    MMM-Fitbit2
    Scheduled Pinned Locked Moved Health
    fitbithealthfitnesshealthywaterfoodtrackingactivity tracker
    98 Posts 21 Posters 177.1k Views 19 Watching
      JJW
      ./Init.sh ISSUE
      I’m new to modules etc, so sorry if this is a dumb issue. When I run ./init.sh in the terminal I get the error message
      npm ERR! must provide string spec
      npm ERR! /home/pi/.npm/_logs/2021-06-05T13_55_01_431Z-debug.log
      The debug log
      0 verbose cli [ ‘/usr/bin/node’, ‘/usr/local/bin/npm’, ‘install’ ]
      1 info using npm@7.16.0
      2 info using node@v10.23.1
      3 timing npm:load:whichnode Completed in 8ms
      4 timing config:load:defaults Completed in 11ms
      5 timing config:load:file:/usr/local/lib/node_modules/npm/npmrc Completed in 11ms
      6 timing config:load:builtin Completed in 13ms
      7 timing config:load:cli Completed in 13ms
      8 timing config:load:env Completed in 2ms
      9 timing config:load:file:/home/pi/MagicMirror/modules/MMM-Fitbit2/.npmrc Completed in 2ms
      10 timing config:load:project Completed in 6ms
      11 timing config:load:file:/home/pi/.npmrc Completed in 1ms
      12 timing config:load:user Completed in 1ms
      13 timing config:load:file:/etc/npmrc Completed in 0ms
      14 timing config:load:global Completed in 1ms
      15 timing config:load:validate Completed in 2ms
      16 timing config:load:credentials Completed in 9ms
      17 timing config:load:setEnvs Completed in 7ms
      18 timing config:load Completed in 66ms
      19 timing npm:load:configload Completed in 67ms
      20 timing npm:load:setTitle Completed in 2ms
      21 timing npm:load:setupLog Completed in 12ms
      22 timing npm:load:cleanupLog Completed in 17ms
      23 timing npm:load:configScope Completed in 0ms
      24 timing npm:load:projectScope Completed in 2ms
      25 timing npm:load Completed in 113ms
      26 timing config:load:flatten Completed in 18ms
      27 timing arborist:ctor Completed in 5ms
      28 timing idealTree Completed in 35ms
      29 timing command:install Completed in 146ms
      30 verbose stack TypeError: must provide string spec
      30 verbose stack at new Edge (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/edge.js:48:13)
      30 verbose stack at Node.[_loadDepType] (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/node.js:781:9)
      30 verbose stack at Node.[Arborist.Node._loadDeps] (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/node.js:765:23)
      30 verbose stack at new Node (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/node.js:232:20)
      30 verbose stack at Arborist.[rootNodeFromPackage] (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:365:18)
      31 verbose cwd /home/pi/MagicMirror/modules/MMM-Fitbit2
      32 verbose Linux 5.10.11-v7+
      33 verbose argv “/usr/bin/node” “/usr/local/bin/npm” “install”
      34 verbose node v10.23.1
      35 verbose npm v7.16.0
      36 error must provide string spec
      37 verbose exit 1
      Any help with the issue would be greatly appreciated thank you.
      V 1 Reply Last reply
      • V
        Vizulize Module Developer @JJW
        @jjw A quick Google search for this error suggests to me that it is related to your node/npm versions, but I can’t offer any more input than that I’m afraid!
        J 1 Reply Last reply
          JJW @Vizulize
          @vizulize No worries, thank you. :beaming_face_with_smiling_eyes:
            sdetweil @JJW
            @jjw looks like npm v7…
              JJW @sdetweil
              @sdetweil sorry for the lack of knowledge, but what does that mean/what do I have to change.
                sdetweil @JJW
                @jjw from the commandline do
                npm install -g npm@6.14.10
                MAY need sudo in front if it fails for permissions error
                after then check
                npm -v
                then redo the steps u were trying to do before
                J 2 Replies Last reply
                  JJW @sdetweil
                  @sdetweil said in MMM-Fitbit2:
                  Will try now, thank you very much.
                    JJW @sdetweil
                    @sdetweil Thank you for your help, have the Fitbit module displaying on the monitor now, however, just says loading.:grinning_squinting_face:
                      sdetweil @JJW
                      @jjw now we need to look for messages in the place u start MM
                      npm start or pm2, if pm2, then the pm2 logs --lines=100 command will show
                      and the developers window on the MM screen
                      ctrl-shift-i, select the console tab, and add part of the module name to the filter field , fit
                        JJW @sdetweil
                        @sdetweil I ran “pm2 logs --lines=100” in the command line and the only returns I got were for the calendar.
                        0|MagicMir | [05.06.2021 18:31.09.798] [INFO] Calendar-Fetcher: Broadcasting 10 events.
                        I’m sorry I don’t know what you mean by developer window, but when I use ctrl+shift+i out of the cmd I take a screenshot and then when I’m in the cmd I just rename the box.
                          JJW @sdetweil
                          @sdetweil I ran another test for 1000 line and the only mention of Fit is:
                          0|MagicMir | [05.06.2021 18:22.00.914] [INFO] Checking git for module: MMM-Fitbit2
                          After that, it moves onto multicast.
                            sdetweil @JJW
                            @jjw on the magicmirror screen, not commandline
                            press ctrl-shift-i together
                            a new window will open 1/2 the Mm screen
                            in that window there is a tabbed interface,
                            here showing error from one of my modules, part of name in filter field
                              JJW @sdetweil
                              @sdetweil Ah, I think because I’m accessing my Pi via VNC viewer, that’s what makes it take a screenshot instead of opening that menu, even when on the MM screen, is there another way to access this? If not work directly through the Pi.
                                sdetweil @JJW
                                @jjw well, you could access from your pc, if the address/ipWhitelist settings in config.js allow it
                                then use chrome to view and open the dev window
                                  JJW @sdetweil
                                  @sdetweil This is what comes up when I filter by fit
                                    sdetweil @JJW
                                    @jjw ok, now you know everything I know.
                                    no errors were reported.
                                      JJW @sdetweil
                                      @sdetweil Thank you for the continued help, really appreciate you taking the time. One last thought, I’ve gone through the processes again, and one of the dependencies, “python-fitbit” requires you to run
                                      sudo pip install -r requirements/base.txt
                                      When I run this code, I get the error message
                                      Could not open requirements file: [Errno 2] No such file or directory: ‘requirements/base.txt’
                                      S V 2 Replies Last reply
                                        sdetweil @JJW
                                        @jjw what folder are u supposed to be in when u run that command?
                                          JJW @sdetweil
                                          @sdetweil Unfortunately it doesn’t say so I’ve just tried running in and out of the Fitbit directory.
                                          https://github.com/m-roberts/MMM-Fitbit2
                                          redirects you to this webpage
                                          https://pypi.org/project/fitbit/0.3.1/
                                          and I can’t see anywhere it says what folder to install it into.
                                          • V
                                            @jjw Running init.sh inside the MMM-Fitbit2 folder should take care of installing the dependencies for you.
                                            • 4 / 5
