    MMM-Fitbit2 PythonShell is not a constructor
    14 Posts 6 Posters 6.0k Views 6 Watching
    • TipponT
      Tippon @sdetweil
      @sdetweil Once again, you are a superstar. It’s working, thank you :)
      I thought I’d tried that the other night, but for some reason it didn’t work. I don’t know if I typed it in wrong, or if I messed it up when I tried to do it remotely through my phone. Either way, it’s working now, and I’m a happy bunny :D
      Please forgive me if I’m slow to reply, I’m currently experiencing memory issues, and sometimes forget that I’ve asked a question >.<
      • V
        Vizulize Module Developer
        Hi - I have just committed this fix: https://github.com/m-roberts/MMM-Fitbit2/commit/e958665dcf63900d38f5405961a1a176d5ba2fcf
        TipponT 1 Reply Last reply Reply Quote 0
        • TipponT
          Tippon @Vizulize
          @vizulize That’s great, thank you :)
          • F
            frosty_snow
            @Tippon
            Hello - just wanted to inquire about this problem as I’m encountering the same thing but even with the mentioned change to the require statement it is continuing to occur.
            Did you need to make any other changes or corrections to any of the files?
            Thank you!
              sdetweil @frosty_snow
              @frosty_snow can us do , from the module folder
              grep version   node_modules/python_shell/package.json
              • F
                frosty_snow @sdetweil
                Looks like I’m on 3.0.0
                  dmolony
                  @frosty_snow Not sure if helpful but I’m using python-shell 0.5.0 and removing the brackets around PythonShell fixed the same error for me.
                  • StoffbeuteluweS
                    Stoffbeuteluwe Project Sponsor
                    var NodeHelper = require("node_helper");
                    const PythonShell = require("python-shell");
                    this is working for me
                    • V
                      I have updated the module: https://github.com/m-roberts/MMM-Fitbit2/commit/27706ea0a9ab13b8d12a020f7234adf361d108ae
                        sdetweil @Vizulize
                        @vizulize i think it depends on what version of python-shell you are running…
                        https://github.com/extrabacon/python-shell/issues/154
                        your package.json says
                        "python-shell": "^0.5.0"
                        which means 0.5.0 OR ABOVE (technically ‘at minimum’)
                        if u want ONLY 0.5.0, take the ^ off the front…
                        else sometimes u will get 1.x
                        • V
                          Vizulize Module Developer @sdetweil
                          @sdetweil It is defined as 0.5.0 in the dependencies.
                          To be honest, the Python should be rewritten in JS anyway. Perhaps I will get around to doing that in the near future :thinking_face:
                          Then this issue goes away!
                            sdetweil @Vizulize
                            @vizulize yeh, i don’t know whay there is a python_shell lib… as exec and spawn are so easy…
