    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 490.1k Views 31 Watching
    • Mykle1M
      Possibly the most important module ever written for MM. I can see that all the config errors for users (new and old) will be virtually eliminated. I applaud your work on this. Just fantastic!
      Works on MM installations on Ubuntu 16.04 LTS and 20.04 LTS, too.
      Peace!
        if u set your config.js to allow connection from outside the mm system, you can config from anywhere
        • BKeyportB
          BKeyport Module Developer
          WOW! this is cool. I’ll have to see how it works when I get my test box setup.
            bdream
            @sdetweil Haven’t had all users the wish for exactly this app?
            Great job :flexed_biceps_medium-light_skin_tone:
            cheers, bdream
            • lavolp3L
              @sdetweil Happy to see this developing further. Have waited for something like this for ages!
              How to troubleshoot modules
              MMM-soccer v2, MMM-AVStock
              • cowboysdudeC
                cowboysdude Module Developer @sdetweil
                @sdetweil WOW this is really AWESOME!!! Very much needed!!
                Awesome job!!!
                Thank you Sam!!!
                  sdetweil @Mykle1
                  @mykle1 I develop on Ubuntu 18.04, so it works there too!
                  Mykle1M 1 Reply Last reply
                  • Mykle1M
                    :thumbsup:
                      stoffel
                      hallo everyone,
                      im new with the fantastic mm and i am german so sorry for my english.
                      i testing this modul.
                      for me MMM-Config is not working. the config.html page say MagicMirror is not running.
                      i tested from my pc and direct from my rpi.
                      file not found ‘/modules/MMM-Config/node_modules/jsonform/deps/opt/bootstrap.css.map’
                      i have installed this module 2 times.
                      i have searched in the whole rpi but nothing.
                      my rpi:
                      Raspberry Pi 3B +
                      updated raspian
                      config.js:
                      address: ‘0.0.0.0’
                      ipWhitelist: []
                      who have this file, or where can i download this file ?
                      thanks sdetweil for this great module and a nice day for all
                        sdetweil @stoffel
                        @stoffel this is because the scanner failed.
                        please look at the messages where u start mm
                        npm start or pm2
                        if pm2, then the pm2 logs --lines=100
                        will produce the output.
                          stoffel
                          thanks sdetweil for your answer,
                          thats the result:
                          0|MagicMirror  | [24.05.2021 16:24.42.647] [LOG]
                          0|MagicMirror  | stdout: completed
                          0|MagicMirror  | [24.05.2021 16:24.42.672] [ERROR]
                          0|MagicMirror  | stderr 2: /home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:595
                          0|MagicMirror  |     let tt = data[left];
                          0|MagicMirror  |                  ^
                          0|MagicMirror  | TypeError: Cannot read property '' of undefined
                          0|MagicMirror  |     at get_define_info (/home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:595:18)
                          0|MagicMirror  |     at get_define_info (/home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:599:12)
                          0|MagicMirror  |     at /home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:415:29
                          0|MagicMirror  |     at Array.forEach (<anonymous>)
                          0|MagicMirror  |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:405:24)
                          0|MagicMirror  |     at Module._compile (internal/modules/cjs/loader.js:1068:30)
                          0|MagicMirror  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1097:10)
                          0|MagicMirror  |     at Module.load (internal/modules/cjs/loader.js:933:32)
                          0|MagicMirror  |     at Function.Module._load (internal/modules/cjs/loader.js:774:14)
                          but why or where searched for bootstrap.css.map
                          i hope you can help me
                            sdetweil @stoffel
                            @stoffel do another git pull… there was a fix yesterday for this… please advise
                            otherwise send me the config.js and the defaults.js (from the modules folder)
                            if u edit any personal info (I don’t share), please try to keep all the lines, don’t delete any
                            send to my email, same userid as here, at gmail.com
                              stoffel
                              i have try it, but all was actuel. also i make an npm install.
                              not solved the problem. it is an file not found error.
                              i send you my config.js and the default.js from the modul
                              and thanks for your help
                                stoffel
                                ich muss kurz weg. melde mich später nochmal
                                  sdetweil @stoffel
                                  @stoffel are you using the MM url
                                  http://mm_address:mm_port/modules/MMM-Config/config.html
                                  got your files… this will take some thinking…
                                  compliments_plus has a data item with lots of .
                                  the forming system can’t handle the dots in the naming scheme
                                  cause it sees the dots as part of the name, not a literal…
                                  regular compliments has them as LEADING only, and I can trick it…
                                  compliments plus has trailing and/or embedded…
                                  currently there is no escaping mechanism…
                                  I opened issued
                                  https://github.com/sdetweil/MMM-Config/issues/8
                                    stoffel
                                    i’v tryed with my address, the same.
                                    the “…–…–…” are original here
                                    but this
                                              '01-01-....': [
                                                null
                                                null
                                    is the result of MMM-Remote-Control module (edit config), i’v changed it to original
                                    		  "01-01-....": [
                                    			function() {return "<i class=\"fa fa-glass-cheers\"></i> Happy New Year! " + moment().format("YYYY")}
                                    			function() {return moment().locale(config.language).format("dddd, D MMMM")}
                                    			// https://forum.magicmirror.builders/topic/13332/reloading-config-defaults-or-module
                                    the same problem
                                    i have searched here for the missing file, nothing.
                                    i am testing again ;-)
                                      sdetweil @stoffel
                                      @stoffel the missing file is not involved…
                                      if the name contains a ‘.’ , it breaks the system. the only example I had was compliments, which had leading dots…
                                      • JalibuJ
                                        Jalibu Module Developer
                                        Wow!
                                        Great module! I just checked out compatibility with my modules and am very impressed.
                                        I’ll leave you some feedback on GitHub.
                                          stoffel
                                          ok, but it works with this 2 variante.
                                          what system breaks ? mm or MMM-Config ?
                                          i’v comment out the compliments_plus modul in the config.js but is the same result
                                            sdetweil @stoffel
                                            @stoffel MMM-Config … MM is happy
                                            did the collector crash again, where u start MM, npm start or pm2 logs --lines=100
                                            • 14
                                            • 15
                                            • 1 / 15
