    Weather station for MagicMirror and SmartHome wanted
    11 Posts 7 Posters 4.8k Views 7 Watching
      jakobeadonis @MajorC
      Digital Wall Calendar and Home Information Center: In this Instructable I’ll be weather and other information (such as events from your calendar.
        sdetweil @jakobeadonis
        @jakobeadonis nice hardware setup but primative software compared to MagicMirror capabilities
        • cowboysdudeC Offline
          cowboysdude Module Developer @MajorC
          @majorc I went with Ambient Weather because your data gets uploaded to both Ambient Weather and Weather Underground.
          Ambient Weather
          For this you get an API key that will return your data in json format which is very usable to build your own module with. This is your weather data which means it’ll be VERY accurate for your area because you are the one capturing it.
          OR
          You can take the weather info you get back and put it into ANY weather module here and make it work.
          They have helper libraries for the api for node js already. Because it’s your data the rate limit is NO more then 1 hit per second… which basically means you can up to the minute accurate weather data.
          While I don’t really write too many modules anymore I will be making a new weather module for my mirror with my data :)
          The reason why you don’t see Eve used in the US much is because they are more expensive compared to say Xiaomi products which most are half the price of Eve products.
          I am running Home Assistant and I have Xiaomi temp/humd sensors, motions sensors, etc. Much less expensive and work very well.
            MajorC Project Sponsor @cowboysdude
            @cowboysdude Nice. I have now a Natatmo station and very happy.
            https://www.netatmo.com/de-de/weather/weatherstation
            Works very good with https://forum.magicmirror.builders/topic/12315/mmm-netatmo-updated
              @majorc They look REALLY awesome!! I’m putting mine on the pole tomorrow…it’s a weekend so I get to play LOL.
              Got the 10’ black iron pole all ready to go… mount is ready. Just a matter of installing it and putting the station on top :)
              I did find this you may want to look at ->
              https://cbornet.github.io/netatmo-swagger-decl/#section/Authentication
              • FoziF Offline
                Fozi Project Sponsor @cowboysdude
                @cowboysdude Yeah, I have my Netamos for more than 8 years now and they are awsome. I found also a fork, which allows to display several base stations https://github.com/MariusEng/MMM-Netatmo
                swvalentiS 1 Reply Last reply Reply Quote 1
                • swvalentiS Offline
                  swvalenti Project Sponsor @Fozi
                  I use https://weatherflow.com/tempest-weather-system/ and really like it
                    cowboysdude Module Developer @swvalenti
                    @swvalenti Here’s my weather page from Wunderground
                    https://www.wunderground.com/dashboard/pws/KNYELMIR44/graph/2021-07-24/2021-07-24/daily
