    MMM-MyScoreboard
    277 Posts 60 Posters 641.8k Views 63 Watching
      JRichardson10
      Hi complete coding and raspberry pie newbie here, I was wondering if it’s possible to add a code sequence that allows you to only show the results from one sports division/league at a time and fade between all the listed divisions/leagues I’ve included in config.js file, similar to how it’s fades between each sports league table in the ‘MMM-MyStandings’ module. I’ve tried looking through the ‘MMM-MyScoreboard.js’ file but cannot find any solution.
      Apologies if this is a really simple solution, I’m very new to this😅. Any help would be greatly appreciated!
      • E
        Egnos
        Hi everyone, many thanks for the module, it is really beautiful!
        Is it possible to freeze match results until the next match?
        Now after the games have finished the results disappear …
        • BKeyportB
          BKeyport Module Developer @Egnos
          @Egnos Short answer: No. Long Answer: Noooooooooooooooooooooooooooooooooooooo.
          Due to the data feeds, the match is cleared as soon as they set up the new ones. You’d be better off to use a module specific to your target league for that, where the author took the time to cache results.
          • E
            Egnos @BKeyport
            @BKeyport thanks.
            If I set “rolloverHours” configuration parameter with a very high number … like 100?
            When the match schedule is updated would it change?
              mcaminiti
              • sifuhallS
                sifuhall
                I followed the instructions here for the git pull and npm install with no errors.
                In my config file I place this but all I get is a blank screen.
                module: “MMM-MyScoreboard”,
                position: “top_left”,
                classes: “default everyone”,
                header: “My Scoreboard”,
                showLeagueSeparators: true,
                colored: true,
                viewStyle: “mediumLogos”,
                sports: [
                league: “NCAAF”,
                teams: [“UK”]
                • W
                  Wenike @sifuhall
                  @sifuhall You won’t get anything until the UK football team has a game, which won’t be for a few weeks. Until then, this module displays nothing.
                  sifuhallS 1 Reply Last reply Reply Quote 0
                  • sifuhallS
                    sifuhall @Wenike
                    @wenike Thank you for the reply. But I’m saying the entire screen is blank. Not just the scores section.
                    W S 2 Replies Last reply Reply Quote 0
                    • W
                      Wenike @sifuhall
                      @sifuhall So, other modules aren’t showing either?
                        sdetweil @sifuhall
                        @sifuhall this sounds like the the missing libraries problem. when the screen is blank, can u show the message at mm startup?
                        if using pm2, use
                        pm2 logs --lines=100
                        • sifuhallS
                          sifuhall @sdetweil
                          Yes, this was it exactly. Once I added the request module everything was fine.
                          However, I do have one question.
                          How can I add the West Ham United Football Club?
                          • BKeyportB
                            BKeyport Module Developer @sifuhall
                            @sifuhall it looks like it’s not supported based on the code.
                            • sifuhallS
                              sifuhall @BKeyport
                              @bkeyport Thank you for the reply
                              • E
                                Egnos
                                Hello everybody,
                                I’m having trouble with this module, are any of you using it?
                                The following errors MM returns me:
                                [02.09.2022 10:52.55.068] [LOG]   [MMM-MyScoreboard] 2-Sep-22 10:52 ** ERROR ** Couldn't retrieve ITA_SERIE_A data for provider ESPN: Error: getaddrinfo ENOTFOUND site.api.espn.com
                                [02.09.2022 10:52.55.068] [LOG]   [MMM-MyScoreboard] http://site.api.espn.com/apis/site/v2/sports/soccer/ita.1/scoreboard?dates=20220902&limit=200
                                Starting module: MMM-MyScoreboard MMM-MyScoreboard.js:560
                                All modules started!
                                MMM-MyScoreboard.js:552
                                [MMM-MyScoreboard] Updating Scores module.js:195
                                MMM-MyScoreboard is suspended.
                                Below my configuration
                                		  module: "MMM-MyScoreboard",
                                		  classes: "default everyone",
                                		  header: "My Scoreboard",
                                			colored: true,
                                			viewStyle: "mediumLogos",
                                			sports: [
                                				league: "ITA_SERIE_A",
                                				//teams: ["JUV"]
                                				//label: "Seria A TIM 2022/23"
                                Can you help me?
                                  sdetweil @Egnos
                                  @Egnos looks like the provider changed their API. so the module will have to be changed
                                  • E
                                    Egnos @sdetweil
                                    @sdetweil said in MMM-MyScoreboard:
                                    Hi @sdetweil
                                    I understand. Do you know if the developer still maintains the module?
                                      sdetweil @Egnos
                                      @Egnos no idea, go look at the GitHub site, post an issue.
                                      • E
                                        Egnos @sdetweil
                                        I tried to do the recommended fix but nothing has changed.
                                        https://github.com/jclarke0000/MMM-MyScoreboard/pull/61
                                        I opened a problem on GitHub as you advised me, I await an answer.
                                        If someone had solved … give a whistle ;-)
                                          sdetweil @Egnos
                                          @Egnos but that PR fixes the wrong provider… the espn provider is broken
                                          the error u posted
                                          that module is 5 years old… these providers change things every year…
                                          • BKeyportB
                                            @sdetweil ESPN sneezes and the data format changes. Not a reliable source.
                                            E 1 Reply Last reply Reply Quote 1
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 12 / 14
