    MMM-CalendarExt2
    486 Posts 83 Posters 1.1m Views 83 Watching
    • mrjdarM
      mrjdar @nitewing76
      @nitewing76 Perfect thanks for the info! Sounds like that should make her happy and let me keep this up in the house :grinning_face_with_sweat:
      Reply Quote 2
        rmcelwee @mrjdar
        @mrjdar said in MMM-CalendarExt2:
        Got CalendarExt2 up and running without a hitch. Hoping there’s a way to show a second month right next to it. Any ideas?
        I set mine up to display weekly format, 6 weeks, starting with the current week. So, 50% of the time it will actually display more “future” days than what you are wanting to do. Would that help?
        mrjdarM 1 Reply Last reply
        • mrjdarM
          mrjdar @rmcelwee
          @rmcelwee Yep that’s what I ended up going with after messing around with it some
          • mrjdarM
            mrjdar
            Hi again all. I was messing around with this and reading more of the documentation and came across a nice solution for my previous post (kind of on accident). I have this:
            views: [
               position: "bottom_left",
               mode: "month",
               position: "bottom_right",
               mode: "month",
               fromNow: "1",
            In short it shows you the current month on the left, and the next month on the right. Works perfect for our needs!
            BKeyportB 1 Reply Last reply
            • BKeyportB
              BKeyport Module Developer @mrjdar
              Anyone know the transform function rather well?
              I want to change the name on my calendar items from the actual title, to a generic “Appointment”.
              I’m pretty sure it’s a transform, I’m just not sure how to do it.
              Thanks!
                djpoirrier
                I’m trying to have a ‘daily’ view where in the morning it shows all of the items for today, and in the evening it shows all of the items for tomorrow. I know i have to make two different ‘views’ and two different ‘scenes’, but what i am struggling with is how to actually change them. I saw in the github that you can do this either on a set period with the ‘rotateInterval’ command but also with a notification or other trigger. How would i go about doing so with the notification or other trigger? Any documentation out there about that?
                Thanks,
                Devin
                D 1 Reply Last reply
                  djpoirrier @djpoirrier
                  Well i ended up figuring out how to do this a couple hours after this post, so i figured I would share in case anyone else wanted to do the same. I used MMM-ModuleScheduler. Basically you can set certain times to send out a notification that MMM-CalendarExt2 recognizes. Heres my config:
                  	module: "MMM-ModuleScheduler",
                  		notification_schedule: [
                  				notification: "CALEXT2_SCENE_CHANGE",
                  				schedule: "0 12 * * *",  //Schedule time based on crontab.guru
                  				payload: {
                  					type: "name",
                  					key: "Afternoon Scene"
                  				schedule: "0 0 * * *",  //Schedule time based on crontab.guru
                  				payload: {
                  					type: "name",
                  					key: "Morning Scene"
                  You can set up as many scheduled notifications as you’d like. You can see here that, based on crontab scheduling, I am set up to change the scene at Midnight and at noon. The payload key value is the name of the scene you’d like to switch to. You can see other options on CalExt2 notifications here.
                  R 1 Reply Last reply
                    rmcelwee @djpoirrier
                    @djpoirrier said in MMM-CalendarExt2:
                    I’d like to see a picture of what this looks like.
                    • L
                      luke1
                      Hi, i have a problem with my scanInterval I want it to update every 2 hours but it keeps updating every minute. (disappears for one second)
                      I already tried different time formats but it didn’t work.
