    NFL Score Module
    95 Posts 20 Posters 136.0k Views 25 Watching
      Shawnsully @strawberry 3.141
      @strawberry-3.141 Thank you so much for your help
      module: ‘MMM-NFL’,
      position: ‘bottom_left’,
      colored: true,
      network: false,
      reloadinterval: 900000,
      cowboysdudeC B 2 Replies Last reply
      • cowboysdudeC
        cowboysdude Module Developer @Shawnsully
        @Shawnsully
        @Shawnsully said in NFL Score Module:
        module: ‘MMM-NFL’,
        colored: true,
        network: false,
        Your missing something… copy this and try it…
        module: ‘MMM-NFL’,
        colored: true,
        network: false,
          Shawnsully @cowboysdude
          @cowboysdude Again, thank you for your assistance. I still get the generic “Please add config” error.
          • cowboysdudeC
            OK well I’d see to your entire config … private msg me with your entire config.js file… so I can take a look at it.
            • strawberry 3.141S
              [card:fewieden/MMM-NFL]
              Changelog:
              Removed network column due to it’s not longer provided through the API
              Implemented voice commands to show passing, rushing, receiving, tackles, sacks and interceptions statistics
              Color and Logo type are also changeable through voice commands on the fly
              alt text
              • strawberry 3.141S
                Changelog:
                • Handling Bye Week for focus_on teams
                alt text
                  bhepler Module Developer @Shawnsully
                  @Shawnsully Double-check your commas and curly braces, specifically at the beginning of your module entry. You have:
                       module: 'MMM-NFL',
                  You probably want:
                       module: 'MMM-NFL',
                  • strawberry 3.141S
                    strawberry 3.141 Project Sponsor Module Developer @strawberry 3.141
                    Changelog:
                    • possible fix for starting times of matches in london
                    O 1 Reply Last reply
                    • O
                      ooom416354 @strawberry 3.141
                      @strawberry-3.141 Hi, just curious, is there a way to show only one particular team? I tried adding a team to the focus_on array but I then returned no rows back.
                      Thanks in advance!
                      • cowboysdudeC
                        cowboysdude Module Developer @ooom416354
                        @ooom416354 said in NFL Score Module:
                        Thanks in advance!
                        This is an my config… it works :)
                        module: ‘MMM-NFL’,
                        position: ‘bottom_bar’,
                        colored: true,
                        helmets: false,
                        reloadInterval: 10000,
                        focus_on: [‘DAL’]
                        Don’t forget to put team or teams in the 'focus_on: just as I have it… in brackets and in single quotes.
                        • O
                          ooom416354 @cowboysdude
                          @cowboysdude Thanks!!!
                          • T
                            TheHyp3
                            I got a problem: Every second its switching between Regular-Season 2016 and Post-Season 2015?
                            I´ve updated already but still the same problem. Here is my config:
                            		 module: 'MMM-NFL',
                            		 position: 'top_left',
                            		 	colored: 'true',
                            			focus_on: ['NE', 'SEA', 'PHI', 'NYG', 'DAL'],
                            Any help on that?
                            • strawberry 3.141S
                              strawberry 3.141 Project Sponsor Module Developer @TheHyp3
                              @TheHyp3 thanks for reporting, I made a hotfix for it. I’m not sure how the data will look like when we are in the post season, so it could happen again.
                              your config has some syntax errors. you shouldn’t put a boolean into quotes. in javascript it will allways lead to true, so if you would have done colored: 'false' it would have been colored as well.
                              T 1 Reply Last reply
                              Reply Quote 2
                              • T
                                TheHyp3 @strawberry 3.141
                                @strawberry-3.141 its working now. Thanks again ;)
                                Also fixed my config!
                                • strawberry 3.141S
                                  Fixed not changing to post season and added icons for TBD
                                    chieftainSupreme @strawberry 3.141
                                    @strawberry-3.141 has there been any movement on this? I’ve been dying for an NBA module but can’t find a basketball API, and I’m pretty new to the scene to begin with. I’d love to collaborate with someone on this, if there’s interest.
                                    • strawberry 3.141S
                                      strawberry 3.141 Project Sponsor Module Developer @chieftainSupreme
                                      @chieftainSupreme sorry I have no time in the next month to do any requests, but i saw that someone forked my repository and trys to change it for nba. check it out maybe you can help him https://github.com/in-a-days/MMM-NBA/
                                      I 1 Reply Last reply
                                      • I
                                        in_a_days @strawberry 3.141
                                        @strawberry-3.141 @chieftainSupreme
                                        I am playing around with this - but I’m also just barely qualified to write code!
                                        I’m gutting out most the higher level functions like stats and voice support, trying to just get correct scores to display. Biggest problem so far is I can not find an easy to parse score feed. This NFL feed is perfect.
                                        http://www.nfl.com/liveupdate/scorestrip/ss.xml
                                          chieftainSupreme @in_a_days
                                          @in_a_days I’ve been having trouble finding an NBA feed as well, I’ll keep looking and let you know if I find anything
                                          • I
                                            in_a_days @chieftainSupreme
                                            @chieftainSupreme
                                            Found this today. It’s not nearly as elegant as the NFL xml file, but it should technically be parsable.
                                            http://www.espn.com/nba/bottomline/scores
                                            • 3 / 5
