    [MMM-JaST] Just another Stock Ticker (new: version 2.x)
    166 Posts 37 Posters 227.1k Views 39 Watching
    • JalibuJ Offline
      Jalibu Module Developer @BravoOscar
      @bravooscar
      Well, the word “install” is fuzzy…
      You don’t need to uninstall your old one and even your configuration is compatible.
      You can switch between them by just changing the branch.
      In your modules/MMM-Jast folder execute
      Switch to Yahoo test branch:
      git fetch
      git checkout feat/useYahoo
      npm i
      Switch back to stable master:
      git checkout master
        BravoOscar @Jalibu
        @jalibu
        pi@raspberrypi:~/MagicMirror/modules/MMM-Jast $ git fetch
        From https://github.com/jalibu/MMM-Jast
           1cd91dc..c18758f  master        -> origin/master
         * [new branch]      feat/useYahoo -> origin/feat/useYahoo
         * [new tag]         v1.1.0        -> v1.1.0
         * [new tag]         v1.2.0        -> v1.2.0
        pi@raspberrypi:~/MagicMirror/modules/MMM-Jast $ git checkout feat/useYahoo
        error: Your local changes to the following files would be overwritten by checkout:
        	MMM-Jast.css
        	MMM-Jast.js
        Please commit your changes or stash them before you switch branches.
        Aborting
        pi@raspberrypi:~/MagicMirror/modules/MMM-Jast $ npm i
        > magicmirror@2.14.0 install /home/pi/MagicMirror
        " && cd vendor && npm install --loglevel=error
        audited 24 packages in 1.694s
        It looks like there is a error when using “git checkout feat/useYahoo”.
        Now the alert message on MM says there is a update for MMM-Jast
          BravoOscar @BravoOscar
          @bravooscar @jalibu
          Branch 'feat/useYahoo' set up to track remote branch 'feat/useYahoo' from 'origin'.
          Switched to a new branch 'feat/useYahoo'
          npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
          added 262 packages from 267 contributors and audited 263 packages in 33.609s
          35 packages are looking for funding
            run `npm fund` for details
          found 0 vulnerabilities
          I removed MMM-Jast folder, and did a clean install of MMM-Jast.
          Then I did this
          git fetch
          npm i
          Everythink works now, and also one of my stocks that was not available before.
          Good work!
          Think is should be made as master, maby make a config option, so its possible to cange from Yahoo to the other one.
          • earnestrichardsE Offline
            earnestrichards
            I guess I’ve done something wrong…
            I copied the link, installed to my modules folder, ran the “npm i” command, and updated my config .js file
            			module: "MMM-Jast",
            				maxWidth: "100%",
            				updateIntervalInSeconds: 300,
            				fadeSpeedInSeconds: 3.5, // Higher value: vertical -> faster // horizontal -> slower
            				scroll:"none", // "<none, vertical, horizontal>",
            				showChangePercent: true,
            				showChangeValue: false,
            				showChangeValueCurrency: false,
            				showDepotGrowth: false,
            				stocks: [
            					{ name: "FFFEX", symbol: "FFFEX",quantity: 1},
            					{ name: "FFFDX", symbol: "FFFDX", quantity: 1},
            					{ name: "PLFJX", symbol: "PLFJX", quantity: 1}
            					// { name: "DJIA", symbol: "DJIA"}
            JalibuJ 1 Reply Last reply Reply Quote 0
            • JalibuJ Offline
              Jalibu Module Developer @earnestrichards
              @earnestrichards I sent you a PM.
              I think you are not on the feat/useYahoo branch.
              No matter. I have now made the feature branch the master.
              • K Offline
                Koert 0
                Hi @jalibu ,
                It works (for the most of my Stocks). The ticker is showing me the correct value but not an increase/decrease in percent (for 2 of 10 stocks).
                can you help me with this error message?
                thank you in advance!
                0|mm       | [31.03.2021 11:25.10.250] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:58
                0|mm       | 			stocks: [
                0|mm       | 			^^^^^^
                0|mm       |
                0|mm       | SyntaxError: Unexpected identifier
                0|mm       |     at Module._compile (internal/modules/cjs/loader.js:896:18)
                0|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:986:10)
                0|mm       |     at Module.load (internal/modules/cjs/loader.js:816:32)
                0|mm       |     at Module._load (internal/modules/cjs/loader.js:728:14)
                0|mm       |     at Function.Module._load (electron/js2c/asar.js:748:26)
                0|mm       |     at Module.require (internal/modules/cjs/loader.js:853:19)
                0|mm       |     at require (internal/modules/cjs/helpers.js:74:18)
                0|mm       |     at loadConfig (/home/pi/MagicMirror/js/app.js:70:12)
                0|mm       |     at App.start (/home/pi/MagicMirror/js/app.js:217:3)
                0|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:129:7)
                0|mm       | [31.03.2021 11:25.11.849] [WARN]  (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently "false".  It will change to be "true" in Electron 9.  For more information please check https://github.com/electron/electron/issues/18397
                0|mm       | [31.03.2021 11:28.30.123] [WARN]  (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently "false".  It will change to be "true" in Electron 9.  For more information please check https://github.com/electron/electron/issues/18397
                0|mm       | [31.03.2021 11:34.45.284] [WARN]  (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently "false".  It will change to be "true" in Electron 9.  For more information please check https://github.com/electron/electron/issues/18397
                0|mm       | [31.03.2021 11:41.15.680] [WARN]  (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently "false".  It will change to be "true" in Electron 9.  For more information please check https://github.com/electron/electron/issues/18397
                  earnestrichards
                  :man_facepalming: As I have read so many times here on the forum… Read. The. Instructions. Thanks!!!
