at 100% for me. Played from the android app. API issue?
                                    • lavolp3L Offline
                                      lavolp3 Module Developer @lavolp3
                                      @lavolp3 said in MMM-Spotify:
                                      Confirmed API issue. Spotify API returns volume 100%, which is not the case in the app itself. Unfortunately.
                                      Am I the only one having this issue?
                                      • lavolp3L Offline
                                        @skuethe said in MMM-Spotify:
                                        My suggestions , generally as well as for mini mode:
                                        • font sizes are hardcoded here, I would rather use the MM classes as reference from main.css. Meaning: giving the module and sub-elements a class “small”, “xsmall” by including the config option classes. I have done that already and works well.
                                        • adjustable cover size.
                                        • option to hide module when nothing is played
                                        • spotify label small and more dimmed (like in MMM-NowPlayingOnSpotify
                                        All of the above is not difficult to manage I guess.
                                        A problem with the module is in my point of view the coding. It’s difficult for me to adept to sean’s style, e.g. leaving semicola completely out, indenting only with 2 spaces. But tha can be managed of course
                                        Let me know what you like to see as PR
                                          skuethe @lavolp3
                                          Interesting. I have no issues with volume display and even the volume control (via touch). Works fine on all the different devices - haven’t tried android though.
                                          Feel free to submit a PR for all those topics if you see them as a valid improvement!
                                            skuethe
                                            Just released a new version of the module, which improves usage for systems without UI (running in a container f.e.):
                                            https://github.com/skuethe/MMM-Spotify/releases/tag/v2.1.0
                                            As there are updated dependencies, be sure to execute
                                            git pull && npm install
                                            inside the MMM-Spotify folder.
                                            Again, if anybody is running into problems, please open issues in the github repo.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 12 / 13
