    MMM-syslog
    logginghome automation
    34 Posts 10 Posters 35.9k Views 11 Watching
      paviro
      It’s done :)
      – The Doctor
        Pbaan93
        Is it possible to change the title name ‘MMM-syslog’? Tried to set the header in config but it adds a header instead of changing the header/title.
        Would be realy cool to change it. My home automation system will send info/warning/error to this module. So I would like to change te tilte in the name of my home automation system.
          DirkS
          Can you give me a clear example for the http get syntax i need to use from the remote device? Maybe to test it from the terminal. I don’t get the point how to do it as a non programmer guy :D
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @DirkS
            @DirkS http://192.168.2.1:8080/syslog?type=INFO&message=This is a test message you need to replace the ip to yours of the mirror
            @Pbaan93 there is an undocumented config option title for it :)
              DirkS
              Oh so easy :D Thanks for the info.
                PointPubMedia
                @strawberry-3-141 Is it the same module you made for me a while ago or it’s a new version?
                I’m still using your https://www.github.com/fewieden/MMM-syslog
                I need to change my repo to use this one if I want the latest version ?
                  PointPubMedia
                  @paviro @strawberry-3-141 I would like that the column for “time” should be justify at right completely. !0_1481377257671_2016-12-10 08_39_44-10.99.99.15 - PuTTY.png
                    strawberry 3.141 Project Sponsor Module Developer @PointPubMedia
                    @PointPubMedia yes the module got merged into the repo of @paviro a while ago and another user made an update on that one, so you have to use the other repo
                      PointPubMedia
                        PointPubMedia
                        Is it normal that the time column is not fully at the right side ?
                          PointPubMedia
                          @paviro @strawberry-3-141 Do you think it could be possible to have a config option to limit the lenght max of the message to be displayed ? And truncate it ?
                            @PointPubMedia https://github.com/paviro/MMM-syslog/pull/6
                            P P 2 Replies Last reply Reply Quote 0
                              PointPubMedia @strawberry 3.141
                              @strawberry-3.141 thanks mate! Do you know at the same time, why the column for date/time is not at the right side completely?
                                @PointPubMedia could it be the margin from the body?
                                  @strawberry-3.141
                                  all other module are correct… except this one!
                                    PointPubMedia
                                    Another cool thing could be, to be able to use classes for the MMM-Facial into syslog to display Warning/ERROR for some user…
                                      paviro @strawberry 3.141
                                      @strawberry-3.141 I just merged your pull request thanks! :)
                                      – The Doctor
                                      • cowboysdudeC Offline
                                        Now this is a handy module!
                                          PointPubMedia
                                          @strawberry-3-141 hey mate… do you think it can be possible to have a way to replicate/centralize the syslog data…
                                          Currently I have one installation of MM in the house, but currently building a couple more. And would need to be able to share the syslog data…
                                          Maybe a config in syslog module to “send” data to “slave” ?
                                            @PointPubMedia do you plan to run multiple independent Mirrors or do you access the one mirror via browser from the other devices?
