    [MMM-JaST] Just another Stock Ticker (new: version 2.x)
    166 Posts 37 Posters 243.5k Views 39 Watching
    • JalibuJ
      Jalibu Module Developer @RIKKO14
      Bonjour @rikko14,
      an easy way to get your Stock Symbols is as follows:
      • Open https://finance.yahoo.com and just search for your favorite stocks (i.e. BMW)
      • Click on Search result
      • URL should now be like https://finance.yahoo.com/quote/BMW.DE?p=BMW.DE&.tsrc=fin-srch where BMW.DE is the symbol.
      This module should not cause any problems with Electron. But there was a mistake in the installation documentation. Please make sure to change into the MMM-Jast module’s folder before you execute the “npm i” command. Please check the latest installation instructions, as they are now fixed.
      • JalibuJ
        Jalibu Module Developer @jack819
        @jack819 That was my mistake in the documentation. It is fixed now.
        uros76U 1 Reply Last reply Reply Quote 0
        • uros76U
          uros76 @Jalibu
          @jalibu
          This is an awesome module, thanks!
          Is there a way to cut away decimal numbers on displayed asset price? I have limited space on my MM display and don’t need to see decimals…
          JalibuJ 1 Reply Last reply Reply Quote 0
          • JalibuJ
            Jalibu Module Developer @uros76
            @uros76
            I liked your idea and added this feature. Please checkout the latest version and check the README for instructions for your configuration.
            Please let me know if you’re facing any issues, as I did not have the time for extensive testing.
            Changes v.2.1.0
            • You can now configure the number of decimals for stock values (default: 2) and percentages (default: 1)
            • Decimal separator symbols are now localized by the browser’s locale, as most of the countries use a comma instead of a dot.
            • The stock’s name field is optional now. If it is not set, the stock’s official trade name will be used.
            • uros76U
              uros76 @Jalibu
              @jalibu you sir are a legend! Thanks a lot for such quick implementation of decimals idea. I just pulled the latest version and it works. Virtual beer for you :beer_mug:
              • JalibuJ
                The latest version has some major improvements for localizations in number formatting (i.e $123.45 en-US vs. 123,45 EUR de-DE)
                Please check it out and let me know if you‘re facing issues.
                • MartinLoidoltM
                  MartinLoidolt
                  Hello Jalibu,
                  first and foremost i want to say that your module is very nice.
                  But I want to ask you if it is possible to show the whole depot and not just the growth?
                  Furthermore it would be nice to have the option to disable the color.
                  Thanks for your Work!
                  • JalibuJ
                    Jalibu Module Developer @MartinLoidolt
                    @martinloidolt
                    Thank you for your comment and your ideas.
                    I’ll add this as soon.
                    • L
                      Leijoh @Jalibu
                      @jalibu
                      Hello! Love your module;) Maybe the almighty might be able to help me out a little?
                      i cant seem to be able to standard a header?
                      Have tried the following without any result.
                      module: "MMM-Jast",
                      header: 'Finanser',
                      module: "MMM-Jast",
                      header: '"Finanser",
                      Any ideas would be much appreciated :)
                      • JalibuJ
                        Jalibu Module Developer @Leijoh
                        @leijoh said in [MMM-JaST] Just another Stock Ticker (new: version 2.0.0):
                        Hi @Leijoh,
                        you can rely on the almighty! There indeed was a problem with the header setting which was fixed in the latest 2.3.0 release.
                        @martinloidolt said in [MMM-JaST] Just another Stock Ticker (new: version 2.0.0):
                        Hi @MartinLoidolt,
                        I picked up both of your feature requests and put them in the latest 2.3.0 release, too.
                        • L
                          Leijoh @Jalibu
                          @jalibu said in [MMM-JaST] Just another Stock Ticker (new: version 2.0.0):
                          Hi @Leijoh,
                          The ALMIGHTY has provided! Thanks alot:)
                          • G
                            gpaquin
                            Hello Everyone!
                            I’m currently trying to install and use this module but when I start it, it says “undefined” and I have no clue of what’s going on… I follow exactly the instruction but… I can’t make it work. Am I missing something?
                            Thank You!
                            • JalibuJ
                              Jalibu Module Developer @gpaquin
                              @gpaquin please send me a PN to provide more information
                                morphisto
                                Hi, is it possible to increase the font size? Often I have wear no glasses if I`m in my bath room after showering - and I need a bigger font size without glasses…
                                • uros76U
                                  uros76 @morphisto
                                  @morphisto said in [MMM-JaST] Just another Stock Ticker (new: version 2.0.0):
                                  You can do that with CSS.
                                  https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works
                                    morphisto @uros76
                                    @uros76 I know how css works - but i cannot find the right class in the Jast Module to change the font size. Therefore I asked the developer if there is a chance to to it?
                                    S JalibuJ 2 Replies Last reply Reply Quote 0
                                      sdetweil @morphisto
                                      @morphisto see https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1622084388280
                                      you can discover what you need to know
                                      • JalibuJ
                                        Jalibu Module Developer @morphisto
                                        @morphisto
                                        you should be fine by just adding
                                        .jast-wrapper {
                                        --size: 2.0rem;
                                        to your custom css
                                          morphisto @Jalibu
                                          –size: 2.0rem;
                                          Thank You!
                                          • JalibuJ
                                            Dear user of this module,
                                            so far, the wording around the portfolio function was incorrect/misleading, as I incorrectly used the German term “Depot” for that.
                                            In the latest version the translation should be clearer.
                                            Attention: Due to the renaming, configuration properties have also changed. Temporarily old AND new properties are supported, but in future versions I will only support the new ones. So, please update your config.
                                            • 3 / 9
