    MMM-YouTube
    64 Posts 15 Posters 41.5k Views 16 Watching
      A Former User @Egnos
      @Egnos
      You can use a few methods; via TelegramBot commands, notifications from other modules.
      Which usecase are you considering?
      • E
        Egnos
        Thanks @Sean
        Unfortunately I thought there was the possibility of sending youtube videos via smartphone using “RaspiCast” or something similar…
        Could you recommend some module?
        ? 1 Reply Last reply
          @Egnos
          MMM-TelegramBot. You can send like this on telegram;
          /yt https://www.youtube.com/watch?v=dAB3gziF9R4
          Or you can use MMM-Remote-Control or other HTTP Request Receiver modules (e.g: MMM-NotificationTrigger),
          But additional typing is somewhat annoying.
          • E
            Egnos
            @Sean said in MMM-YouTube:
            MMM-Remote-Control
            Thanks for your advises, but I chose to use RaspiCast directly to share the videos (when the video ends the MM returns…).
            Do you know how to mute the sound of the MM (not the Raspberry …)?
              A Former User @iwaldrum
              @iwaldrum
              Well, ideally possible. But I think you’d better make playlist to play several video sequentially.
              I 1 Reply Last reply
              • I
                iwaldrum @Guest
                @Sean Thanks Sean. Is there a way to limit the amount of time for each video in the playlist? Only play for 30 seconds, then switch to the next video in the playlist?
                  @iwaldrum
                  Maybe possible. As far as I know, There are several scheduling modules. Or you can use cron. Emit notification per 30 seconds.
                  But, If I were you, I would just make a summary video clip with 30 seconds of each videos. :D
                  • A
                    ArthurOff
                    Hi! How do I get rid of black borders around the video, i.e. stretch/fill/crop the video?
                    • bugsounetB
                      bugsounet Banned
                      @csoogos : and yes … it’s dead and this module is not maintened ;)
                      Actually, just only one module with youtube feature works ;)
                      Reply Quote -1
                        Shinigami @bugsounet
                        @bugsounet Good morning and happy Sunday. I would like to ask you which youtube module works?
                        • H
                          hogedir
                          Same question : I want to use youtube (via iframe or not), how can it be possible with the actual version of Magic mirror ? please ! thanks
                          M 1 Reply Last reply
                            MMRIZE @hogedir
                            @hogedir @Shinigami
                            I didn’t test all the feature, but still working as expected in MM 2.26.
                            Tested config is here;
                            	module: "MMM-YouTube",
                            		defaultQuality: "default",
                            		width: "400px",
                            		height: "300px",
                            		onStartPlay: {
                            			type: "id",
                            			shuffle: true,
                            			loop: false,
                            			autoplay: true,
                            • 4 / 4
