    MMM-Fitbit2
    Scheduled Pinned Locked Moved Health
    fitbithealthfitnesshealthywaterfoodtrackingactivity tracker
    98 Posts 21 Posters 173.6k Views 19 Watching
    • goldyfruitG Offline
      goldyfruit Project Sponsor @aunrea
      @aunrea I have the same behavior with a second account, like if some cache was used.
      My workaround was to clone the repository on my laptop (not on my RPi) and run the Python script from there and then copy/paste the tokens-XXXXX.json file to my RPi.
      Build smart things with magic and love! | https://smartgic.io
        goldyfruit Project Sponsor @mkufner24
        @mkufner24 Same, sleep time is inaccurate.
        • V Offline
          Vizulize Module Developer @goldyfruit
          @goldyfruit said in MMM-Fitbit2:
          @Vizulize It would be great it you could allow the issue creation on GitHub, this will be easier to contribute and raise issue. :)
          Done!
          • V Offline
            Unfortunately, this is what is returned from the Fitbit API. If you can figure out how to produce the data you want from what is returned from the API, then I am happy to take a look!
              davidgeo
              Is it possible to display weight in pounds instead of kg? If yes, how?
              • V Offline
                Vizulize Module Developer @davidgeo
                @davidgeo
                This is currently not exposed to the user via the config.json (that feature is tracked here).
                However, you can change this option to “US” in your installed module directory.
                For more information about how units are handled by the Fitbit API, check out the unit system information detailed here.
                • TipponT Offline
                  Tippon
                  Sorry for replying to an old topic, but I thought it was best to keep this in the same place.
                  I realised today that I’m having a problem with MMM-fitbit2. I fixed the issue in my other thread here yesterday:
                  https://forum.magicmirror.builders/topic/14879/mmm-fitbit2-pythonshell-is-not-a-constructor?_=1617917654075
                  but updated Magic Mirror shortly after, so I’m not sure if the problem existed before the update or not.
                  The module loads and seems to work, but I’m only getting values returned for the calories I’ve burned water drank, and my weight. My food eaten isn’t updating, even though it’s showing in my Fitbit dashboard. I don’t have a Fitbit device so I’m not sure if the other values are flled in on my dashboard.
                  Please forgive me if I’m slow to reply, I’m currently experiencing memory issues, and sometimes forget that I’ve asked a question >.<
                  • V Offline
                    Vizulize Module Developer @Tippon
                    @tippon Hopefully this is fixed: https://github.com/m-roberts/MMM-Fitbit2/commit/e958665dcf63900d38f5405961a1a176d5ba2fcf
                    TipponT 1 Reply Last reply Reply Quote 0
                      JohnGalt
                      I would love to try this module, but at stuck at the starting block of creating an app on the Fitbit site… When I go to Settings -> Applications on the FitBit site there is a place where it would list the authorized applications, but does not allow creation of a new application. I tried in Firefox and Chrome, but get the same output. My web searching seems to indicate most of the results are adding an app to the actual FitBit wearable, not to the account. This is an older ‘Alta’ model, and it has no fancy bells and whistles - just basic tracking which DOES show up on the FitBit web site. I feel like I am missing something very basic, but am just not seeing it.
                        sdetweil @JohnGalt
                        @johngalt u are going here, https://dev.fitbit.com/apps/new, right??
                        have to go to the DEV site not normal fitbit.com
                          JohnGalt @sdetweil
                          @sdetweil: THANKS, I knew it was something simple… I guess i read the instructions [“Go to Fitbit …”] and just went to Fitbit, using my usual approach of launching it via my password manager. When I instead went to the dev site, it was straightforward to create an app. Thanks again!
                          • TipponT Offline
                            Tippon @Vizulize
                            @vizulize said in MMM-Fitbit2:
                            Thank you :)
                            It seems to have solved the Python issue, but I’m still not seeing the calories I’ve eaten.
                            I’m really sorry. Please ignore me, I’m an idiot! :confounded_face:
                            I just noticed on the log that there was no figure set for my calorie goal, so I went through my profile on the Fitbit site, and the calorie goal wasn’t listed there either. I set it up sometime last year when I originally started trying to diet, but for some reason, the goal has gone and I have no idea why. It still shows up on my phone as I’ve got everything linked to everything else, so it must be populated from another app.
                            I feel like a muppet, but on the bright side, I’ve probably just burned of a few hundred calories just from embarrassment :beaming_face_with_smiling_eyes:
                            • TipponT Offline
                              Tippon
                              Sorry to be a pain, but my calories in is wrong again. I set a goal of 1,400 calories per day after my last post, and entered 51 calories of snacks to test it. It worked perfectly, and as well as showing my calories in on my mirror, the browser log showed the correct details being fetched (caloriesIn (data/goal): 51/1400). At some point today the goal has disappeared. It’s now showing caloriesIn (data/goal): 0/0.
