    MMM-Fitbit2
    Scheduled Pinned Locked Moved Health
    fitbithealthfitnesshealthywaterfoodtrackingactivity tracker
    98 Posts 21 Posters 175.1k Views 19 Watching
      sdetweil @JJW
      @jjw looks like npm v7…
        JJW @sdetweil
        @sdetweil sorry for the lack of knowledge, but what does that mean/what do I have to change.
          sdetweil @JJW
          @jjw from the commandline do
          npm install -g npm@6.14.10
          MAY need sudo in front if it fails for permissions error
          after then check
          npm -v
          then redo the steps u were trying to do before
            JJW @sdetweil
            @sdetweil said in MMM-Fitbit2:
            Will try now, thank you very much.
              JJW @sdetweil
              @sdetweil Thank you for your help, have the Fitbit module displaying on the monitor now, however, just says loading.:grinning_squinting_face:
                sdetweil @JJW
                @jjw now we need to look for messages in the place u start MM
                npm start or pm2, if pm2, then the pm2 logs --lines=100 command will show
                and the developers window on the MM screen
                ctrl-shift-i, select the console tab, and add part of the module name to the filter field , fit
                  JJW @sdetweil
                  @sdetweil I ran “pm2 logs --lines=100” in the command line and the only returns I got were for the calendar.
                  0|MagicMir | [05.06.2021 18:31.09.798] [INFO] Calendar-Fetcher: Broadcasting 10 events.
                  I’m sorry I don’t know what you mean by developer window, but when I use ctrl+shift+i out of the cmd I take a screenshot and then when I’m in the cmd I just rename the box.
                    JJW @sdetweil
                    @sdetweil I ran another test for 1000 line and the only mention of Fit is:
                    0|MagicMir | [05.06.2021 18:22.00.914] [INFO] Checking git for module: MMM-Fitbit2
                    After that, it moves onto multicast.
                      sdetweil @JJW
                      @jjw on the magicmirror screen, not commandline
                      press ctrl-shift-i together
                      a new window will open 1/2 the Mm screen
                      in that window there is a tabbed interface,
                      here showing error from one of my modules, part of name in filter field
                        JJW @sdetweil
                        @sdetweil Ah, I think because I’m accessing my Pi via VNC viewer, that’s what makes it take a screenshot instead of opening that menu, even when on the MM screen, is there another way to access this? If not work directly through the Pi.
                          sdetweil @JJW
                          @jjw well, you could access from your pc, if the address/ipWhitelist settings in config.js allow it
                          then use chrome to view and open the dev window
                            JJW @sdetweil
                            @sdetweil This is what comes up when I filter by fit
                              sdetweil @JJW
                              @jjw ok, now you know everything I know.
                              no errors were reported.
                                JJW @sdetweil
                                @sdetweil Thank you for the continued help, really appreciate you taking the time. One last thought, I’ve gone through the processes again, and one of the dependencies, “python-fitbit” requires you to run
                                sudo pip install -r requirements/base.txt
                                When I run this code, I get the error message
                                Could not open requirements file: [Errno 2] No such file or directory: ‘requirements/base.txt’
                                S V 2 Replies Last reply Reply Quote 0
                                  sdetweil @JJW
                                  @jjw what folder are u supposed to be in when u run that command?
                                    JJW @sdetweil
                                    @sdetweil Unfortunately it doesn’t say so I’ve just tried running in and out of the Fitbit directory.
                                    https://github.com/m-roberts/MMM-Fitbit2
                                    redirects you to this webpage
                                    https://pypi.org/project/fitbit/0.3.1/
                                    and I can’t see anywhere it says what folder to install it into.
                                    • V
                                      Vizulize Module Developer @JJW
                                      @jjw Running init.sh inside the MMM-Fitbit2 folder should take care of installing the dependencies for you.
                                        JJW @Vizulize
                                        @vizulize I’ve done that, unfortunately still just have loading.
                                          Dresch360 Project Sponsor
                                          Entered all of the required information in the Fitbit application registry.
                                          At the ./auth.sh process, entered correct “Client ID” and “Client Secret” and I get the following after Allowing full access during authentication process:
                                          **Fitbit
                                          The app you’re trying to connect did not provide valid information to Fitbit. Please report this issue to them.
                                          Developer information: invalid_request - Missing parameters: client_id**
                                          Any help would be greatly appreciated!
                                            Also - attempted to authorize and obtain token directly from the Fitbit site using their token authenticator from the “OAuth 2.0 tutorial page” and I received the error message below:
                                            404 Not Found
                                            Missing parameters: state
                                            File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cpdispatch.py”, line 54, in call
                                            return self.callable(*self.args, **self.kwargs)
                                            TypeError: index() missing 1 required positional argument: ‘state’
                                            During handling of the above exception, another exception occurred:
                                            File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cprequest.py”, line 628, in respond
                                            self._do_respond(path_info)
                                            File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cprequest.py”, line 687, in _do_respond
                                            response.body = self.handler()
                                            File “/usr/local/lib/python3.7/dist-packages/cherrypy/lib/encoding.py”, line 219, in call
                                            self.body = self.oldhandler(*args, **kwargs)
                                            File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cpdispatch.py”, line 60, in call
                                            raise sys.exc_info()[1]
                                            File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cpdispatch.py”, line 58, in call
                                            test_callable_spec(self.callable, self.args, self.kwargs)
                                            File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cpdispatch.py”, line 157, in test_callable_spec
                                            raise cherrypy.HTTPError(404, message=message)
                                            cherrypy._cperror.HTTPError: (404, ‘Missing parameters: state’)
                                            • 4 / 5
