    MMM-Fitbit2
    Scheduled Pinned Locked Moved Health
    fitbithealthfitnesshealthywaterfoodtrackingactivity tracker
    98 Posts 21 Posters 175.1k Views 19 Watching
      JJW @sdetweil
      @sdetweil I ran “pm2 logs --lines=100” in the command line and the only returns I got were for the calendar.
      0|MagicMir | [05.06.2021 18:31.09.798] [INFO] Calendar-Fetcher: Broadcasting 10 events.
      I’m sorry I don’t know what you mean by developer window, but when I use ctrl+shift+i out of the cmd I take a screenshot and then when I’m in the cmd I just rename the box.
        JJW @sdetweil
        @sdetweil I ran another test for 1000 line and the only mention of Fit is:
        0|MagicMir | [05.06.2021 18:22.00.914] [INFO] Checking git for module: MMM-Fitbit2
        After that, it moves onto multicast.
          sdetweil @JJW
          @jjw on the magicmirror screen, not commandline
          press ctrl-shift-i together
          a new window will open 1/2 the Mm screen
          in that window there is a tabbed interface,
          here showing error from one of my modules, part of name in filter field
            JJW @sdetweil
            @sdetweil Ah, I think because I’m accessing my Pi via VNC viewer, that’s what makes it take a screenshot instead of opening that menu, even when on the MM screen, is there another way to access this? If not work directly through the Pi.
              sdetweil @JJW
              @jjw well, you could access from your pc, if the address/ipWhitelist settings in config.js allow it
              then use chrome to view and open the dev window
                JJW @sdetweil
                @sdetweil This is what comes up when I filter by fit
                  sdetweil @JJW
                  @jjw ok, now you know everything I know.
                  no errors were reported.
                    JJW @sdetweil
                    @sdetweil Thank you for the continued help, really appreciate you taking the time. One last thought, I’ve gone through the processes again, and one of the dependencies, “python-fitbit” requires you to run
                    sudo pip install -r requirements/base.txt
                    When I run this code, I get the error message
                    Could not open requirements file: [Errno 2] No such file or directory: ‘requirements/base.txt’
                    S V 2 Replies Last reply Reply Quote 0
                      sdetweil @JJW
                      @jjw what folder are u supposed to be in when u run that command?
                        JJW @sdetweil
                        @sdetweil Unfortunately it doesn’t say so I’ve just tried running in and out of the Fitbit directory.
                        https://github.com/m-roberts/MMM-Fitbit2
                        redirects you to this webpage
                        https://pypi.org/project/fitbit/0.3.1/
                        and I can’t see anywhere it says what folder to install it into.
                        • V
                          Vizulize Module Developer @JJW
                          @jjw Running init.sh inside the MMM-Fitbit2 folder should take care of installing the dependencies for you.
                            JJW @Vizulize
                            @vizulize I’ve done that, unfortunately still just have loading.
                              Dresch360 Project Sponsor
                              Entered all of the required information in the Fitbit application registry.
                              At the ./auth.sh process, entered correct “Client ID” and “Client Secret” and I get the following after Allowing full access during authentication process:
                              **Fitbit
                              The app you’re trying to connect did not provide valid information to Fitbit. Please report this issue to them.
                              Developer information: invalid_request - Missing parameters: client_id**
                              Any help would be greatly appreciated!
                                Also - attempted to authorize and obtain token directly from the Fitbit site using their token authenticator from the “OAuth 2.0 tutorial page” and I received the error message below:
                                404 Not Found
                                Missing parameters: state
                                File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cpdispatch.py”, line 54, in call
                                return self.callable(*self.args, **self.kwargs)
                                TypeError: index() missing 1 required positional argument: ‘state’
                                During handling of the above exception, another exception occurred:
                                File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cprequest.py”, line 628, in respond
                                self._do_respond(path_info)
                                File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cprequest.py”, line 687, in _do_respond
                                response.body = self.handler()
                                File “/usr/local/lib/python3.7/dist-packages/cherrypy/lib/encoding.py”, line 219, in call
                                self.body = self.oldhandler(*args, **kwargs)
                                File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cpdispatch.py”, line 60, in call
                                raise sys.exc_info()[1]
                                File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cpdispatch.py”, line 58, in call
                                test_callable_spec(self.callable, self.args, self.kwargs)
                                File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cpdispatch.py”, line 157, in test_callable_spec
                                raise cherrypy.HTTPError(404, message=message)
                                cherrypy._cperror.HTTPError: (404, ‘Missing parameters: state’)
                                  sdetweil @Dresch360
                                  @dresch360 looks like something changed in the api requirements, but the library version hasnt
                                    @sdetweil - Thanks for your reply. So does this mean that no new tokens can be created?
                                      richmp95
                                      any chance of this being revived and updated?
                                        sdetweil @richmp95
                                        @richmp95 you’d have to post in an issue in the module GitHub repo
                                        • V
                                          Vizulize Module Developer @richmp95
                                          @richmp95 - last I checked, this still works. Why does it need ‘reviving’?
                                          If you would like to have extra features, I am open to suggestions and contributions.
                                          • L
                                            Layton
                                            Is there anyway to remove the goal tracking widget underneath each resource?
                                            I have been trying to play around with removing it myself, but every time I touch something it breaks the whole module.
                                            Any ideas!?
                                            • 4 / 5
