    Compliments module external file
    18 Posts 3 Posters 4.4k Views 3 Watching
    • H Offline
      HanaO00
      Hello, I wanted to use a file for the compliments module, but it doesn’t take it
      Here is the part in config.json
      module: 'compliments',
      position: 'middle_center',
           remoteFile: '/home/pi/MagicMirror/modules/MMM-Compliments/compliments.json'
      Someone have an idea ?
        sdetweil @HanaO00
        @hanao00 it either has to be IN the compliments folder and you use JUST the name, OR its http://someserver…/path_tofile
        so, in your case, just use the filename
        also, the path is wrong
        you coded
        but then coded this for the path (no mmm and capital letters matter on PI )
        the module folder name is compliments
        this is where the file should be…
        modules/default/compliments
        • H Offline
          HanaO00 @sdetweil
          @sdetweil Thanks for your reply, MMM-Compliments was a folder that i make for customs compliments, but now the path for compliments is :
          /home/pi/MagicMirror/modules/default/compliments/
          A screen of my config for compliments, but doesn’t work
            sdetweil @HanaO00
            @hanao00 every letter matters
            its
            remoteFile
            not
            remotefile
            on linux things are case sensitive
            javascript is case sensitive on all platforms…
            • H Offline
              HanaO00 @sdetweil
              @sdetweil Thank you I hadn’t paid attention, I corrected the case but it still uses the default compliments
                sdetweil @HanaO00
                @hanao00
                if the file upload fails, the defaults are used…
                open the developers window, ctrl-shift-i on the pi keyboard,
                select the console tab, and scroll up, or enter some unique part of the module name in the filter field
                to slim down messages to the module
                make sure the name is exact…
                • H Offline
                  HanaO00
                  Oh perfect, thanks ! He needs the extension of the file
                    sdetweil @HanaO00
                    @hanao00 said in Compliments module external file:
                    yes, exact name
                    and for this module, the extension MUST be .json
                    • H Offline
                      HanaO00 @sdetweil
                      @sdetweil Thank you
                        CheapDad
                        May I ask a follow on question? Is the source of the core compliments editable? Meaning, not the source code, but the source of the sayings that appear on the screen. I like the existing compliments but would like to customize what actually appears on the screen.
                          sdetweil @CheapDad
                          @cheapdad you should not edit THAT content
                          you can copy into your own file and edit from there, OR add it to the config.js
                          general rule… unless there is bug u are fixing short term, or a feature u are adding,
                          do NOT edit the module content (any file) in the defaults folder…
                          and overall should never edit the installed module files at all…
                          config.js is designed to allow to override the settings defined by the modules
                            CheapDad
                            Understood, but the entry in my config.js for just the line that says “compliments.” There’s no indication in config.js where that pulls from. The add-on compliments modules have extra lines with a website address, etc., but I don’t see where the core module is getting what it puts on the screen.
                              sdetweil @CheapDad
                              @cheapdad
                              in the core compliments.js file is the default setting
                              defaults: {
                              		compliments: {
                              			anytime: ["Hey there sexy!"],
                              			morning: ["Good morning, handsome!", "Enjoy your day!", "How was your sleep?"],
                              			afternoon: ["Hello, beauty!", "You look sexy!", "Looking good today!"],
                              			evening: ["Wow, you look hot!", "You look nice!", "Hi, sexy!"],
                              			"....-01-01": ["Happy new year!"]
                                CheapDad @sdetweil
                                @sdetweil Thanks, that’s very helpful. I imagine I can simply edit that compliments.js file, since I can always download another one if I want to return to default.
                                Alternatively, I could copy/paste a second set of those lines, edit them, and “no comment” the defaults. (I think that’s the correct term.) However, that would add/leave in unnecessary lines of code, which strikes me as inefficient.
                                  sdetweil @CheapDad
                                  @cheapdad i don’t understand
                                  in config.js
                                   module:"compliments",
                                  position:".....",
                                  		compliments: {
                                  edit away
                                  never touch the source file…
                                  this is the MM model,
                                  what ever is in a modules defaults:{} section
                                  can be overridden in config.js
                                  usually that is all in the module README.md file as part of the instructions
                                    CheapDad @sdetweil
                                    @sdetweil I’m not logged into my pi ATM so I can’t post code, but that’s not what’s in my config.js. My config.js has only two lines for “compliments” - that it exists and position.
                                    This is not my actual file, but it looks essentially like this:
                                    		module: "compliments",
                                    		position: "lower_third",
                                    In having this conversation, it looks like I have to add the config header and lines to do what I want and then edit that.
                                      sdetweil @CheapDad
                                      @cheapdad right…
                                      if you DON’T add things to config.js then the DEFAULTS apply
                                      (whatever is in the module)
                                        sdetweil @CheapDad
                                        @cheapdad read the links in my signature below