                    jack819
                    I am very new to all of this but have been able to install every module so far. I had the old one working fine until the other day when it would not update the stocks. Then I discovered it was updated so I removed the old one and installed the new one as directed. I copied the config file directly to the config.js but I keep getting an error. When I run the config check it keeps coming back as below:
                    pi@raspberrypi:~/MagicMirror $ npm run config:check
                    > magicmirror@2.14.0 config:check /home/pi/MagicMirror
                    > node js/check_config.js
                    [01.04.2021 06:41.32.155] [INFO]  Checking file...  /home/pi/MagicMirror/config/config.js
                    [01.04.2021 06:41.32.210] [ERROR] Your configuration file contains syntax errors :(
                    [01.04.2021 06:41.32.212] [ERROR] Line 109 col 3 Parsing error: Unexpected token stocks```
                    Any ideas? Like I said, the config file is copied right from the sample. Line 109 is the stocks : [ line from the sample.
                    S JalibuJ 2 Replies Last reply Reply Quote 0
                      sdetweil @jack819
                      @jack819 is there a comma on the end of line 108?
                        jack819 @sdetweil
                        There was not a comma (like I said, I am new to this). I did add one but now I just get a black screen when I start Magic Mirror. Nothing seems to load.
                          sdetweil @jack819
                          @jack819 and when u look at the messages in the window where u started MM???
                          did u do an npm install in the module folder after git clone?
                            @jack819 said in [MMM-JaST] Just another Stock Ticker (new: version 2.0.0):
                            I see the instructions do not say to change to the module folder before doing the npm i
                            I submitted an issue to the modules github repo
                              jack819
                              Bear with me, I am new to this:
                              I got to the modules folder in terminal, copied the git command, hit enter. Once that happened, I typed in the npm i command. It appears it was still in the module folder.
                                sdetweil @jack819
                                @jack819 to install a module (read the link below in my signature)
                                cd ~/MagicMirror/modules
                                git clone   url from module
                                cd module_name
                                npm i
                                you need the module folder to be the current folder to do the dependency install
                                  RIKKO14
                                  I am French.
                                  Since The data is now fetched from Yahoo’s finance API. I would like to try again to install this module but beforehand I would like to know how we find the symbols for the stocks ​​we want to have and present them like this:
                                  {name: “BASF”, symbol: “BAS.DE”, quantity: 10},
                                  {name: “SAP”, symbol: “SAP.DE”, quantity: 15},
                                  {name: “Henkel”, symbol: “HEN3.DE”},
                                  {name: “Alibaba”, symbol: “BABA”}
                                  The stocks ​​that interest me are:
                                  CAC 40
                                  Dow jones
                                  Euro stoxx 50
                                  Crédit Agricole.
                                  Thank you
                                    RIKKO14
                                    I tried to install this module with the stocks in examples but I had a problem of “Electron rebuild” because of black screen, I do not know how to make an “electron rebuild” so I deleted the module and the modules of my MM reappeared.
                                    how to do an “electron rebuild”?
                                    • JalibuJ Offline
                                      Jalibu Module Developer @RIKKO14
                                      Bonjour @rikko14,
                                      an easy way to get your Stock Symbols is as follows:
                                      • Open https://finance.yahoo.com and just search for your favorite stocks (i.e. BMW)
                                      • Click on Search result
                                      • URL should now be like https://finance.yahoo.com/quote/BMW.DE?p=BMW.DE&.tsrc=fin-srch where BMW.DE is the symbol.
                                      This module should not cause any problems with Electron. But there was a mistake in the installation documentation. Please make sure to change into the MMM-Jast module’s folder before you execute the “npm i” command. Please check the latest installation instructions, as they are now fixed.
                                      • JalibuJ Offline
                                        Jalibu Module Developer @jack819
                                        @jack819 That was my mistake in the documentation. It is fixed now.
                                        uros76U 1 Reply Last reply Reply Quote 0
                                        • uros76U Offline
                                          uros76 @Jalibu
                                          @jalibu
                                          This is an awesome module, thanks!
                                          Is there a way to cut away decimal numbers on displayed asset price? I have limited space on my MM display and don’t need to see decimals…
                                          • JalibuJ Offline
                                            Jalibu Module Developer @uros76
                                            @uros76
                                            I liked your idea and added this feature. Please checkout the latest version and check the README for instructions for your configuration.
                                            Please let me know if you’re facing any issues, as I did not have the time for extensive testing.
                                            Changes v.2.1.0
                                            • You can now configure the number of decimals for stock values (default: 2) and percentages (default: 1)
                                            • Decimal separator symbols are now localized by the browser’s locale, as most of the countries use a comma instead of a dot.
                                            • The stock’s name field is optional now. If it is not set, the stock’s official trade name will be used.
                                            • 3 / 9
