    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 487.0k Views 31 Watching
      stoffel
      i’v tryed with my address, the same.
      the “…–…–…” are original here
      but this
                '01-01-....': [
                  null
                  null
      is the result of MMM-Remote-Control module (edit config), i’v changed it to original
      		  "01-01-....": [
      			function() {return "<i class=\"fa fa-glass-cheers\"></i> Happy New Year! " + moment().format("YYYY")}
      			function() {return moment().locale(config.language).format("dddd, D MMMM")}
      			// https://forum.magicmirror.builders/topic/13332/reloading-config-defaults-or-module
      the same problem
      i have searched here for the missing file, nothing.
      i am testing again ;-)
      thanks for your help
        sdetweil @stoffel
        @stoffel the missing file is not involved…
        if the name contains a ‘.’ , it breaks the system. the only example I had was compliments, which had leading dots…
        • JalibuJ
          Jalibu Module Developer
          Wow!
          Great module! I just checked out compatibility with my modules and am very impressed.
          I’ll leave you some feedback on GitHub.
            stoffel
            ok, but it works with this 2 variante.
            what system breaks ? mm or MMM-Config ?
            i’v comment out the compliments_plus modul in the config.js but is the same result
              sdetweil @stoffel
              @stoffel MMM-Config … MM is happy
              did the collector crash again, where u start MM, npm start or pm2 logs --lines=100
                stoffel
                autostart with pm2
                  stoffel
                  ok, what i see is when i start mm with npm start it loads all modules what i have installt not only from the config.js (i use now the default config.js from mm). Next i delete all moduls what i not needed.
                    sdetweil @stoffel
                    @stoffel sorry, I do not understand
                    if there is a collector error, you should see something like
                    /home/sam/mmm-config/scripts/buildschema3.js:619
                      return data[left];
                    TypeError: Cannot read property 'feeds' of undefined
                        at get_define_info (/home/sam/mmm-config/scripts/buildschema3.js:619:14)
                        at /home/sam/mmm-config/scripts/buildschema3.js:415:29
                        at Array.forEach (<anonymous>)
                        at Object.<anonymous> (/home/sam/mmm-config/scripts/buildschema3.js:405:24)
                      stoffel
                      ok, i think so,
                      0|MagicMirror  | stderr 2: /home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:595
                      0|MagicMirror  |     let tt = data[left];
                      0|MagicMirror  |                  ^
                      0|MagicMirror  | TypeError: Cannot read property '' of undefined
                      0|MagicMirror  |     at get_define_info (/home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:595:18)
                      0|MagicMirror  |     at get_define_info (/home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:599:12)
                      look at page 2 the 2. post
                      S 2 Replies Last reply
                        sdetweil @stoffel
                        @stoffel yes, that is because of the … the code splits the string with . and not I have 10 items, some empty… oops…
                        working on fix…
                          sdetweil @stoffel
                          @stoffel I think I have a fix
                          see the issue for instructions
                          https://github.com/sdetweil/MMM-Config/issues/8
                          • FoziF
                            Fozi Project Sponsor @sdetweil
                            @sdetweil The “Mother of all Modules”! :love-you_gesture_light_skin_tone:
                            That’s a fantastic job, Sam! Especially beginners will be grateful, but not only beginners.
                            • StoffbeuteluweS
                              Stoffbeuteluwe Project Sponsor
                              Hi I only see this…?
                              Need a little bit help :grinning_face:
                              Reply Quote -1
                                sdetweil @Stoffbeuteluwe
                                @stoffbeuteluwe try again , git pull the repo…
                                  stoffel
                                  i have fix it with your issues. thank you very much !!
                                    sdetweil @stoffel
                                    @stoffel i have seen a couple places in some data where I inadvertently change paths to files with leading …
                                    so be careful…
                                    will update fix when I have it…
                                      stoffel
                                      ok, thanks. it works well with all my modules, great!
                                      but when i add the MMM-Volume i have another error. i think it is a problem from MMM-Volume. it’s two years old. it’s a json format error
                                        sdetweil @stoffel
                                        @stoffel no, I fixed a problem with MMM-Volume earlier today… haven’t pushed it yet…
                                          stoffel @sdetweil
                                          ok
                                          when you module works also with MMM-Volume then i am very happy.:beaming_face_with_smiling_eyes: i control my mm over remote control.
                                          thank you very much for your support, great job :thumbs_up:
                                            sdetweil @stoffel
                                            @stoffel do a git pull on the newform branch, and try it out… this is with the fix for MMM-Volume
                                            and another, plus an npm install after
                                            • 14
                                            • 15
                                            • 2 / 15
