    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 435.2k Views 31 Watching
      I’ve watched as users continue to struggle with formatting in config.js and i think I have a solution
      https://github.com/sdetweil/MMM-Config
      it automatically discovers what you have installed (in the modules folder) and what you are using (in config.js)
      and will let you turn them on/off, edit the settings and change the module positions. all in a form.
      every time u start MagicMirror it will check to see if config.js has changed since last time, and if you’ve added or removed something from the modules folder… it will construct a form that will allow you to edit the settings of everything.
      and then save it back to config.js (after saving the current copy) (and if using PM2) restart MM to use that new config.js
      also works on Windows installations of MM.
      it can put a QR code on the screen so you can use your phone or ipad, or other scanning device so u don’t have to know the url
      and can also be bookmarked etc…
      I supply a css to allow you to change color of the form.
      some screen shots
      initial form screen
      base expanded
      some places I can tell what you can do
      modules list, blue is enabled, red disabled… (u can changed that in the css file)
      sample module form section , discovered from module source file and config.js usage (if any)
      module position info, cause you may need one above another, (clock and calendar for example)
      and things in other areas…
      if u disable a module (checkbox), the contents STAYS in config.js, otherwise it would lose the important info (apikeys, urls, etc)
      thanks to a few testers(who can name themselves if they want) , we’ve gone thru a lot of modules, but not all…
      so I expect there will be reports of troubles… give it a shot and let me know…
      it currently doesn’t support multiple instances of the same module (used for pages and carousel or similar type modules ), or things like my Covid19 charter.
      but I have an open issue and am working on it…
      Mykle1M S lavolp3L cowboysdudeC FoziF 5 Replies Last reply Reply Quote 17
        Possibly the most important module ever written for MM. I can see that all the config errors for users (new and old) will be virtually eliminated. I applaud your work on this. Just fantastic!
        Works on MM installations on Ubuntu 16.04 LTS and 20.04 LTS, too.
        Peace!
          if u set your config.js to allow connection from outside the mm system, you can config from anywhere
          • BKeyportB Offline
            BKeyport Module Developer
            WOW! this is cool. I’ll have to see how it works when I get my test box setup.
              bdream
              @sdetweil Haven’t had all users the wish for exactly this app?
              Great job :flexed_biceps_medium-light_skin_tone:
              cheers, bdream
              • lavolp3L Offline
                @sdetweil Happy to see this developing further. Have waited for something like this for ages!
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
                • cowboysdudeC Offline
                  cowboysdude Module Developer @sdetweil
                  @sdetweil WOW this is really AWESOME!!! Very much needed!!
                  Awesome job!!!
                  Thank you Sam!!!
                    sdetweil @Mykle1
                    @mykle1 I develop on Ubuntu 18.04, so it works there too!
                      :thumbsup:
                        stoffel
                        hallo everyone,
                        im new with the fantastic mm and i am german so sorry for my english.
                        i testing this modul.
                        for me MMM-Config is not working. the config.html page say MagicMirror is not running.
                        i tested from my pc and direct from my rpi.
                        file not found ‘/modules/MMM-Config/node_modules/jsonform/deps/opt/bootstrap.css.map’
                        i have installed this module 2 times.
                        i have searched in the whole rpi but nothing.
                        my rpi:
                        Raspberry Pi 3B +
                        updated raspian
                        config.js:
                        address: ‘0.0.0.0’
                        ipWhitelist: []
                        who have this file, or where can i download this file ?
                        thanks sdetweil for this great module and a nice day for all
                          sdetweil @stoffel
                          @stoffel this is because the scanner failed.
                          please look at the messages where u start mm
                          npm start or pm2
                          if pm2, then the pm2 logs --lines=100
                          will produce the output.
                            stoffel
                            thanks sdetweil for your answer,
                            thats the result:
                            0|MagicMirror  | [24.05.2021 16:24.42.647] [LOG]
                            0|MagicMirror  | stdout: completed
                            0|MagicMirror  | [24.05.2021 16:24.42.672] [ERROR]
                            0|MagicMirror  | stderr 2: /home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:595
                            0|MagicMirror  |     let tt = data[left];
                            0|MagicMirror  |                  ^
                            0|MagicMirror  | TypeError: Cannot read property '' of undefined
                            0|MagicMirror  |     at get_define_info (/home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:595:18)
                            0|MagicMirror  |     at get_define_info (/home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:599:12)
                            0|MagicMirror  |     at /home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:415:29
                            0|MagicMirror  |     at Array.forEach (<anonymous>)
                            0|MagicMirror  |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:405:24)
                            0|MagicMirror  |     at Module._compile (internal/modules/cjs/loader.js:1068:30)
                            0|MagicMirror  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1097:10)
                            0|MagicMirror  |     at Module.load (internal/modules/cjs/loader.js:933:32)
                            0|MagicMirror  |     at Function.Module._load (internal/modules/cjs/loader.js:774:14)
                            but why or where searched for bootstrap.css.map
                            i hope you can help me
                              sdetweil @stoffel
                              @stoffel do another git pull… there was a fix yesterday for this… please advise
                              otherwise send me the config.js and the defaults.js (from the modules folder)
                              if u edit any personal info (I don’t share), please try to keep all the lines, don’t delete any
                              send to my email, same userid as here, at gmail.com
                                stoffel
                                i have try it, but all was actuel. also i make an npm install.
                                not solved the problem. it is an file not found error.
                                i send you my config.js and the default.js from the modul
                                and thanks for your help
                                  stoffel
                                  ich muss kurz weg. melde mich später nochmal
                                    sdetweil @stoffel
                                    @stoffel are you using the MM url
                                    http://mm_address:mm_port/modules/MMM-Config/config.html
                                    got your files… this will take some thinking…
                                    compliments_plus has a data item with lots of .
                                    the forming system can’t handle the dots in the naming scheme
                                    cause it sees the dots as part of the name, not a literal…
                                    regular compliments has them as LEADING only, and I can trick it…
                                    compliments plus has trailing and/or embedded…
                                    currently there is no escaping mechanism…
                                    I opened issued
                                    https://github.com/sdetweil/MMM-Config/issues/8
                                      stoffel
                                      i’v tryed with my address, the same.
                                      the “…–…–…” are original here
                                      but this
                                                '01-01-....': [
                                                  null
                                                  null
                                      is the result of MMM-Remote-Control module (edit config), i’v changed it to original
                                      		  "01-01-....": [
                                      			function() {return "<i class=\"fa fa-glass-cheers\"></i> Happy New Year! " + moment().format("YYYY")}
                                      			function() {return moment().locale(config.language).format("dddd, D MMMM")}
                                      			// https://forum.magicmirror.builders/topic/13332/reloading-config-defaults-or-module
                                      the same problem
                                      i have searched here for the missing file, nothing.
                                      i am testing again ;-)
                                        sdetweil @stoffel
                                        @stoffel the missing file is not involved…
                                        if the name contains a ‘.’ , it breaks the system. the only example I had was compliments, which had leading dots…
                                        • JalibuJ Offline
                                          Jalibu Module Developer
                                          Wow!
                                          Great module! I just checked out compatibility with my modules and am very impressed.
                                          I’ll leave you some feedback on GitHub.
                                            stoffel
                                            ok, but it works with this 2 variante.
                                            what system breaks ? mm or MMM-Config ?
                                            i’v comment out the compliments_plus modul in the config.js but is the same result
                                            • 14
                                            • 15
                                            • 1 / 15
