Compliments module external file
18 Posts 3 Posters 4.0k Views 3 Watching
  • H Offline
    HanaO00
    Hello, I wanted to use a file for the compliments module, but it doesn’t take it
    Here is the part in config.json
    module: 'compliments',
    position: 'middle_center',
         remoteFile: '/home/pi/MagicMirror/modules/MMM-Compliments/compliments.json'
    Someone have an idea ?
    S 1 Reply Last reply Apr 19, 2021, 8:28 PM Reply Quote 0
      sdetweil @HanaO00
      @hanao00 it either has to be IN the compliments folder and you use JUST the name, OR its http://someserver…/path_tofile
      so, in your case, just use the filename
      also, the path is wrong
      you coded
      but then coded this for the path (no mmm and capital letters matter on PI )
      the module folder name is compliments
      this is where the file should be…
      modules/default/compliments
      H 1 Reply Last reply Apr 19, 2021, 8:46 PM Reply Quote 0
      • H Offline
        HanaO00 @sdetweil
        @sdetweil Thanks for your reply, MMM-Compliments was a folder that i make for customs compliments, but now the path for compliments is :
        /home/pi/MagicMirror/modules/default/compliments/
        A screen of my config for compliments, but doesn’t work
        S 1 Reply Last reply Apr 19, 2021, 9:59 PM Reply Quote 0
          sdetweil @HanaO00
          @hanao00 every letter matters
          its
          remoteFile
          not
          remotefile
          on linux things are case sensitive
          javascript is case sensitive on all platforms…
          H 1 Reply Last reply Apr 19, 2021, 10:19 PM Reply Quote 0
          • H Offline
            HanaO00 @sdetweil
            @sdetweil Thank you I hadn’t paid attention, I corrected the case but it still uses the default compliments
            S 1 Reply Last reply Apr 19, 2021, 10:27 PM Reply Quote 0
              sdetweil @HanaO00
              @hanao00
              if the file upload fails, the defaults are used…
              open the developers window, ctrl-shift-i on the pi keyboard,
              select the console tab, and scroll up, or enter some unique part of the module name in the filter field
              to slim down messages to the module
              make sure the name is exact…
              • H Offline
                HanaO00
                Oh perfect, thanks ! He needs the extension of the file
                S 1 Reply Last reply Apr 19, 2021, 10:34 PM Reply Quote 0
                  sdetweil @HanaO00
                  @hanao00 said in Compliments module external file:
                  yes, exact name
                  and for this module, the extension MUST be .json
                  H 1 Reply Last reply Apr 19, 2021, 10:41 PM Reply Quote 0
                  • H Offline
                    HanaO00 @sdetweil
                    @sdetweil Thank you
                      CheapDad
                      May I ask a follow on question? Is the source of the core compliments editable? Meaning, not the source code, but the source of the sayings that appear on the screen. I like the existing compliments but would like to customize what actually appears on the screen.
                      S 1 Reply Last reply Apr 20, 2021, 1:48 PM Reply Quote 0
