    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 460.6k Views 31 Watching
      stoffel
      i have try it, but all was actuel. also i make an npm install.
      not solved the problem. it is an file not found error.
      i send you my config.js and the default.js from the modul
      and thanks for your help
        stoffel
        ich muss kurz weg. melde mich später nochmal
          sdetweil @stoffel
          @stoffel are you using the MM url
          http://mm_address:mm_port/modules/MMM-Config/config.html
          got your files… this will take some thinking…
          compliments_plus has a data item with lots of .
          the forming system can’t handle the dots in the naming scheme
          cause it sees the dots as part of the name, not a literal…
          regular compliments has them as LEADING only, and I can trick it…
          compliments plus has trailing and/or embedded…
          currently there is no escaping mechanism…
          I opened issued
          https://github.com/sdetweil/MMM-Config/issues/8
            stoffel
            i’v tryed with my address, the same.
            the “…–…–…” are original here
            but this
                      '01-01-....': [
                        null
                        null
            is the result of MMM-Remote-Control module (edit config), i’v changed it to original
            		  "01-01-....": [
            			function() {return "<i class=\"fa fa-glass-cheers\"></i> Happy New Year! " + moment().format("YYYY")}
            			function() {return moment().locale(config.language).format("dddd, D MMMM")}
            			// https://forum.magicmirror.builders/topic/13332/reloading-config-defaults-or-module
            the same problem
            i have searched here for the missing file, nothing.
            i am testing again ;-)
              sdetweil @stoffel
              @stoffel the missing file is not involved…
              if the name contains a ‘.’ , it breaks the system. the only example I had was compliments, which had leading dots…
              • JalibuJ Offline
                Jalibu Module Developer
                Wow!
                Great module! I just checked out compatibility with my modules and am very impressed.
                I’ll leave you some feedback on GitHub.
                  stoffel
                  ok, but it works with this 2 variante.
                  what system breaks ? mm or MMM-Config ?
                  i’v comment out the compliments_plus modul in the config.js but is the same result
                    sdetweil @stoffel
                    @stoffel MMM-Config … MM is happy
                    did the collector crash again, where u start MM, npm start or pm2 logs --lines=100
                      stoffel
                      autostart with pm2
                        stoffel
                        ok, what i see is when i start mm with npm start it loads all modules what i have installt not only from the config.js (i use now the default config.js from mm). Next i delete all moduls what i not needed.
                          sdetweil @stoffel
                          @stoffel sorry, I do not understand
                          if there is a collector error, you should see something like
                          /home/sam/mmm-config/scripts/buildschema3.js:619
                            return data[left];
                          TypeError: Cannot read property 'feeds' of undefined
                              at get_define_info (/home/sam/mmm-config/scripts/buildschema3.js:619:14)
                              at /home/sam/mmm-config/scripts/buildschema3.js:415:29
                              at Array.forEach (<anonymous>)
                              at Object.<anonymous> (/home/sam/mmm-config/scripts/buildschema3.js:405:24)
                            stoffel
                            ok, i think so,
                            0|MagicMirror  | stderr 2: /home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:595
                            0|MagicMirror  |     let tt = data[left];
                            0|MagicMirror  |                  ^
                            0|MagicMirror  | TypeError: Cannot read property '' of undefined
                            0|MagicMirror  |     at get_define_info (/home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:595:18)
                            0|MagicMirror  |     at get_define_info (/home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:599:12)
                            look at page 2 the 2. post
                              sdetweil @stoffel
                              @stoffel yes, that is because of the … the code splits the string with . and not I have 10 items, some empty… oops…
                              working on fix…
                                sdetweil @stoffel
                                @stoffel I think I have a fix
                                see the issue for instructions
                                • FoziF Offline
                                  Fozi Project Sponsor @sdetweil
                                  @sdetweil The “Mother of all Modules”! :love-you_gesture_light_skin_tone:
                                  That’s a fantastic job, Sam! Especially beginners will be grateful, but not only beginners.
                                  • StoffbeuteluweS Offline
                                    Stoffbeuteluwe Project Sponsor
                                    Hi I only see this…?
                                    Need a little bit help :grinning_face:
                                    S 1 Reply Last reply Reply Quote -1
                                      sdetweil @Stoffbeuteluwe
                                      @stoffbeuteluwe try again , git pull the repo…
                                        stoffel
                                        i have fix it with your issues. thank you very much !!
                                          sdetweil @stoffel
                                          @stoffel i have seen a couple places in some data where I inadvertently change paths to files with leading …
                                          so be careful…
                                          will update fix when I have it…
                                            stoffel
                                            ok, thanks. it works well with all my modules, great!
                                            but when i add the MMM-Volume i have another error. i think it is a problem from MMM-Volume. it’s two years old. it’s a json format error
                                            • 14
                                            • 15
                                            • 2 / 15
