    Compliments module external file
    18 Posts 3 Posters 3.7k Views 3 Watching
    • H Offline
      HanaO00
      Hello, I wanted to use a file for the compliments module, but it doesn’t take it
      Here is the part in config.json
      module: 'compliments',
      position: 'middle_center',
           remoteFile: '/home/pi/MagicMirror/modules/MMM-Compliments/compliments.json'
      Someone have an idea ?
        sdetweil @HanaO00
        @hanao00 it either has to be IN the compliments folder and you use JUST the name, OR its http://someserver…/path_tofile
        so, in your case, just use the filename
        also, the path is wrong
        you coded
        but then coded this for the path (no mmm and capital letters matter on PI )
        the module folder name is compliments
        this is where the file should be…
        modules/default/compliments
        • H Offline
          HanaO00 @sdetweil
          @sdetweil Thanks for your reply, MMM-Compliments was a folder that i make for customs compliments, but now the path for compliments is :
          /home/pi/MagicMirror/modules/default/compliments/
          A screen of my config for compliments, but doesn’t work
            sdetweil @HanaO00
            @hanao00 every letter matters
            its
            remoteFile
            not
            remotefile
            on linux things are case sensitive
            javascript is case sensitive on all platforms…
            • H Offline
              HanaO00 @sdetweil
              @sdetweil Thank you I hadn’t paid attention, I corrected the case but it still uses the default compliments
                sdetweil @HanaO00
                @hanao00
                if the file upload fails, the defaults are used…
                open the developers window, ctrl-shift-i on the pi keyboard,
                select the console tab, and scroll up, or enter some unique part of the module name in the filter field
                to slim down messages to the module
                make sure the name is exact…
                • H Offline
                  HanaO00
                  Oh perfect, thanks ! He needs the extension of the file
                    sdetweil @HanaO00
                    @hanao00 said in Compliments module external file:
                    yes, exact name
                    and for this module, the extension MUST be .json
                    • H Offline
                      HanaO00 @sdetweil
                      @sdetweil Thank you
                        CheapDad
                        May I ask a follow on question? Is the source of the core compliments editable? Meaning, not the source code, but the source of the sayings that appear on the screen. I like the existing compliments but would like to customize what actually appears on the screen.