                      Thanks,
                      Luke
                      module: 'MMM-CalendarExt2',
                                                      calendars : [
        url: „***********“,
        scanInterval: 7200000, (already tried: 1000*60*60*2, 2*60*60*1000, )
        url: „***********",
        url: „**********"
                                                      views: [
        mode: "week",
        calendars: [],
        hideOverflow: false,
        position: "bottom_bar",
        slotCount: 3,
        filterPassedEvent: true,
        locale: "de-DE",
        mode: "upcoming",
        maxItems: 5,
        maxDays: 7,
        locale: "de-DE",
                                                      scenes: [
                      • V
                        Vandrasky
                        • BKeyportB
                          BKeyport Module Developer @luke1
                          @luke1 I believe it refreshes every minute anyway, but don’t ping the servers for the time you specify. If you want it to stop animating as a stopgap, you can use this:
                          /* Stop animating */
                          .CX2.hidden {
                            display: block;
                            opacity: 1;
                            animation-name: none;
                            animation-iteration-count: 0;
                            animation-timing-function: none;
                            animation-duration: 0s;
                          .CX2.shown {
                            display: block;
                            opacity: 1;
                          L 1 Reply Last reply
                          • L
                            luke1 @BKeyport
                            @bkeyport Thanks a lot! :)
                            • V
                              Vandrasky
                              Hi
                              Just wondering if it’s possible to change the date format in the upcoming view.
                              Its currently giving me how many days until the event. I’m looking for the date of the event.
                              I’ve tried (useEventTimeRelative: “false”)
                              any other thoughts?
                              Jeremy
                              • A
                                almightyyoshi
                                Is there a way to show the next month in the “month” view? I want to rotate between the current month and next month. If it can be done, is there a way to show it without having to manually filter it each month (i.e filter = currentMonth + 1 … or something like that)?
                                A 1 Reply Last reply
                                • A
                                  almightyyoshi @almightyyoshi
                                  @almightyyoshi NM. I was way overthinking that. Found the “fromNow” setting.
                                    Marva82 @BKeyport
                                    @bkeyport
                                    That is not correct. If you want to get rid of the week count create a css/custom.css file, never change the main.css! And add this line
                                    .CX2 .weeksmark {
                                    display:none;
                                    • BKeyportB
                                      BKeyport Module Developer @Marva82
                                      @marva82 My statement was functionally correct. Yeah, I forgot to use the overused “Use custom.css” mantra
                                      (Which in this case, don’t really matter, as if you’d adjust MMM-CX2’s css stub, it’ll likely never get overwritten as the projects effectively dead)
                                      And yes, you can remove the Week of the year with your stub.
                                        debaetstony
                                        Apparently I’m still using MMM-CalendarExt (which is archived) on my old configured MM, so I wanted to update it.
                                        After a while with MMM-CalendarExt2 I still have an issue.
                                        I don’t get the ‘Today’ and ‘Tomorrow’ in Dutch, also keep giving the date ‘month day’ instead of day/month.
                                        Additional question;
                                        I know that with following you hide the week numbers
                                        .CX2 .weeksmark {
                                           display: none;
                                        • But how can you remove the block so that the empty space disappears.
                                        • Also how do you get less space between the ‘Today / Tomorrow / next days’
                                        • Is it possible to see the entire appointment in ‘month’ view, even on multiple lines?
                                          alt text
                                          SARCux @debaetstony
                                          @debaetstony
                                          hi,
                                          these are my lines in the config.js
                                          views: [
                                          				mode: "daily",
                                          				title: "Termine nächsten Tage",
                                          				position: "top_center",
                                          				locale: "de-DE",
                                          				calendars: ["eigene Kalender eintragen"],
                                          				slotCount: 3,
                                          				slotTitleFormat: {
                                          						sameDay: "[Heute]",
                                          						nextDay: "[Morgen]",
                                          						nextWeek: "[am] dddd",
                                          						lastDay: "[Gestern]",
                                          						lastWeek: "[letzte] ddd",
                                          						sameElse: "DD.MM."
                                            sdetweil @SARCux
                                            @sarcux the doc seems to suggest where you have
                                            sameDay: "[Heute]",
                                            you could have the date format too
                                            sameDay: "[Heute]  D, MMM",
                                            you do that on lastWeek
                                            formatting options
                                            https://devhints.io/moment
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 20 / 25