                              I’ve opened the Fitbit dashboard and set up a food plan, in case that was the issue, but it hasn’t made a difference. My food has been logged and is showing correctly in my Fitbit dashboard, but it’s not transferring to the module.
                              I adjusted my weight and added some water, and both showed up immediately, so the module is obviously getting data, but I can’t figure out why it’s not getting my calories in.
                              Thanks for looking :)
                              • TipponT Offline
                                Tippon
                                Sorry, I can’t edit my last post.
                                It’s past midnight, and my calorie in goal is showing again. It’s back to zero and showing the full amount of calories available for the 14th. I’ll check tomorrow and see if it changes or disappears, and see if it changes once I add my breakfast or dinner.
                                • TipponT Offline
                                  Tippon @Tippon
                                  Seems to be working properly. Apparently Fitbit doesn’t like it when you set your own calorie goals.
                                    JJW
                                    ./Init.sh ISSUE
                                    I’m new to modules etc, so sorry if this is a dumb issue. When I run ./init.sh in the terminal I get the error message
                                    npm ERR! must provide string spec
                                    npm ERR! /home/pi/.npm/_logs/2021-06-05T13_55_01_431Z-debug.log
                                    The debug log
                                    0 verbose cli [ ‘/usr/bin/node’, ‘/usr/local/bin/npm’, ‘install’ ]
                                    1 info using npm@7.16.0
                                    2 info using node@v10.23.1
                                    3 timing npm:load:whichnode Completed in 8ms
                                    4 timing config:load:defaults Completed in 11ms
                                    5 timing config:load:file:/usr/local/lib/node_modules/npm/npmrc Completed in 11ms
                                    6 timing config:load:builtin Completed in 13ms
                                    7 timing config:load:cli Completed in 13ms
                                    8 timing config:load:env Completed in 2ms
                                    9 timing config:load:file:/home/pi/MagicMirror/modules/MMM-Fitbit2/.npmrc Completed in 2ms
                                    10 timing config:load:project Completed in 6ms
                                    11 timing config:load:file:/home/pi/.npmrc Completed in 1ms
                                    12 timing config:load:user Completed in 1ms
                                    13 timing config:load:file:/etc/npmrc Completed in 0ms
                                    14 timing config:load:global Completed in 1ms
                                    15 timing config:load:validate Completed in 2ms
                                    16 timing config:load:credentials Completed in 9ms
                                    17 timing config:load:setEnvs Completed in 7ms
                                    18 timing config:load Completed in 66ms
                                    19 timing npm:load:configload Completed in 67ms
                                    20 timing npm:load:setTitle Completed in 2ms
                                    21 timing npm:load:setupLog Completed in 12ms
                                    22 timing npm:load:cleanupLog Completed in 17ms
                                    23 timing npm:load:configScope Completed in 0ms
                                    24 timing npm:load:projectScope Completed in 2ms
                                    25 timing npm:load Completed in 113ms
                                    26 timing config:load:flatten Completed in 18ms
                                    27 timing arborist:ctor Completed in 5ms
                                    28 timing idealTree Completed in 35ms
                                    29 timing command:install Completed in 146ms
                                    30 verbose stack TypeError: must provide string spec
                                    30 verbose stack at new Edge (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/edge.js:48:13)
                                    30 verbose stack at Node.[_loadDepType] (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/node.js:781:9)
                                    30 verbose stack at Node.[Arborist.Node._loadDeps] (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/node.js:765:23)
                                    30 verbose stack at new Node (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/node.js:232:20)
                                    30 verbose stack at Arborist.[rootNodeFromPackage] (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:365:18)
                                    31 verbose cwd /home/pi/MagicMirror/modules/MMM-Fitbit2
                                    32 verbose Linux 5.10.11-v7+
                                    33 verbose argv “/usr/bin/node” “/usr/local/bin/npm” “install”
                                    34 verbose node v10.23.1
                                    35 verbose npm v7.16.0
                                    36 error must provide string spec
                                    37 verbose exit 1
                                    Any help with the issue would be greatly appreciated thank you.
                                    • V Offline
                                      Vizulize Module Developer @JJW
                                      @jjw A quick Google search for this error suggests to me that it is related to your node/npm versions, but I can’t offer any more input than that I’m afraid!
                                        JJW @Vizulize
                                        @vizulize No worries, thank you. :beaming_face_with_smiling_eyes:
                                          sdetweil @JJW
                                          @jjw looks like npm v7…
                                            JJW @sdetweil
                                            @sdetweil sorry for the lack of knowledge, but what does that mean/what do I have to change.
                                            • 3 / 5
