    Compliments module external file
    18 Posts 3 Posters 5.5k Views 3 Watching
      sdetweil @HanaO00
      @hanao00 it either has to be IN the compliments folder and you use JUST the name, OR its http://someserver…/path_tofile
      so, in your case, just use the filename
      also, the path is wrong
      you coded
      module: 'compliments',
      but then coded this for the path (no mmm and capital letters matter on PI )
      modules/MMM-Compliments
      the module folder name is compliments
      this is where the file should be…
      modules/default/compliments
      H 1 Reply Last reply
      • H
        HanaO00 @sdetweil
        @sdetweil Thanks for your reply, MMM-Compliments was a folder that i make for customs compliments, but now the path for compliments is :
        /home/pi/MagicMirror/modules/default/compliments/
        A screen of my config for compliments, but doesn’t work
          sdetweil @HanaO00
          @hanao00 every letter matters
          its
          remoteFile
          not
          remotefile
          on linux things are case sensitive
          javascript is case sensitive on all platforms…
          • H
            HanaO00 @sdetweil
            @sdetweil Thank you I hadn’t paid attention, I corrected the case but it still uses the default compliments
              sdetweil @HanaO00
              @hanao00
              if the file upload fails, the defaults are used…
              open the developers window, ctrl-shift-i on the pi keyboard,
              select the console tab, and scroll up, or enter some unique part of the module name in the filter field
              to slim down messages to the module
              make sure the name is exact…
              • H
                HanaO00
                Oh perfect, thanks ! He needs the extension of the file
                  sdetweil @HanaO00
                  @hanao00 said in Compliments module external file:
                  yes, exact name
                  and for this module, the extension MUST be .json
                  • H
                    HanaO00 @sdetweil
                    @sdetweil Thank you
                      CheapDad
                      May I ask a follow on question? Is the source of the core compliments editable? Meaning, not the source code, but the source of the sayings that appear on the screen. I like the existing compliments but would like to customize what actually appears on the screen.
                        sdetweil @CheapDad
                        @cheapdad you should not edit THAT content
                        you can copy into your own file and edit from there, OR add it to the config.js
                        general rule… unless there is bug u are fixing short term, or a feature u are adding,
                        do NOT edit the module content (any file) in the defaults folder…
                        and overall should never edit the installed module files at all…
                        config.js is designed to allow to override the settings defined by the modules
                          CheapDad
                          Understood, but the entry in my config.js for just the line that says “compliments.” There’s no indication in config.js where that pulls from. The add-on compliments modules have extra lines with a website address, etc., but I don’t see where the core module is getting what it puts on the screen.
                            sdetweil @CheapDad
                            @cheapdad
                            in the core compliments.js file is the default setting
                            defaults: {
                            		compliments: {
                            			anytime: ["Hey there sexy!"],
                            			morning: ["Good morning, handsome!", "Enjoy your day!", "How was your sleep?"],
                            			afternoon: ["Hello, beauty!", "You look sexy!", "Looking good today!"],
                            			evening: ["Wow, you look hot!", "You look nice!", "Hi, sexy!"],
                            			"....-01-01": ["Happy new year!"]
                            C 1 Reply Last reply
                              CheapDad @sdetweil
                              @sdetweil Thanks, that’s very helpful. I imagine I can simply edit that compliments.js file, since I can always download another one if I want to return to default.
                              Alternatively, I could copy/paste a second set of those lines, edit them, and “no comment” the defaults. (I think that’s the correct term.) However, that would add/leave in unnecessary lines of code, which strikes me as inefficient.
                                sdetweil @CheapDad
                                @cheapdad i don’t understand
                                in config.js
                                 module:"compliments",
                                position:".....",
                                		compliments: {
                                edit away
                                never touch the source file…
                                this is the MM model,
                                what ever is in a modules defaults:{} section
                                can be overridden in config.js
                                usually that is all in the module README.md file as part of the instructions
                                  CheapDad @sdetweil
                                  @sdetweil I’m not logged into my pi ATM so I can’t post code, but that’s not what’s in my config.js. My config.js has only two lines for “compliments” - that it exists and position.
                                  This is not my actual file, but it looks essentially like this:
                                  		module: "compliments",
                                  		position: "lower_third",
                                  In having this conversation, it looks like I have to add the config header and lines to do what I want and then edit that.
                                  S 2 Replies Last reply
                                    sdetweil @CheapDad
                                    @cheapdad right…
                                    if you DON’T add things to config.js then the DEFAULTS apply
                                    (whatever is in the module)
                                      sdetweil @CheapDad
                                      @cheapdad read the links in my signature below
