    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 489.8k Views 31 Watching
      stoffel
      hallo everyone,
      im new with the fantastic mm and i am german so sorry for my english.
      i testing this modul.
      for me MMM-Config is not working. the config.html page say MagicMirror is not running.
      i tested from my pc and direct from my rpi.
      file not found ‘/modules/MMM-Config/node_modules/jsonform/deps/opt/bootstrap.css.map’
      i have installed this module 2 times.
      i have searched in the whole rpi but nothing.
      my rpi:
      Raspberry Pi 3B +
      updated raspian
      config.js:
      address: ‘0.0.0.0’
      ipWhitelist: []
      who have this file, or where can i download this file ?
      thanks sdetweil for this great module and a nice day for all
        sdetweil @stoffel
        @stoffel this is because the scanner failed.
        please look at the messages where u start mm
        npm start or pm2
        if pm2, then the pm2 logs --lines=100
        will produce the output.
          stoffel
          thanks sdetweil for your answer,
          thats the result:
          0|MagicMirror  | [24.05.2021 16:24.42.647] [LOG]
          0|MagicMirror  | stdout: completed
          0|MagicMirror  | [24.05.2021 16:24.42.672] [ERROR]
          0|MagicMirror  | stderr 2: /home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:595
          0|MagicMirror  |     let tt = data[left];
          0|MagicMirror  |                  ^
          0|MagicMirror  | TypeError: Cannot read property '' of undefined
          0|MagicMirror  |     at get_define_info (/home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:595:18)
          0|MagicMirror  |     at get_define_info (/home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:599:12)
          0|MagicMirror  |     at /home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:415:29
          0|MagicMirror  |     at Array.forEach (<anonymous>)
          0|MagicMirror  |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:405:24)
          0|MagicMirror  |     at Module._compile (internal/modules/cjs/loader.js:1068:30)
          0|MagicMirror  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1097:10)
          0|MagicMirror  |     at Module.load (internal/modules/cjs/loader.js:933:32)
          0|MagicMirror  |     at Function.Module._load (internal/modules/cjs/loader.js:774:14)
          but why or where searched for bootstrap.css.map
          i hope you can help me
            sdetweil @stoffel
            @stoffel do another git pull… there was a fix yesterday for this… please advise
            otherwise send me the config.js and the defaults.js (from the modules folder)
            if u edit any personal info (I don’t share), please try to keep all the lines, don’t delete any
            send to my email, same userid as here, at gmail.com
              stoffel
              i have try it, but all was actuel. also i make an npm install.
              not solved the problem. it is an file not found error.
              i send you my config.js and the default.js from the modul
              and thanks for your help
                stoffel
                ich muss kurz weg. melde mich später nochmal
                  sdetweil @stoffel
                  @stoffel are you using the MM url
                  http://mm_address:mm_port/modules/MMM-Config/config.html
                  got your files… this will take some thinking…
                  compliments_plus has a data item with lots of .
                  the forming system can’t handle the dots in the naming scheme
                  cause it sees the dots as part of the name, not a literal…
                  regular compliments has them as LEADING only, and I can trick it…
                  compliments plus has trailing and/or embedded…
                  currently there is no escaping mechanism…
                  I opened issued
                  https://github.com/sdetweil/MMM-Config/issues/8
                    stoffel
                    i’v tryed with my address, the same.
                    the “…–…–…” are original here
                    but this
                              '01-01-....': [
                                null
                                null
                    is the result of MMM-Remote-Control module (edit config), i’v changed it to original
                    		  "01-01-....": [
                    			function() {return "<i class=\"fa fa-glass-cheers\"></i> Happy New Year! " + moment().format("YYYY")}
                    			function() {return moment().locale(config.language).format("dddd, D MMMM")}
                    			// https://forum.magicmirror.builders/topic/13332/reloading-config-defaults-or-module
                    the same problem
                    i have searched here for the missing file, nothing.
                    i am testing again ;-)
                      sdetweil @stoffel
                      @stoffel the missing file is not involved…
                      if the name contains a ‘.’ , it breaks the system. the only example I had was compliments, which had leading dots…
                      • JalibuJ
                        Jalibu Module Developer
                        Wow!
                        Great module! I just checked out compatibility with my modules and am very impressed.
                        I’ll leave you some feedback on GitHub.
                          stoffel
                          ok, but it works with this 2 variante.
                          what system breaks ? mm or MMM-Config ?
                          i’v comment out the compliments_plus modul in the config.js but is the same result
                            sdetweil @stoffel
                            @stoffel MMM-Config … MM is happy
                            did the collector crash again, where u start MM, npm start or pm2 logs --lines=100
                              stoffel
                              autostart with pm2
                                stoffel
                                ok, what i see is when i start mm with npm start it loads all modules what i have installt not only from the config.js (i use now the default config.js from mm). Next i delete all moduls what i not needed.
                                  sdetweil @stoffel
                                  @stoffel sorry, I do not understand
                                  if there is a collector error, you should see something like
                                  /home/sam/mmm-config/scripts/buildschema3.js:619
                                    return data[left];
                                  TypeError: Cannot read property 'feeds' of undefined
                                      at get_define_info (/home/sam/mmm-config/scripts/buildschema3.js:619:14)
                                      at /home/sam/mmm-config/scripts/buildschema3.js:415:29
                                      at Object.<anonymous> (/home/sam/mmm-config/scripts/buildschema3.js:405:24)
                                    stoffel
                                    ok, i think so,
                                    0|MagicMirror  |                  ^
                                    look at page 2 the 2. post
                                    S 2 Replies Last reply
                                      sdetweil @stoffel
                                      @stoffel yes, that is because of the … the code splits the string with . and not I have 10 items, some empty… oops…
                                      working on fix…
                                        sdetweil @stoffel
                                        @stoffel I think I have a fix
                                        see the issue for instructions
                                        • FoziF
                                          Fozi Project Sponsor @sdetweil
                                          @sdetweil The “Mother of all Modules”! :love-you_gesture_light_skin_tone:
                                          That’s a fantastic job, Sam! Especially beginners will be grateful, but not only beginners.
                                          • StoffbeuteluweS
                                            Stoffbeuteluwe Project Sponsor
                                            Hi I only see this…?
                                            Need a little bit help :grinning_face:
                                            Reply Quote -1
                                            • 14
                                            • 15
                                            • 1 / 15
